Old January 24th, 2013, 17:11   #1
Whitbread
Whitbread's Avatar
TDI(s): Several
Post Whitbread Performance Innovations. Product and service offerings
This thread will be a complete listing of all products and services I offer. Please watch for updates and announcements. For any questions, please g-mail me. I'll try to keep things here as clean and organized as possible. Thanks!
Audi 01E Importing, Rebuilding, and Custom Clutches
Due to the increased demand, I've slowly been working on sourcing TDI ratio 01E's and related parts. I'm pleased to announce that I've recently established some importing contacts and have become a distributor for JH Motorsport. They recently developed their own carbon lined syncros that are far better than oem and cheaper. They will also have their own 1-2 shift collar released very shortly that won't be $600 like the vw one. This means that for the first time ever, 01E's will actually be able to rebuilt for a reasonable price.
For the guys wanting to do 6 speed swaps into b5.5's, I've been working with DC Clutch to develop a custom SMF unit that will use the stock starter, not require a spacer plate, and have a total weight of 40 lbs. The oem dmf setup is 41lbs. Holding power can be done up to 600lb/ft for anyone going nuts. The disks have a special hub that is sprung extremely softly to help absorb torsional vibrations. Pricing and availability will be announced shortly.
UPDATE:
As promised, here are pictures of the final prototype 240mm smf kit for 01E/01A longitudinal applications.
02 Jetta TDI
-Full TDI maintenance, performance and custom fabrication services. 248-755-8118, 10AM-5PM EST M-F. Please email or call only for business inquiries. PM's are not for business communication.
Whitbread is offline   Reply With Quote
Old January 24th, 2013, 17:11   #2
Whitbread
Whitbread's Avatar
TDI(s): Several
Fabrication and Machining Services
Fluidampr's with 4 groove pulley added for B5.5 BHW applications when doing manual swaps.
02 Jetta TDI
Old January 24th, 2013, 17:12   #3
Whitbread
Whitbread's Avatar
TDI(s): Several
Dealer Product Listing
Auto Tech/Wavetrac
Peloquin
South Bend Clutch
Venair Silicone Products
Vibrant Fabrication Products
JH Motorsports
Premier Performance
A1 Technologies
02 Jetta TDI
Old January 24th, 2013, 17:13   #4
Whitbread
Whitbread's Avatar
TDI(s): Several
Turbo Supplies and Turbo Kits
I've worked with RyanP to develop a budget minded big turbo kit. Components will be;
B5.5 passat exhaust manifold from Ryan. Ceramic coating would be optional
Turbo to manifold adapter plate from Ryan
1756vk or 2260vk turbo from Ryan. (2056vk's are NLA)
Oil feed and drain lines
Vacuum actuator conversion using Ryan's stainless bracket
2.5" V band ring welded to turbine housing
2.5" stainless downpipe for mk4 kit
Silicone elbow to build your own turbo inlet pipe
Silicone connector and T bolts for compressor outlet
Assorted stainless hardware and gaskets
For mk3's, I'm afraid I won't be able to make a downpipe for it. I will still weld a V band ring on the turbine housing and weld a 90* elbow to the mating v band ring. For the mk3, I'll also do the necessary welding to re-direct the compressor outlet to work better with the mk3 piping orientation.
The pricing goal is ~$1900 for the mk4 kit with the downpipe and ~$1600 for the mk3 kit without the dp.
Lower IC pipe and modded PD150 TIP will not be parts of the normal kits unless customer adds them as options for additional costs.
Here's some pics to give you an idea;
On a mk3 block with stock engine mount
In a mk4 jetta
02 Jetta TDI
Old January 24th, 2013, 17:15   #5
Whitbread
Whitbread's Avatar
TDI(s): Several
Custom Injector Nozzles
Let me know what you want and lets bring some cool stuff come to market. Can do any size up to somewhere around .025" holes for VE/PD/CR nozzles.
Delivery time is 2-6 weeks depending on nozzle.
VE Nozzles
Each .001" increase in hole size is ~15% increase in flow for VE nozzles.*
5x.010" $335 (approximately equal to race 520's)
5x.011" $350
5x.012" $375
5x.013" $395
5x.014" $410
I have 2 sets of 5x.012's in stock right now.
PD Nozzles
Stock 04-05 passat pd140 nozzles are 5x.008" for reference. Due to higher injection pressure, each .001" increase in hole size flows ~20% more.
5x.012" $450 (Approximately 6% less than a Race 783)
5x.013" $495
5x.014" $499
For those looking to do a hot swap type of deal, I have a set of BEW bodies that are at Drive By Wire's. For a $500 deposit, I will loan out a set of bodies that can have the nozzles installed and calibrated on. That way, you're not down a car. Once Pete receives your old bodies and confirms they are BEW or BHW bodies in good working order, I'll refund the deposit.
The nozzle blanks are made by Firad in Italy and are then modified here in the good ol US of A. They come with the smile guarantee; if you don't smile after putting them in, I'll buy them back plain and simple.
02 Jetta TDI
Old January 24th, 2013, 17:16   #6
Whitbread
Whitbread's Avatar
TDI(s): Several
OEM Replacement Fabricated Parts
02 Jetta TDI
Old January 24th, 2013, 17:17   #7
Whitbread
Whitbread's Avatar
TDI(s): Several
Custom Engine and Transmission Building
Custom VE, PD, and CR Head Studs custom made to my specs by A1 Technologies. $375 shipped to USA, $405 to Canada for H11 VE or PD stud kits. H11 tool steel is 255kpsi tensile, ARP2000 is 220kpsi tensile.
UPDATE 11-19-13: VE H11 studs are sold out. Sorry! Have 4 PD stud kits left.
I also have ARP 8740 Chromoly stud kits for PD engines available for those who don't quite need the H11's. 8740 is 190kpsi tensile strength. $185 shipped with the OD of the ARP nut lathed down to clear the cam caps. Uses stock head bolt washers.
02 Jetta TDI
Old January 24th, 2013, 17:19   #8
Whitbread
Whitbread's Avatar
TDI(s): Several
TDI Swaps and Re-powers
02 Jetta TDI
Old January 24th, 2013, 17:27   #9
bikerboyriley
bikerboyriley's Avatar
Fuel Economy: 46 mpg
Do you make tubular manifold that can keep turbo in stock position?
2001 2 door alh tdi. Ventectomy, ccv mod, Aero stainless muffler, FMIC, OMI, Street toys gt1856 hybrid, 2.5'' downpipe, PP764, 11mm IP, In tank lift pump, 3barmap, arp headstuds, southbend endurance stage 2 clutch,fuel cooler, mcnally boost/egt gauge, dieselgeek shifter linkage, malone stage 5, ARP headstuds, Koni fsd's
bikerboyriley is offline   Reply With Quote
Old January 24th, 2013, 18:03   #10
Whitbread
Whitbread's Avatar
TDI(s): Several
Reserved
02 Jetta TDI
Old January 24th, 2013, 18:04   #11
Whitbread
Whitbread's Avatar
TDI(s): Several
reserved
02 Jetta TDI
Old April 30th, 2013, 20:38   #12
Whitbread
Whitbread's Avatar
TDI(s): Several
I regret to announce that from this time on, I will not be taking any new appointments for general service work. All other operations will continue as usual.
For any locals needing basic service work, please contact Marty Bergel or Munk's garage in Waterford.
02 Jetta TDI
Old April 30th, 2013, 20:45   #13
Good Ol' Boy
VeeDubTDI's Avatar
Good for you, Matt! I'm glad the custom stuff is able to fill your schedule.
Old April 30th, 2013, 20:57   #14
Whitbread
Whitbread's Avatar
TDI(s): Several
Fill is an understatement. Going from 70 hours a week at my shop to 20 at best severely hampers the amount of work I can get done .
02 Jetta TDI
Old May 1st, 2013, 04:31   #15
Growler
Got Soot Vendor
Growler's Avatar
Is everything still going well at your Day job? Glad to hear it. keep up with the Mods. always liked seeing what you come up with.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Whitbread Performance Innovations is now in operation! Whitbread Vendor & GroupBuy items for sale 463 January 24th, 2013 11:27
Whitbread Performance Innovations is now a Peloquin and Venair Silicone dealer Whitbread Vendor & GroupBuy items for sale 11 April 4th, 2012 09:46
NewSouth Performance Product Announcements VailPowder Vendor & GroupBuy items for sale 0 March 26th, 2008 08:58
Page generated in 0.16858 seconds with 10 queries
[Output: 139.88 Kb. compressed to 116.43 Kb. by saving 23.44 Kb. (16.76%)]
