Old January 23rd, 2013, 16:23   #1
Walley
Fuel Economy: Good enough
Default hard start/no start. air in fuel lines. whereto look next?
I am pulling my hair out and am hoping one of you smart folks can tell me where to look next. I had been having some hard start/no start issues in my 03 Wagon, but only in the cold weather. Here is the whole sequence of repairs and issues in the hopes that one you can help me connect the dots.
-Leaky IP in Sept 2012. I replaced the seals and did hammer mod with my friends Vag-Com to set the quantity at about 3.8 (background info).
-October 2012, CEL and P0128. I replaced the CTS with one from Advance Auto.
-November-December 2012, Intermittent CEL and P0128. Hard starting after cold (30F) nights. Replaced the CTS with one from the dealer and also replaced the thermostat. Checked glow plugs with a multi-meter and removed them to check them using a battery. All were fine. Harness was fine also.
-early January 2013. Still hard starting when cold. Noticed air in fuel line from my filter to the IP. Got a new fuel filter, good o-rings, and a new t-valve from the dealer and replaced all the old stuff. Also replaced the original line clamps with some worm gear clamps.
-Monday. Temperatures below 15F. Hard starting in the cold and hard starting after partial warm-up. Still a lot of and bubbles and air in the fuel line going to the IP.
-Today. Hooked up a bottle with fuel to the IP similar to a diesel purge and ran the car till only a few tiny bubbles remained. I assume this will tell me if the air is getting in on the IP side of my filter. (I don't think this is the problem, but I thought I should check).
If my air leak isn't at the IP, then where should I look next?
Could there be something else that I am missing?
Thanks in advance.
Walley is offline   Reply With Quote
Old January 23rd, 2013, 16:57   #2
csstevej
Id still Check the Mickey mouse fitting on the fuel filter, common area for air intrusion. Cover the area with Vaseline and see if air stops.
When you did the IP, did you do it on the car or did you remove it?
Just for peace of mind check your staic and dynamic timing, might be off ( retarded ).
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old January 23rd, 2013, 17:21   #3
Walley
I greased up the o-rings before putting in the NEW t-valve, but I guess I could slather more on there and see what happens. Anything between the tank and filter that would cause the car to suck air when cold?
The IP stayed on the car when I replaced the seal for the quantity adjuster, the seal for the cap over the fuel temp sensor, and the large o-ring on the side. No visible leaks now. I am going to go back out and check tonight (still have the bottle hooked up), if no hard start or air bubbles then I assume everything is fine on that end.
I'll need to drive over and see my buddy with VAG-COM to check the timing.
Old January 23rd, 2013, 17:26   #4
csstevej
Can't think of anything between filter and tank that would cause air intrusion other than the fuel sending unit.
Out of courisity , how much fuel is in your tank?
Old January 23rd, 2013, 18:18   #5
Walley
About a half tank right now.
Just wondering how/why would the sending unit would cause air intrusion when cold? I have heard they have a one way valve that can go bad, or get clogged. But the car will hard start even after a partial warm-up (5-10 minutes of city driving) then sitting for 5 minutes. I was thinking of replacing it a couple of weeks back, but am reluctant.
Update. The car sat in an unheated garage at 15F for 3hours (American hours). Started just fine with the bottle set-up.
Old January 23rd, 2013, 18:42   #6
csstevej
I definitely would check the timing. Are you getting a large bubble of air or just streams of small bubbles?
Old January 23rd, 2013, 19:33   #7
Walley
Its pretty much a constant stream of lentil-sized bubbles. I'll add that I greased up the t-valve after reconnecting the lines to the filter, then drove around for 15min (five on the highway) and still had a lot of bubbles. I'll check again for a hard start in the morning and call my friend with VAG-COM to check my timing.
Old January 23rd, 2013, 20:07   #8
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
Are your fuel lines showing some dry rot? Are you running any bio?
2K jetta gl tdi 5spd 407k, RC5+, 17/22, R520's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Old January 24th, 2013, 06:28   #9
Walley
The "rubber" lines running from the filter back to the firewall (where they connect to the hard plastic lines) look old, but not rotten. I was considering changing these out next.
In the past I ran bio 90% of the time. I usually ran B90 in the summer and anywhere from B10 to B50 in the winter. I moved away from my bio source 2-years ago and have been running on dino-d (with Power Service) about 90% of the time ever since. Hence the reason for the leaky IP seals that I fixed back in September. You just reminded me that I did run a single tank of B80 back in October. I guess there is a chance that it could have picked up a diesel booger and clogged my sending unit, but my vac pressure looks good and the problem is air...not a lack of fuel.
Old January 24th, 2013, 10:25   #10
Walley
Been thinking about this at work today so I'll respond to my own thread.
Here is a newb question.....if the car starts fine in the cold when I have a Gatorade bottle of fuel connected directly to the IP, then how would my issues be related to timing?
Old January 24th, 2013, 12:29   #11
alphaseinor
how about that piston coming out of the fuel valve on the IP?
alphaseinor is offline   Reply With Quote
Old January 24th, 2013, 12:31   #12
lizbiz
TDI(s): 1998 Jetta
Fuel Economy: 48-52 MPG
Default posting
I know this probably isn't the place to do this, but I always have trouble find the button that says post a new thread or post. right now all I can find anywhere is post reply. can anyone tell me how to start to get to a new post when I first log in
lizbiz is offline   Reply With Quote
Old January 24th, 2013, 13:28   #13
Walley
I think you go back to the main page for the "discussion area" where you want to post. Look in the almost upper right corner under the page number and click on the drop down menu for "thread tools". I had a tough time finding it also. probably placed there so newbs like me would read a bunch of posts to find our answer before posting too many redundant questions.
Old January 24th, 2013, 13:29   #14
Walley
Please explain.
Could this happen without first tampering with the IP?
Old January 24th, 2013, 16:28   #15
sisyphus
sisyphus's Avatar
Timing. Check your timing. My car wouldn't start/hard start in the low 20's. Advanced timing with board member Abacus to 65/100, started the other day at like -8, ran like a champ.
sisyphus is offline   Reply With Quote
95 Golf TD wont start (Air in fuel lines) GTIDamien_407 Other VW Group TD(I)s 7 January 23rd, 2012 07:22
98 TDI hard to start/air in lines theoriginalgerhard VW MKIII-A3/B4 TDIs 3 February 8th, 2011 15:24
VERY Hard to start/Still Air in Lines (ON MY LAST STRAW) bigwoode TDI 101 9 March 29th, 2009 11:02
No start / air in fuel lines ssg TDI 101 13 November 25th, 2007 07:56
Need help badly, air in fuel line, hard start... 2TDIguy Fuels & Lubricants 13 December 26th, 2005 16:39
Page generated in 0.17777 seconds with 10 queries
[Output: 128.13 Kb. compressed to 107.06 Kb. by saving 21.07 Kb. (16.45%)]
