Old February 2nd, 2013, 14:45   #1
nvr-enuf
Default Transmission in limp mode - how to reset / remove limp mode?
Hello everyone,
recently my trans puked out all the trans fluid. I changed the filter / seal - added 3.5 quarts, drove the car a bit but it seems like the car is in limp mode.
It was slow to engage gears, maybe the pump is fried.
I will see if it is low, I would expect the trans would take more than 3.5 qts.
I am in the process of doing the manual conversion but would like to try to drive the car for the next month.
Does anyone know how to clear the limp mode without a VAGCOM?
thanks
SCott
nvr-enuf is offline   Reply With Quote
Old February 2nd, 2013, 21:55   #2
vwztips
vwztips's Avatar
Might as well bite the bullet and buy a VCDS cable as you will need it for the conversion or you will have to pay someone to do it for you.
vwztips is offline   Reply With Quote
Old February 3rd, 2013, 06:01   #3
nvr-enuf
So the answer to the question is "the only way to recent the trans limp mode is to use a VAGCOM"?
Thanks - looks like the brother in law needs to stop by - he has the cable.
I agree, when I do the conversion the vagcom will be needed.
Old February 3rd, 2013, 17:43   #4
cpinde
TDI(s): 05 VW Passat
Let me say that I ordered my VCDS (Vagcom) cable from Ross Tech last Friday at like 1pm. They got it out the same day and I had it the next day, paid extra for overnight. Great people to deal with.
The couple times my trans went into limp mode all I did was turn the car off and back on and that cleared the limp mode. But the thing that caused my limp mode was/is intermittent.
cpinde is offline   Reply With Quote
Old February 4th, 2013, 17:33   #5
rydogg
TDI(s): Passat
What caused your transmission to "puke out all the fluid"? This sounds very bizarre.
Unchained!!
rydogg is offline   Reply With Quote
Old August 19th, 2013, 07:40   #6
wswanson
TDI(s): 2002 jetta
There is a pop off valve on the top of the trans my 05 1.8t did the same thing due to that pop off being bad
wswanson is offline   Reply With Quote
Old August 19th, 2013, 09:30   #7
vwztips
vwztips's Avatar
From the ones I have seen the pump seal fails.
Old August 26th, 2013, 03:18   #8
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
there is no "pop off valve". Do you mean the vent?
Mostly if they "puke out the fluid" the front seal is leaking, usually from the pump bushing spinning out. (like vwztips said)
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Transmission LIMP mode P0706 DHC VW B5 Passat TDIs 13 May 23rd, 2015 13:56
Can driving in limp mode ruin a transmission? 03PlatinumBug VW B5 Passat TDIs 43 October 21st, 2011 01:58
Limp mode reset by Scanguage?? cleaver TDI 101 27 March 29th, 2010 09:17
limp mode reset while going up a mountain? kooyajerms TDI 101 6 May 3rd, 2009 06:43
Transmission Limp Mode iBlake TDI 101 2 December 29th, 2008 17:57
Page generated in 0.15756 seconds with 10 queries
[Output: 83.05 Kb. compressed to 71.47 Kb. by saving 11.58 Kb. (13.95%)]
