Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old January 22nd, 2013, 10:33   #1
chargersrt10
Fuel Economy: 45-50ish MPG
Exclamation WANT!!! Drivers Front Heated Seat
I'm looking for a Drivers Front Heated Seat(Black Cloth(Mouse fur) for my 2000 Jetta TDI. If anyone in the GTA can help me locate a seat I'd be much obliged. Thanks Cheers. Chargersr10
chargersrt10 is offline   Reply With Quote
Old January 22nd, 2013, 10:38   #2
MoldovaDIZEL
MoldovaDIZEL's Avatar
Fuel Economy: whats that?
I have a black leather one, 50$.
2017 ALLTRACK,470k,OMI,STG 5,R520,11mm, 2.5dp,2+ SB,VR6 axels,Euro 5 speed,e-codes, ST Coils, skid plate 17" CR7s.
98 Cabrio TD Swap,Jetta Front, Green Magic
Humberview Volkswagen Sales Manager
MoldovaDIZEL is offline   Reply With Quote
Old January 22nd, 2013, 10:39   #3
Johhny04
Check The Source. Call Mike.
2003 Jetta TDi skid plate, GLI suspension, VR6 brakes, Fat 5 TT rims
2002 Ford E350 7.3L Powerstroke. Weekend workhorse that pulls like a freight train!....sold
2004 Jetta TDI ..... sold
Johhny04 is offline   Reply With Quote
Old January 22nd, 2013, 10:47   #4
chargersrt10
@Johhny04 Thanks for the tip. I will ask him as I'm going there on Saturday.
@MoldovaDIZEL Just got off the phone with a good friend who works at Volkswagen. I'm told the Heated seat Control Modules are different and wouldn't allow me to use a leather seat. None the less Thank you for the offer.
Old January 22nd, 2013, 11:39   #5
P2B
P2B's Avatar
I don't believe that. I have switched seat controls from leather to cloth and vice versa, no issues.
Simon
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is online now   Reply With Quote
Old January 22nd, 2013, 11:47   #6
Purch
Purch's Avatar
It's the year of the car that makes the difference, not the material. The earlier mk4 models had a different connector for the heated seats than the later models. I just don't remember if they changed in 2000 or 2001....
-2013 Golf TDI 6-Speed - Malone Stage 2, S3 Short Shifter, HID Projectors, Factory Tint, SG2, LEDS Everywhere
Purch is offline   Reply With Quote
Old January 22nd, 2013, 11:49   #7
david_594
david_594's Avatar
Fuel Economy: 51.7/48.2/40.7
The switches are different for cloth and leather, but its only a minor detail in how hot it will let the seats get for a given settings. So if you mix and match it's possible that your seats might run a bit hotter or cooler than intended. Not likely to be something you'd notice though.
There was a switch recall years ago that went to a cooler temp switch to avoid lighting peoples pants on fire.
david_594 is offline   Reply With Quote
Old January 22nd, 2013, 12:12   #8
chargersrt10
I know about the recall. I was denied it because apparently my car was not part of that recall. Stupid dealers.............
Old January 22nd, 2013, 12:32   #9
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
The only issue with swapping seats is the air bag connector. They changed for the 2002 model year. So you would need a seat from a 2000 or early 2001 if you want it to be plug & play. Otherwise, you would have to cut & splice connectors. The heater plug harness did not change.
Moving? Need boxes?
Go green and check out FROGBOX.com
Old Ride (2000 Black Sedan): Gone
New Ride: (2003 Silver Wagon): Malone Tuned, T4 injectors, 11mm pump, 2.5" Magnaflow cat back, PD150 intake, OMI, Wingnut SS, ERF 6 speed, Bilstein TC Sport susp. w/GTI springs, Neuspeed RSB, Santa Monica's, Autometer Cobalt Boost & EGT, MFA Sport cluster, GLI Leather seats, SS vacuum lines, AVIC Z3 Nav and I still get 4.5L/100km (I got 3.9L/100k on a tank once)
Some handy 'How to's'
Wingnut is offline   Reply With Quote
Old January 22nd, 2013, 12:53   #10
Purch
Purch's Avatar
I knew it was a connector that was the issue, I was just wrong on which one!
Old January 22nd, 2013, 12:53   #11
chargersrt10
Thanks for the tip @Wingnut. I'm going to take a pic of the connectors on my car before I do anything
Old January 22nd, 2013, 13:17   #12
Wingnut
Wingnut's Avatar
The air bag is the yellow connector. The heated seat is green.
Moving? Need boxes?
Old January 22nd, 2013, 20:39   #13
mecne
mecne's Avatar
TDI(s): 15 Jetta TDI
Like this ..
My wife sent me this pic today after lunch .. said her leg was getting way to warm .. so she shut off the switch .. took this when she got home and out of the car ..
Was in the same sitch as the OP .. just got the Golf and heated seat had no heat .. found a used pair or seats .. no idea what year they were out of ..
So now I have the original seat in the basement waiting to be pulled apart and fixed . and guess who gets to drive the Golf again ..
Is there a way to tell what switch you have? Pre Recall or Post ? part number difference?
M
15 Jetta TDI
10 MB ML350 Bluetec
mecne is offline   Reply With Quote
Old January 22nd, 2013, 21:19   #14
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Most VW connectors come apart. You can release the pins with the proper tool (Which I have) and swap them into the other connector. I have never looked at the airbag ones up close, but I assume they would be the same.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old January 23rd, 2013, 00:01   #15
Wingnut
Wingnut's Avatar
Been there, done that. The pins are different. No way to swap the connectors. If someone is really anal, you can remove the pins from the connector, then remove the pins from the wires and re-crimp them on the old wires. But those are small crimps and pretty delicate work. Much easier to just cut & splice.
Moving? Need boxes?
Wanted: MK IV front end pieces, black drivers seat. Portland, OR hartung Private TDI Items for Sale/Wanted 0 October 18th, 2011 16:55
Heated drivers seat ??? Graphic Man Ontario 6 October 9th, 2008 02:24
WTB 02 0r 03 JETTA BLACK HEATED LEATHER MANUAL PASSENGER FRONT SEAT thebigarniedog Private TDI Items for Sale/Wanted 0 November 5th, 2007 03:02
2005 Passat (Front drivers seat is falling apart) deming VW B5 Passat TDIs 7 September 13th, 2004 23:12
WTB Drivers Front seat cover (lower) for '03 golf tdibeliever Private TDI Items for Sale/Wanted 2 May 9th, 2003 12:33
Page generated in 0.19556 seconds with 10 queries
[Output: 132.62 Kb. compressed to 110.48 Kb. by saving 22.14 Kb. (16.69%)]
