Old January 29th, 2013, 09:09   #1
dewainc1
Default 2000 Jetta stopped running, won't start
Newbie here. I drove the car on the prior day after a 3 day cold snap. I was driving for about 20 minutes and felt the engine slowing as I neared a stop sign. It died. Glow plug light comes on, all lights come on, engine cranks but doesn't start. I had heavy smoke after starting since I bought the car in June of 2012, but thought it was normal because it is my first TDI. The check engine light is intermittent, and not predictable at all. It just comes on at random times. Any thoughts?
dewainc1 is offline   Reply With Quote
Old January 29th, 2013, 10:27   #2
Walley
Hey. Welcome! I was reluctant to post because I am also a noob, but screw it.
First how cold did it get? In Ohio we saw single digits last week, but now we are above 50F. Single digits shouldn't stop a TDI full of winterized fuel and/or some Power Service.
My guess is that your check engine light (CEL) and loss of power/no start are unrelated.
Do you run biodiesel?
Do you have a full tank of fuel?
Do you use an additive to prevent gelling?
Have you changed your fuel filter recently?
The intermittent CEL could be many things...Search the forum for someone local with VAG_COM who can scan your car and identify the code. May be a bad coolant temperature sensor, or a bad theromostat. If yes, change them both at the same time AND get those parts from the dealership (there have been some bad sensors being sold at parts stores).
These are cheap and easy fixes that a newb can do without even jacking up the car. There are plenty of posts on the forum and you tube videos that show how to do them.
Good Luck and have fun!
Walley is offline   Reply With Quote
Old January 29th, 2013, 17:04   #3
herkybird2001
Fuel Economy: 47/54
Mine did the same thing. Change the P109 relay below. Pull your lower valance under the steering wheel and tap the relay panel it probably will start. Lots of advice here about P109 relay just type P109.
herkybird2001 is offline   Reply With Quote
Old January 31st, 2013, 07:40   #4
Powder Hound
Powder Hound's Avatar
You have had heavy smoke after starting always?
You need to have the timing mechanically checked and corrected. Then you need to have it set via VCDS. Then scan for DTCs (stored error codes). They will show up even though the CEL is not currently illuminated.
Then check the glow plugs.
Checking these things should help the smoke after starts, even the very cold ones. What you describe does not sound like a relay 109 failure. It could be, but with a 109 failure you don't normally get all the dash lights going on as is in the usual startup procedure for the ECU.
Old February 2nd, 2013, 09:01   #5
dewainc1
Well, here's where I'm at. Had it towed to an "import" mechanic. After 4 days of the car sitting, he calls and says the following "What happened was someone broke off a glowplug. Then they jammed another one in that wasn't properly seated and it's a major fire hazard. We need to remove the cylinder head and take it to a machine shop. It will be about $1500.00."
Ok, that being said I have a few thoughts.
1. He broke the glow plug trying to replace it and can't get it out.
2. If the car started and ran for 7 months then just died, the one glow plug had nothing to do with it.
3. How am I going to fix this whole mess?
Old February 2nd, 2013, 10:12   #6
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
That doesn't make sense. I don't know how you would break a glow plug at the top and proceed to "jam another one in." You don't need to pull off the cylinder head just for that as long as you're careful about extracting the bad one.
This bears repeating - the root cause is probably timing and should be checked out along with pulling the fault memory with VCDS. The main power relay is also a possibility and can cause unexpected shutdowns.
In your position, your best option is to seek out Jason in Port Jervis - aka tdijetta99.
Yard sale - misc. mk4 TDI parts.
jcrews is offline   Reply With Quote
Old February 2nd, 2013, 11:02   #7
csstevej
Where in North N.J. Are you, im in Wantage by the high point monument.
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old February 2nd, 2013, 11:35   #8
dewainc1
I'm in Randolph. By County College of Morris, right off route 10
Old February 2nd, 2013, 15:58   #9
herkybird2001
Fuel Economy: 47/54
I would pick your car up and run away. I agree how the heck did you break a glow plug and shove another in.
Old February 2nd, 2013, 16:00   #10
csstevej
For what it's worth I've been running with only three GP's for 4 years or so, if it's not leaking leave it. I broke mine when removing it, and I'm not going to do anything till I have to remove the head. As Jcrews stated the timing is probably off.
Old February 4th, 2013, 08:42   #11
dewainc1
Here's where I'm at. I stopped into the mechanic this morning and after a brief discussion/argument, cooler heads prevailed. The girl who called me to tell me what was wrong gave me the wrong info. He showed me what was going on. Looking left to right at the engine, the 2nd glow plug is broken off at the cylinder head. The prior idiot just put a new glow plug in the harness and ran a jumper wire to a screw on top of the engine block to ground it. So when I start the car there is a dangling glow plug; bright red hot just behind the fuel pump and surrounding fuel lines. I remember seeing the top of the glow plug when I changed my oil filter but being so green, I thought it was normal. We agreed that timing may be the issue. When I was originally broken down, I forgot to look at the fuel lines. The clear line had no fuel in it. Diesel boogers? He is going to check the timing and get back to me. It's no wonder why the mechanic who I bought it from won't call me back.
B5.5V stopped running, won't start RI_TDI VW B5 Passat TDIs 42 February 14th, 2013 04:25
2000 jetta TDI starts but won't stay running yseent VW MKIV-A4 TDIs (VE and PD) 9 February 22nd, 2011 13:29
2000 Golf TDI just stopped running while driving. any tips? johnk VW MKIV-A4 TDIs (VE and PD) 8 December 18th, 2008 15:20
Jetta 2000 Won't Start WMCI TDI 101 10 January 29th, 2007 08:16
2000 jetta won't start rbslapshot VW MKIV-A4 TDIs (VE and PD) 1 August 10th, 2003 18:44
Page generated in 0.14143 seconds with 10 queries
[Output: 100.67 Kb. compressed to 85.35 Kb. by saving 15.32 Kb. (15.21%)]
