yahmon
- Joined
- Dec 27, 2012
- Location
- canada
- TDI
- 04 passat tdi 6spd stage2 webasto TC3 , 04 passatW8 6 spd, 10 Jetta TDI 6spd stage 1
Not sure if anyone cares but if you have the 12pin 1531 webasto timer then you can ground pin 7 momentarily to activate instant on.
So it does the same as pushing the instant on button.
So you can connect any signal to a relay to latch for a second and the webasto fires up the same as instant on button.
I used it with t91 remote that won't hold +12V for more than 2 seconds.
Enough to get pin 7 exited though.
