New member here, but have been a lurker for a few years now. 56K miles on the JSW now, and just about out of warranty.
Issues seen so far have been:
@ ~12K, gas door would not open. Replaced under warranty.
@ ~20K, HPFP failure, <50mi after 20K service completed at the dealer.
Potentially, the fuel pump was not primed properly, or just coincidence. Repaired under warranty.
MIL popped up and error code scanned was P0470.
001136 - Exhaust Pressure Sensor 1 (G450)
P0470 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 15
Mileage: 90939 km
Time Indication: 0
Date: 2100.14.16
Time: 10:30:13
Freeze Frame:
RPM: 1150 /min
Speed: 50.0 km/h
Temperature: 10.8°C
Temperature: 70.2°C
Temperature: 66.0°C
Pressure: 326 mbar
Pressure: 3 mbar
Datalogged what I am assuming is the G450 sensor, and did not see any abnormalities. Perhaps the logging rate (turbo enabled) is not high enough to pick up the erroneous value(s) that caused the MIL. I'm assuming the first "Pressure" value in the freeze frame is the pressure difference, and the second "Pressure" value is the pressure difference offset. Not really sure what the pressure difference offset is, but those were the only pressure related variables in VCDS. This is a big assumption though...
Cleared the code, and took a quick drive. The MIL did not light up, but when checking for fault codes, the same error had already been logged.
Ordered a new sensor (076-906-051-B), replaced, and completed adaptation. Easy access and <30mins to replace and adapt the new sensor.
No MIL has occurred since replacement, but will continue monitoring.
Datalogged after sensor replacement and its basically the same thing, acceleration causes higher deltaP, cruising gives a ~constant deltaP, idle has low deltaP. Potentially if I left the faulty sensor in longer before replacement I would see more obvious symptoms (abnormal soot load, regen based on time or distance), but it was replaced <20 mi after MIL. I could not tell any difference in the way the car drove with the MIL on.
Datalog of "Bad" sensor
Sensor Adaptation procedure.
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Mileage: 90939 km
Time Indication: 0
Date: 2100.14.16
Time: 10:30:13
Freeze Frame:
RPM: 1150 /min
Speed: 50.0 km/h
Temperature: 10.8°C
Temperature: 70.2°C
Temperature: 66.0°C
Pressure: 326 mbar
Pressure: 3 mbar
