Old January 26th, 2013, 12:11   #1
@Tdi VW
Default Thermostat...OEM Vs Aftermarket
Im about to change the thermostat on my B5 PD.
Should i get an OEM one or Aftermarket are ok too.
@Tdi VW is offline   Reply With Quote
Old January 26th, 2013, 15:05   #2
thundershorts
oem only as per oilhammer
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old January 26th, 2013, 15:18   #3
@Tdi VW
sorry but i didnt get that
Old January 26th, 2013, 15:28   #4
Volkstraktor
TDI(s): 2005 Passat
Oilhammer is kinda THE go-to guru. He works on LOTS of these and drives one, too.
2005 Passat GLS - Artic Blue - 35% Tint - Grey Leatherette w/ OEM Brushed Interior Trim -
Fast Valve-stem Caps - Geared & 'Gatored by FixUmHaus 10/10/10
Volkstraktor is offline   Reply With Quote
Old January 26th, 2013, 15:49   #5
@Tdi VW
So original Vw one is the right choice
Old January 26th, 2013, 16:36   #6
Dieselducky
Dieselducky's Avatar
YEs go with the one from the dealer...i have used 5 aftermarket ones....they never seem to let the engine run at optimum temp..I have one from the dealer now...worth every penny
Dieselducky is offline   Reply With Quote
Old January 26th, 2013, 16:40   #7
@Tdi VW
Old January 30th, 2013, 12:17   #8
Dr. Greenthumb
I just installed one from Carquest (Carquest brand - not one they brought in from World Pac) and it is working fine. It was made in France.
Dr. Greenthumb is offline   Reply With Quote
Old January 30th, 2013, 12:29   #9
Dieselducky
I bought a few of those....they are the exact reason i went back to the dealer to buy one..I got sick of changing them every year due to slow warm-up/failing to maintain temperature.average temp with a aftermarket one in my car....75-83C...Now with the dealer supplied one i maintain 87-93C even on the coldest days.
Old January 30th, 2013, 12:29   #10
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
If you can find one, Behr is who makes them for this application. Not Wahler (although VR6 stats are indeed made by Wahler).
I use the OEM ones from Volkswagen exclusively though.
oilhammer
www.cardocautomotive.com
Old January 30th, 2013, 15:36   #11
Dr. Greenthumb
Did they ever maintain temp or was it right from the start? It was 10F today and it took less than 5 minutes to get up to temp. Temp held w/o no problem.
Old February 1st, 2013, 13:11   #12
@Tdi VW
I Can have a Behr one for 10 $
Old February 2nd, 2013, 18:58   #13
T_D_I_POWER
T_D_I_POWER's Avatar
Yes. The one that you buy at the dealer it's known as the OE part. OEM for the thermostat parts are Wahler, Behr etc. who design & manufacture thermostat parts for VAG OE parts
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
2.0 pistons: Aftermarket vs OEM Scufi TDI Power Enhancements 4 May 7th, 2011 05:47
Hoodliner New OEM or Aftermarket??? navyboy65 TDI 101 16 January 25th, 2010 14:05
FS: OEM thermostat and thermo housing Revolutionary_mind Private TDI Items for Sale/Wanted 2 March 11th, 2009 16:28
Is the Best Antenna an OEM or aftermarket? greenjetta Upgrades (non TDI Engine related) 3 April 10th, 2007 19:22
Aftermarket oem egr???? Mike Piles VW MKIV-A4 TDIs (VE and PD) 0 July 30th, 2003 20:11
Page generated in 0.15854 seconds with 10 queries
[Output: 113.01 Kb. compressed to 94.38 Kb. by saving 18.64 Kb. (16.49%)]
