Old February 1st, 2013, 10:37   #1
Cycleman
Cycleman's Avatar
Default Splash Guards, Mud Flaps ???
Whatever you call them, I'm thinking of getting splash guards (aka, mud flaps) for my 2013 JSW.
The main reason I'm thinking is to help the rear window not get so hard-to-see filthy. That has happened a lot so far this winter.
So, a few questions:
  • Will splash guards help keep the rear window a bit cleaner?
  • Are they easy to install?
  • What's involved with an install?
  • Are the VW brand splash guards a good choice?
All opinions from those who have used these rubber items are greatly welcomed.
Dave, who also sees two different part numbers for this item for the JSW on a VW dealer's site
Cycleman is offline   Reply With Quote
Old February 1st, 2013, 11:06   #2
bdisco
bdisco's Avatar
No
Yes
A few screws
I have the oem
http://forums.tdiclub.com/showthread.php?t=299110
So when the Dealer tells you "Don't worry, that's normal, they all do that." , they're not lying.
bdisco is offline   Reply With Quote
Old February 1st, 2013, 11:08   #3
rfortson
I have them on my '12 JSW. I don't see them helping much with the dirty rear window, but then I don't have that problem. Not a lot of winter road grime down here in Texas. I mainly got them because I thought they looked cool. I guess they keep rocks from chipping the paint around the wheel wells....maybe. I bought the VW guards from an online dealership. I think Kefflers (sp?) in North Carolina.
I paid a shop a few bucks to install mine since I didn't have ramps and it seemed like more trouble than it was worth to me. If you're used to working on your car, I don't think there's much to installing them.
rfortson is offline   Reply With Quote
Old February 1st, 2013, 12:49   #4
Dadskier
TDI(s): 2013 JSW 6M
No.
Got mine new with the car so can't address installing them.
Dadskier is offline   Reply With Quote
Old February 1st, 2013, 13:36   #5
Conrad -JSW
Conrad -JSW's Avatar
TDI(s): 2012 JSW DSG
Originally Posted by Dadskier View Post
No.
If you've had them since new, how would you know if they help with the rear window or not?
Conrad -JSW is offline   Reply With Quote
Old February 1st, 2013, 14:58   #6
BrShootr
TDI(s): MKVI JSW
The don't help with rear window dirt. The dirt on the rear window is due to turbulent air and is from dirt picked up with the air not sprayed up from the tires. It's due to the design of the car. Every bus, van, wagon and hatch has this problem due to the large area on the back of the car being relatively flat. The only OEM I've ever seen that cared about this was Subaru. They had a top spoiler that deflected air down, the airstream keeps the dirt off you window by maintaining a high speed airflow over it.
2013 Candy White JSW 6MT. Tinted windows, Classix 17" wheels. More mods to come....
BrShootr is offline   Reply With Quote
Old February 1st, 2013, 16:59   #7
pknopp
No
For splash gaurds they could be easier.
I had to trim mine a bit.
OEM. My car is lowered and I've scraped them many, many times and they are holding up great.
pknopp is offline   Reply With Quote
Old February 1st, 2013, 20:22   #8
Brent Wahl
Fuel Economy: 42 mpg freeway speeds
No idead about rear window
I have 2013 jsw with OEM front and rear mud guards.
Saw the oem install instruction and thought it showed taking the wheels off to install them. Dealer installed them for me
Brent Wahl is offline   Reply With Quote
Old February 2nd, 2013, 04:52   #9
schultp
schultp's Avatar
From past experience with other vehicles, taking the wheels off gives more room to use a drill-driver to fasten the splashguards with stainless self tapping screws. But, I am sure on some vehicles it is possible to do the job without removing the wheels.
Paul.
2010 JSW TDI, 6sp manual
schultp is offline   Reply With Quote
Old February 2nd, 2013, 09:34   #10
Dadskier
TDI(s): 2013 JSW 6M
Ha, well probably because I can't see out of the back if I don't use the washer and wiper frequently ....
Old February 2nd, 2013, 22:27   #11
jni3
jni3's Avatar
i got them for my wife's jsw. even if they don't help with the rear window it's a great product. helps save your paint from road debris.
2012 Jetta Sportwagen 4dr DSG TDI - wife
2012 Golf 2dr HB Man TDI w/ Tech Pkg - mine
jni3 is offline   Reply With Quote
Old February 4th, 2013, 08:57   #12
MertCheney
I would recommend the flaps to help keep debri off the lower body panels. The OEM's are the way to go but in VW fashion they are not as easy to install as they should be.
Mert Cheney
MertCheney is offline   Reply With Quote
Old February 6th, 2013, 03:35   #13
nhdude
I installed them on my 2011 JSW (VW OEM units) to keep salt, sand, etc. from blasting the lower body behind the wheel wells. They do seem to help in that regard. No effect on rear window as others have mentioned. Install was fairly easy... wheels need to come off.
nhdude is offline   Reply With Quote
Old February 6th, 2013, 09:55   #14
jasong70
I would install the fronts, but leave the rear off.
The rears seem to get pinched if you back up to a curb in reverse or drive off a curb. I have one that is nearly ripped off.
The fronts help with rocks. The rear are marginally helpful...
jasong70 is offline   Reply With Quote
Old February 6th, 2013, 10:10   #15
ValveCoverGasket
does anyone offer a flexible version? or has anyone installed something like the rally armor setup?
im not a fan of fixed mudflaps, as if they ever get hung up on something they typically cause damage to other components as they break/flex...
ValveCoverGasket is offline   Reply With Quote
Mud Flaps or Splash Guards for a TDI Cup Jetta Matty69 VW MKV-A5 Golf/Jettas 17 June 26th, 2011 03:50
FS: VW Jetta mk4 (99-04) Mud Flaps Splash Guards c0179999 Ontario 1 September 20th, 2010 05:31
Splash guards or mud flaps for 98 Jetta? blee83 General Automotive 1 January 13th, 2009 19:41
Splash Guards / Mud Flaps for A4 colezy9 Upgrades (non TDI Engine related) 12 February 7th, 2007 13:14
What will a Passat with splash guards/mud flaps look like? brownnugen Upgrades (non TDI Engine related) 5 August 13th, 2001 11:06
Page generated in 0.16602 seconds with 10 queries
[Output: 124.38 Kb. compressed to 103.70 Kb. by saving 20.68 Kb. (16.62%)]
