Digital Corpus
When pulling fueling info from VCDS in a log, it always has a range of 0 to 51 mg/str no matter if you car is stock or tuned; kinda like scaling a 4 bar sensor to the diagnostic limit in Group 11 for boost. Can this be converted to usable data, converting volume per stroke to volume per unit of time? The conversion is multi-step but simple, however the VCDS numbers are somewhat arbitrary according to many members on here.
Does anyone have helpful information we can coalesce in one spot regarding the flow data of each nozzle type we have on the market? We've had threads analyzing the flow performance between the nozzles, but only in relative terms and nothing is specific, abosolute units with tolerences. Also, nozzles are usually refered to as what is the horsepower they support so it kinda adds mud to the water.
I know we can use the voltage going to the pump to figure out where we lie on fuelling too, but I wouldn't expect the transfer function of that voltage to be linear with respect to the maximum flow rate of a nozzle.
Also, as a side note, does anyone have access to add to the following page, or make a sister page with the current, larger nozzles on the market?
http://pics2.tdiclub.com/gwillie/VW/nozzlesize/index.htm
We have flow maps for turbos, just not flow maps for nozzles
