Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old January 29th, 2013, 07:57   #1
GotEuroCorrado
Default Romans ALH BEW and BRM parts thread
hello all,
"WILL TRADE CHEAP PARTS FOR BEER!"
its been years since i started working on tdi's for myself and family and ive collected a lot of parts from spares from wrecks and motors purchased to fix a car. i am moving within the next year so i m going through all my boxes to get rid of these parts.
this thread will change as things are no longer available and i take pics of other items. discounts when purchasing multiple items is available. items are preferably picked up in pa 19040 (not far outside of philadephia). shipping is extra and is calculated per customer and per order.
if prices are unreasonable, please pm me with a valid reason / example of lower prices and i will work to make the sale!
please feel free pm me with questions
unpictured items:
01m927733kt 01m 927 733 kt trans ecu $50
1c0959799c 1c0 959 799c comfort control module $25
alh parts:
INTAKE/EGR/VACUUM/INTERCOOLER COMPONENTS
alh intake manifold (cleaned by burning out soot) $60
alh egr/anti shutter valve (leaky) $10
alh egr/anti shutter vacuum pod $15
alh egr cooler $15
alh egr tube large $25
alh egr tube small $25
alh vacuum ball for golf/jetta $5
alh vacuum ball for beetle $5
alh vacuum pump $35
alh intercooler $50
alh turbo inlet pipe $15
alh turbo outlet hose sold
alh turbo outlet hose beetle/ early alh $30
alh small rubber hose connector for turbo to inlet pipe $5
alh large rubber hose connector for pancake pipe to intercooler and to upper intake pipe $5
alh 2.5 map sensor $15
items not pictured:
alh vacuum solenoid n18 $25
alh vacuum solenoid n75 $35
alh rubber intake elbow (anti shutter valve to upper intercooler tube) $35
alh lower intercooler line (pancake pipe) $15
COOLANT LINES:
items not pictured:
alh oil cooler coolant lines $8
INTERNAL ENGINE COMPONENTS
alh piston $40
alh rod 64 gram (4x) $45 per
alh rod 76 gram (3x) $45 per
FUEL SYSTEM
alh hard fuel lines $35
alh injection pump sprocket $25
alh injectors w/ manual tips and square plug 41k $250
alh injectors w/ auto tips and square plug 155k $175
alh injectors w/ manual tips and D shaped plug 108k $175 (possibly rebuilt?)
alh manual tips <100k (removed for upgraded tips) $30 a set
alh injector hold down brackets $20 a set
items not pictured:
manual 10mm injection pump 82k (no leaks) $450
manual 10mm injection pump 115k (no leaks) $375
manual 10mm injection pump 145k (no leaks) $350
manual 10mm injection pump 165k (no leaks) $350
maunal 10mm injection pump 135k (no leaks, good working pump but quantity adjuster removed to fix another car) $300
ENGINE TRIM/EXTERNAL PARTS
alh injection pump and accessory mount bracket $75
alh rear timing cover $35
alh front timing cover $20
alh / bew oil filter housing complete (cap, housing, cooler, sensor) $35
alh valve cover $35
alh valve cover breather $15
alh accessory belt tensioner no shock $25
alh accessory belt tensioner $55
alh engine mount bracket for alh and bew $45
alh upper metal timing belt cover $8
alh lower metal timing belt cover $8
alh harmonic balancer $10
alh rare 2003 harmonic balancer $10
alh turbo oil feed line $40
alh turbo oil drain line $40
alh oil filter housing assembly $35
alh dip stick $5
alh cam sprocket(may come with bolt) $25
alh crank sprocket (may come with bolt) $25
alh manual water outlet with glow plugs $25
alh manual water outlet w/o glow plugs $10
alh engine cover (no foam) $50
alh crank seal carrier (with new seal) $50
items not pictured:
alh transmission dust shield 5spd / manual includes larger and smaller covers $35
ENGINE ACCESSORIES
items not pictured:
alh / bew alternator 108k (d shaped plug) $75
alh / bew air conditioning compressor 108k $75
alh / bew power steering pump $50 ($65 with pulley)
SUSPENSION PARTS:
items not pictured:
alh / bew metal outer sway bar end links (compatible with plastic) $10
ACS TDI SPECIFIC MAINTENANCE AND REPAIR IN HATBORO PA (267)317-8229
$650+/- ALH/BEW/BRM/BHW/CBEA/CJAA TIMING BELT KIT INSTALLED NEAR PHILADELPHIA !
used parts FS: http://tinyurl.com/zfdjgyh
smoking deals on TIMING BELT KITS: http://tinyurl.com/ov57jfl
GotEuroCorrado is offline   Reply With Quote
Old January 29th, 2013, 07:57   #2
GotEuroCorrado
1. 038 906 012 cp (2000-2001?) sold
2. 038 906 012 bd (2001-2001?) $100
3. 06a 906 032 cp (2002-2003?) 2.0 GAS ENGINE $60
bew parts
heads DO NOT have cam kits OR INJECTORS in them! i can install for additional cost. please pm me for pricing.
1. brm/bhw cylinder head with 68k (new valve guides and seals) sold
2. bew cylinder head with 102k (new valve guides and seals) sold
3. bew cylinder head with 145k (new valve guides and seals) sold
4. cam sprocket $25 ($35 with cam hub which is not pictured)
5. oil feed line $45
6. automatic water outlet $35
7. knock sensor $20
8. SOLD
items not pictured:
bew cam sensor $25
items not pictured:
bew turbo oil drain line $35
bew egr cooler with upper tube $25
bew intake manifold upper and lower $100
bew turbo inlet pipe with heater element $25
bew egr valve $45
1. harmonic balancer with bolt cover for manual $25
2. upper timing belt cover $25
3. rear timing belt cover $35
4. accessory bracket $35
5. luk fuel pump 62k $125
6. metal fuel line with rubber lines and vacuum canister with line $35
7. SOLD
8. metal upper timing belt cover $10
9. metal lower timing belt cover $15
brm parts
item not pictured:
brm egr valve $50
brm anti shutter valve / intake flapper $75
brm egr cooler (working and not leaking) $75
Brake parts
MK4:
tdi/2.0
dr side knuckles bare with $70
pass side knuckles bare $70
front calipers $40 a set ($25 each)
rear calipers with carriers $60 a side
Old January 29th, 2013, 07:58   #3
GotEuroCorrado
Interior items
grey headrests each $10
door cards (no driver) NO SAG!!!!!!NO SAG!!! NO SAG!!! $20 each
shipping extra for all, but can meet up locally
no other grey parts, so please dont ask!
Old January 29th, 2013, 07:58   #4
GotEuroCorrado
this one is mine as well
Old January 29th, 2013, 07:59   #5
GotEuroCorrado
i may need this as well
Old May 10th, 2013, 03:39   #6
hrjack99
I need the BEW egr valve.
2011 Jetta TDI
hrjack99 is offline   Reply With Quote
Old May 15th, 2013, 06:03   #7
jhuroleye
I need the bew egr valve as well!!! lol.. and i'm coming to philly this weekend! so I could pick it up!!
jhuroleye is offline   Reply With Quote
Old May 18th, 2013, 19:30   #8
H2O2H
TDI(s): ALH
How much for the front pass handle and rear drivers side door panel (only really need the area where the tweeter and window button are).
Any chance you have a red drivers side mirror?
H2O2H is offline   Reply With Quote
Old September 29th, 2013, 19:04   #9
mutzie
TDI(s): 2006 TDI GLS
Default Interested in some of your parts
Hi Roman,
#3 and #4
Intake manifold upper and lower, will fit a 2006 TDI BEW? In What condition is this part ?
EGR cooler w/ upper tube, will fit a 2006 TDI BEW ? In what condition is this part?
I have pay pal.
Can you ship to south Florida?
mutzie is offline   Reply With Quote
Old August 30th, 2014, 11:15   #10
drywaller
TDI(s): VDUBS
Have you got a cam sensor for a bew engine?
drywaller is offline   Reply With Quote
Old September 21st, 2014, 12:03   #11
2004STARWARSTDI
2004STARWARSTDI's Avatar
Great Vendor! Been looking for a rear windowshade for MKIV Jetta and he had the last one in the world! It was brand new!! Can't go wrong with GotEuroCorrado!!
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2020
A4 Limp Mode,A4 tech.com/index.php/Category:Fault_Codes"]Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old March 20th, 2015, 08:27   #12
GOT SMOKE
Looking for a ALH #3 injector PM sent
GOT SMOKE is offline   Reply With Quote
Old March 20th, 2015, 08:55   #13
Lex4TDI4Life
Lex4TDI4Life's Avatar
Let me know if you get your hands on a relatively clean, no cracks, reflex silver MKIV Golf/GIT front bumper.
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is offline   Reply With Quote
Old March 20th, 2015, 09:48   #14
GotEuroCorrado
not panels, sorry. and im just trying to get rid of what i have. not going to acquire more (i hope)
Old March 24th, 2015, 14:33   #15
pricha00
I am needing a turbo actuator for the KP39 on my BEW.... do you have a good one and how much to 14304.
Pat
pricha00 is offline   Reply With Quote
BEW, BRM, and ALH head gaskets oldpoopie TDI Power Enhancements 31 November 25th, 2017 19:07
TDI ALH BEW BRM Parts Precisiontuning Vendor & GroupBuy items for sale 0 December 14th, 2012 11:43
ALH vs. BEW vs. BRM sk8rdi16 TDI 101 36 August 24th, 2012 11:45
Wanted ALH/BRM/BEW Crank...99.5mm storx Private TDI Items for Sale/Wanted 1 February 14th, 2009 12:30
brm vs bew vs alh detoxed TDI 101 2 April 19th, 2007 19:52
Page generated in 0.16023 seconds with 10 queries
[Output: 130.71 Kb. compressed to 109.44 Kb. by saving 21.27 Kb. (16.27%)]
