Old January 16th, 2013, 05:40   #1
cobra390t
cobra390t's Avatar
Default FOB Programming Instructions
Hello ...
I been searching for a way to program my spare Keyless entry fob to sync and came across this write up , Figured to share
VW Volkswagen keyless entry flip key remote users guide
VW sidewinder flip key application 1998 to 2009
Volkswagen does not have a comprehensive application guide or chart. Nor is their part application of these remotes complete or specific.
Short version:
1998-1999 New Beetle: any HAA key works, 3 button remote = 1J0959753F and 1J0959753T, no immobilizer system
1998 to 2001 Passat: any HAA Key works, 3 button remote 1J0959753F (E = wagon) and 1J0959753T (S = wagon), no immobilizer system
1999 1/2 Golf & Jetta: any HAA key works, 3 button remote = 1J0959753F and 1J0959753T. no immobilizer system
2000 to 2001 Golf & Jetta: any HAA key with rfid chip works, 3 button remote = 1J0959753F and 1J0959753T. yes, immobilizer system
2002 to 2005 New Beetle, Passat, Golf, Jetta: any HAA key with rfid chip works, remote= 1J0959753AM or DC . yes, immobilizer system
2005.5 to 2007 Golf, Jetta; newer HAA key 1T0, remote= 1K0959753H, yes, immobilizer system
2005.5 to 2010 New Beetle; newer HAA key 1T0, remote= 1J0959753AM or DC, yes, immobilizer system
Volkswagens security key system is like the old bug with the cart in front of the horse, you program the car to the key, not the key to the car.
2008 and 2009 are VW dealer only keys, cars are too new, keys have different frequencies and chips than the older cars.
Programing the button REMOTE portion of the key is simple.
You do need 2 keys. You must be able to lock the drivers door and have the red led alarm light next to the lock button blink. If it does not blink, the alarm does not know the door is closed and will not go into program mode. Put one key in the ignition switch, turn on, do not start engine. Close the door, use 2nd key, turn door lock and hold in lock position for 10 seconds. Release key to neutral position. Press a button on the remote, within 2 seconds press the same button again, the turn signal lights will flash,
this indicates your remote matches the car system and is now recognized. Unlock door remove key from ignition.
So don't pay extra 99 cents to $5 for these instructions in hopes of getting the KEY to function with the car.
Instructions are only for the keyless remote, not the key.
The HAA keys are cut by using your serial number to the car (vin dependent) There is a 4 digit key code, unless you are the original owner or you have the black zip tie tag that was attached to the black valet key, you will not have the key code. We use an image of the key cut to verify the code to be cut.
Applications contained here-in are for the Volkswagens in North America. Volkswagen has 7 markets worldwide. Due to frequency licensing in different countries the remotes will have other part numbers similar to USA. Example, the oval 2 button E and the 3 button F in Europe are G and H. Asia uses A and B. They are not interchangeable between countries.
Starting in 1998 with the New Beetle 98-99 and Passat 1998 to 2001.5 (01 Passat serial number 49999 or less), with the Golf IV and Jetta IV 1999.5, the key does not have a computer chip, and does not need the engine computer programed to recognize it. The remote has the oval button HLO 1J0 959 753 F . The remote does not have the chrome bar on the end, only the corner loop to attach to a key ring. This remote will not work with 2002 and newer Volkswagens.
Now available is this vintage look key for the cars without the immobilizer systems or to use as a hide-a-key or emergency key to gain entry to the car if you locked your other keys inside.
Original 1J0959753F application 08/97 to 05/99 do not have transponder computer chip for 06/99 to 05/01 and newer Volkswagens that require one. 1998 and early 1999 cars had banjo Hella remotes. The F and T flip key 3 button remotes ( E and S are 2 button for the wagon) will work with these cars. Replacement 1J0959753F (and E) all have transponder chips. See date codes marked after the part number on the button remote portion of the key. 34/98 = week 34 of 1998
If you have the oval button remote and the batteries keep going dead or with new batteries it won't work. The button gets distorted and keeps the switch under the button pressed, killing the battery. This also prevents it from being programmed. You may have to match the remote to the car if the batteries have been dead too long.
Some models, the transition date is different, look for the yellow car with the key under it when you turn the ignition on.
(second light from the left) Will not do Cabrio, Eurovan or 2005.5 up cars.
key tag that came with the valet / mechanics key.
1J0959753T ( S is the 2 button) original application 10/00 to 05/01 but will work from 08/97 (new beetle) 1999.5 to 05/01 Golf, Jetta, Passat (original may look like F with oval button) Only 1 out of 3 oval button remotes have the transponder chip because only 1 out of 3 are the T version. Even with the chip, a used flip key head cannot be made to start the immobilizer cars unless the chip is new. The chip is a one time use device. Once matched to a car, it belongs to that car.
1J0959753AM original application 06/2001 to 2005 New Beetle, Golf, Jetta, Passat but will not work on 05/2001 and older cars. Note: AM and DC will work with Eurovan 2001-2004 and will need to be recognized by engine computer.
In 2000 model year (around May 1999) the transition takes place with immobilizer 2, (immo II) the addition of a writable computer chip inside the key portion of the flip key. 2001 is a transition year. The remote changes to the squared buttons but the frequency of the button remote is the same as the older Volkswagens with the oval buttons. This remote will work on the older cars but not the newer cars. HLO 1J0 959 753 T (wagon 2 button is S) It can be programmed to the engine computer but not to the keyless entry of 2002 (May 2001) and newer Volkswagens. It has the newer look with the chrome bar on the end.
Starting late in 2001(June) to 2005 the squared button remote has a more common part number HLO 1J0 959 753 AM (replaced by 1J0959753DC). This remote has a different frequency matched only to Golf IV Jetta IV Passat and New Beetle. It has the chrome bar and a computer chip. You can buy the Vagtacho software from me and do it with your laptop or you will need a VW dealer or Automotive Locksmith to program the engine computer to recognize the key. After the key is cut, it will work in the locks, start the engine, but the engine will shut off as a theft prevention if the engine computer has not been programed to recognize it. This key will work in 2000 and older Volkswagens but the 3 button remote will not. It has a different frequency. Works with Eurovan 2001-2004. This key also works on 2006 TDI Jetta (December 2005) since the diesel production was ending they installed the older keyless systems. Check your remote to match part number.
cobra390t is offline   Reply With Quote
Old January 16th, 2013, 05:47   #2
cobra390t
cobra390t's Avatar
Please Note that i attempted above manual programing section for my 2006 using one key in the ignition and one in the door lock and no Luck what so ever, I also tried to use VAG-com adaptation procedure i see the turn signal flash to confirm the programing was success , However the spar key fob keyless entry will not operate the lock/unlock , trunk or panic function however the key it self will start the car .... ANY Ideas
I used the same steps shown in this helpful video < Turn signal flashed But fob still will not function >
http://www.youtube.com/watch?v=jdakPlMnDr4
Old January 16th, 2013, 08:13   #3
JSWTDI09
JSWTDI09's Avatar
Any ideas?
Just one. There seems to be a limited number of remotes that can be programmed. This number seems to vary with the year of the car. Since your car starts with the key, the immobilizer is good. It is only the remote locking that is giving you trouble. I have had better luck in programming remote functions by first deleting all the remotes (set number of remotes to "0"), and then programming all of the remotes at the same time. This usually works better than trying to add a new remote without deleting the old ones. No guarantees, but this is worth a try.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old January 16th, 2013, 10:44   #4
cobra390t
cobra390t's Avatar
Originally Posted by JSWTDI09 View Post
Any ideas?
Have Fun!
Don
We did that as well... No effect.
However when you use the key in question and lock the door manually the alarm get activated and red light blink , therefore it recognize the key but not the Keyless Entry function ..It's like the transmitter on the fob is whack
Old January 17th, 2013, 01:02   #5
keaton
keaton's Avatar
TDI(s): 2005 Mk5
not sure if this will help but if you have a new uncut key and an old one you can do this.
http://forums.vwvortex.com/showthread.php?4591438
you can also pop the pin out of the the switch blade and repin it
2015 MK6 Jetta S TDI w/DSG
2005 Chevy Corvette, 1-7/8 long tube headers, 3" Catless X-pipe, NPP Dual mode mufflers, tuned.
1996 Chevy Silverado, Headers, tuned
1960 El Camino (project)
keaton is offline   Reply With Quote
Old January 17th, 2013, 13:53   #6
cobra390t
cobra390t's Avatar
It appears as if it's a Bad Key Fob transmitter , It act like it's programed , System recognize it but when you transmit ..it's nothing. Found a used in good condition OEM unit at a fraction of what the stealertship will charge , Might give it a run and see ....
Old January 29th, 2013, 08:18   #7
Btravelen
I just bought a new replacement fob with an uncut blade on Ebay. It appears to be OEM with the right numbers, appearance. My local locksmith cut the key and obtained my 4 digit PIN (which was NOT on my key tag, there is a 7 digit code on my 2005 Passat). I used my VagCom to program the immobilizer and all is well with it. I was able to program the remote portion and it locks/unlocks the passenger doors. I thought everything was good until I tried to unlock the liftgate. I tried to use the VagCom to add the remote, but it doesn't let me. It shows the 2 keys in the system but doesn't let me add 1. I thought the remote portion of the FOB was defective, so the Ebay vendor replaced it for me. I haven't tried to program it again yet.
EDIT: I just came in from trying to program the replacement remote. Same result, the liftgate function is not working. Doors lock, unlock, immobilizer functions (car starts), but no liftgate unlock.. I even tried re-adding the keys with the VagCom and the two original keys fully function, but the Ebay key won't open the liftgate. Nuts..
'05 Stonehenge gray TDI Passat Wagon, Leather with wood. Splash guards, 3M Clear bra, Reverse sensors, Spoiler, Rear sunshade, etc..
What's a chain?
'05 Ford Excursion Limited, 6.0L PSD, Air Lifts, Bilsteins, High idle mod.
Btravelen is offline   Reply With Quote
Old January 30th, 2013, 06:14   #8
cobra390t
cobra390t's Avatar
I ordered Pr owned OEM Key fob which came complete (fob and Key) am only interested to re-program/ re-flash the Fob section i will do it this weekend for the lock/unlock ,Panic & Lift-gate option to mate with My 06 . I chooses to go the Pre-owned OEM to avoid what you mentioned.
When i was looking i was told that all numbers and letters listed on the fob must match so if your fob #'s end with P and you bought H then something will not work , All internal ICU has to be the same ,HLO is the company makes the OEM key Fobs for VW not sure what you have is the OEM or Not ... Or you can live without this function
Old February 2nd, 2013, 08:47   #9
cobra390t
cobra390t's Avatar
My Local TDI club Member friend and i programed my Pr-owned spare key fob with His Vag-com ..It Worked 100% . We also tuned off the DRL light and reprogrammed the Key fob to control the Window's to go up and down with the remote ..Pretty neat stuff ..Thanks to TDI club Member's ...This place ROCK
Old June 24th, 2013, 19:56   #10
turbos10
TDI(s): 2004 Golf
I am reading all of this and my head is spinning....I just got an 00 Jetta and I have no working key FOBs. I have one that does not work and I have tried batteries with no luck. I would like to have two working FOB's and a valet key if possible. Can someone give me the options on what to buy. I have access to a local guru with Vagcom. I have read that used can work and it can not. Does anyone know the price to get these from a dealer?
Auto Stable:
'00 Beetle TDI, 98 Jetta TDI
'03 Chevy Duramax, '69 Firebird
Jeep XJ Rock Crawler(For Sale), Jeep CJ2 tube buggy
turbos10 is offline   Reply With Quote
Old November 10th, 2013, 11:09   #11
autoexpert2
Default Best key FOB
Good find for keyless programing.
Key Fob (keyless entry): http://programkeyfob.com/
Check Engine codes (Trouble codes) : http://checkenginecode.com/
autoexpert2 is offline   Reply With Quote
Old January 7th, 2014, 11:01   #12
BITRBO
TDI(s): '09 JSW DSG
I'm running into this problem and wondered if anyone found a solution... Took the car to the dealer today to get a new fob programmed, and everything works except when I hit the unlock button the trunk pops, but stays locked... It's like it only half unlocks or something. I have to pull up on the trunk handle and hit the unlock button again in order for it to open. I don't see how this could be fixed using VAGCOM, but maybe someone knows??
BITRBO is offline   Reply With Quote
Old January 11th, 2014, 04:02   #13
munderhill
Fuel Economy: avg 39 with current '05 tdi triptronic auto
Default Replacement aftermarket fob
I just bought a pair of key less entry remotes for my Wife's 2005 TDI off ebay.
She matched them to car without issue.
Saved quite a bit of coin going this route. Paid 39.99 for the pair shipped!
Thanks to all the info I found here on this forum, I save a lot on repairs.
MU
munderhill is offline   Reply With Quote
Old January 12th, 2014, 12:16   #14
bigolac
TDI(s): 99 Beetle
Thanks, op! Had to reprogram both fobs when I had the battery out to do a starter replacement.
Good stuff - saved me some money and much needed time!
- Adam
bigolac is offline   Reply With Quote
Old March 1st, 2014, 13:19   #15
scottb8888
Default New Jetta
Well, not new. I just bought a 2002 Jetta for my son and it came with a worn out fob. I have been reading and as much as I understand is there a way to take the fobs on Ebay and create a couple for our car without going to the dealer??
Dealer said $200
scottb8888 is offline   Reply With Quote
Key fob programming fire32njetta OBD Scanners 1 April 10th, 2009 03:46
FOB programming problem Tee Dee Eye OBD Scanners 3 October 31st, 2007 17:16
Key FOB programming nordska TDI 101 2 April 1st, 2007 09:51
Key fob programming tekone VW MKIV-A4 TDIs (VE and PD) 8 February 5th, 2004 10:37
keyless programming instructions cjric VW MKIV-A4 TDIs (VE and PD) 6 November 5th, 2003 05:01
Page generated in 0.15733 seconds with 10 queries
[Output: 136.34 Kb. compressed to 115.07 Kb. by saving 21.27 Kb. (15.60%)]
