Old January 21st, 2013, 08:58   #1
ken w
Default How long did your clutch last??????
We are replacing our clutch for the first time. 2001 Golf TDI 5sp with 679,000km. It still works but is getting a little noisey.
ken w is offline   Reply With Quote
Old January 21st, 2013, 10:17   #2
jtnf
jtnf's Avatar
Fuel Economy: 40+ on the B7
679,000*0.6=407,400 miles...
I'd call that a good run! Almost double my 210,800ish miles (clutch still fine by the by.)
jtnf is offline   Reply With Quote
Old January 21st, 2013, 10:53   #3
muzy
TDI(s): 02 jetta TDI
Fuel Economy: in process
560 000km , the release bearing gave up. Although it had to be cut out with an angle grinder the wear surfaces did not look bad at all . Think there were three previous owners. Glen
muzy is offline   Reply With Quote
Old January 21st, 2013, 13:02   #4
MeOmYo
2001 Golf, 230,000 miles throwout bearing fell apart and 2 teeth on pressure plate were missing. wear surfaces were still good.
'01 Golf GLS, 5-speed, monsoon, sunroof, ventectomy
'03 Jetta Wagon, 5-speed, ventectomy
MeOmYo is offline   Reply With Quote
Old January 21st, 2013, 13:11   #5
yakfish
I had a '98 jetta with 325,000 miles before it started to slip. I replaced the clutch on my current 06 jetta wagon at 188,000 kms due to a failed throwout bearing the clutch itself was still good but replaced it anyway since everything was apart. May not be relevant here but I also had a '04 VR6 GLI with 225,000 miles when I replaced the clutch on it last year. Master and slave cylinders needed replaced and did the clutch at the same time It was still in descent shape too.
yakfish is offline   Reply With Quote
Old January 21st, 2013, 13:53   #6
POWERSTROKE
POWERSTROKE's Avatar
TDI(s): 2002 Golf
125k in constant ny traffic. Stuck in jams every night. Throwout went bad. Clutch looked good.
It's kind of fun to do the impossible.-Walt Disney
POWERSTROKE is offline   Reply With Quote
Old January 21st, 2013, 14:16   #7
craig01b
craig01b's Avatar
TDI(s): None
465,000 kms still fine..
All retired, bought a Subaru.... all wheel drive, and a little bigger than the high line. Time will tell!
craig01b is offline   Reply With Quote
Old January 21st, 2013, 14:21   #8
Curious Chris
Fuel Economy: 47/42/38
Oh my first one slipped with chip and larger injectors at 80,000 miles, the Spec clutch on the OEM DMF lasted to 200,000 miles, now I have a South Bend Endurance on a solid steel flywheel.
Yes if you drive mainly long stretches the clutch will be happy. If you crank up the power like I did you learn to expect to have to replace clutches.
Wavetrac LSD, Bosch 230'a with RC4.5, Whitbread 2.5" downpipe, PD lift pump, South Bend Stage 2 Endurance Clutch, steel skid plate, Wingnut inspired EGR mod, MyCruiseAgent no drill EGT, MoGolf skidplate mod
Curious Chris is offline   Reply With Quote
Old January 22nd, 2013, 22:46   #9
JettaTdiSport
JettaTdiSport's Avatar
Fuel Economy: currently calculating
I'm at 130K km and the friction point is starting to move up. Plus it's been stuttering when cold, every winter. I've had the car for 6 years and I've put most of the mileage on it.
JettaTdiSport is offline   Reply With Quote
Old January 23rd, 2013, 00:23   #10
Crankous
Crankous's Avatar
Our 03 is Still going 192k miles. I have a clutch/flywheel/pp on the shelf here waiting.... the DMF is starting to make a little noise but clutch still functions great. With resonable driving it doesnt seem like the clutches are the point of failure from what I have seen. Thats of the ones Ive had apart. ...407k is quite the run for sure.
Crankous is offline   Reply With Quote
Old January 28th, 2013, 05:38   #11
philsbug
philsbug's Avatar
Fuel Economy: 590 / tank
452, 000 miles and still strong.
philsbug is offline   Reply With Quote
Old January 28th, 2013, 07:30   #12
Richy_T
Richy_T's Avatar
TDI(s): 2000 Jetta
Replaced the clutch at somewhere around 120k miles, 30k after I bought the car. Went over to the single mass flywheel. Hoping it will last a while, I don't hit much traffic but I am a bit rough on the clutch sometimes.
Richy_T is offline   Reply With Quote
Old January 28th, 2013, 13:45   #13
white95v6
Man you guys have a lot of miles on those clutches crazy.
My wagon had 170k on it when I bought it I assume stock clutch. I installed a tune about 40k ago and my clutch has started to slip. Put stock tune back in and no slip maybe I can make it last alittle while longer. I do tow a john boat with this car. She now has 235k on it.
My sedan had 80k on it when I got it again I assume stock clutch. I installed a tune about 16 k ago and its clutch started to slip. Had to return it back to stock and no more clutch slip. Now with 185k on her.
Guess I got two stage 2 clutches are in my future lol.
race car= 9sec v6 mustang with 76mm turbo
2003 5spd jetta jw tdi gls
2000 5spd jetta tdi
white95v6 is offline   Reply With Quote
Old January 28th, 2013, 16:48   #14
Richy_T
Richy_T's Avatar
TDI(s): 2000 Jetta
Careful there. My clutch was just starting to slip then I lent it to my wife for a few days. Long story short, when I pulled the transmission, there was 0 clutch material left.
So basically, don't lend your car to my wife.
Seriously, I mean, it can be surprising how quickly they can go.
Old January 28th, 2013, 17:15   #15
Seatman
Seatman's Avatar
Fuel Economy: No idea
Lol my car came with a very recent clutch but it's not handling the power so I've kinda killed it with a few thousand miles
The new uprated one is sitting beside me though
Seatman is offline   Reply With Quote
How long does an alternator overrunning clutch last? tgray TDI 101 10 February 20th, 2012 09:21
How long can the clutch survive?? tysingleton34 TDI Power Enhancements 23 October 14th, 2009 09:43
How long does a clutch last? Brandon7 TDI 101 8 May 27th, 2008 10:28
Clutch...How Long will it Last, Place your bets! dzlchef VW MKIV-A4 TDIs (VE and PD) 5 September 1st, 2004 12:40
(POLL) How long for a clutch change? lam121 VW MKIV-A4 TDIs (VE and PD) 0 April 4th, 2004 15:04
Page generated in 0.15129 seconds with 10 queries
[Output: 122.63 Kb. compressed to 101.62 Kb. by saving 21.01 Kb. (17.13%)]
