Old January 10th, 2013, 14:35   #1
Uimytdi
TDI(s): Mkv jetta
Default Frequent regens
It's been happening more than normal. I have been driving the same route since I got the car and it almost never would be in the middle of a regen when I turned it off.(fan staying on) but over the past few tanks I've noticed it happening almost every time I stop. It's happened 3 times this tank of gas and I still have about a 1/4 left.
Any idea what's happening? Is my dpf just becoming clogged? I try to redline it often enough to heat everything up in an attempt to prevent this.
Car has 80k miles on it.
Uimytdi is offline   Reply With Quote
Old January 21st, 2013, 19:37   #2
OldMan52
OldMan52's Avatar
TDI(s): Jetta 2009
just a thought...when it's cold, car takes longer to warm up, and more soot is produced.
OldMan52 is offline   Reply With Quote
Old January 22nd, 2013, 08:27   #3
FowVay
FowVay's Avatar
I thought my car was doing very frequent regenerative burns but after watching the tachometer every time I realized that the fans were running but I wasn't getting any RPM increase. I figured that it was just my cooling fans running to cool the engine.
FowVay is offline   Reply With Quote
Old January 22nd, 2013, 08:30   #4
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
You really need a ScanGauge or UltraGauge or whatever to VERIFY what is really happening.
If you keep interrupting the regens, it will keep trying to do it until it completes one. Stop interrupting them.
Trusted TDI Mechanics Map || TDIClub Chat
Old January 22nd, 2013, 08:57   #5
flyboy320
flyboy320's Avatar
TDI(s): 2018 e-Golf
Mine seems that do one every 250km.
flyboy320 is offline   Reply With Quote
Old January 24th, 2013, 12:36   #6
socrates42
I think mine is doing it too. What is the code for Regen? I have a bluetooth OBDII Tool that I can use.
socrates42 is offline   Reply With Quote
Old January 24th, 2013, 12:39   #7
Good Ol' Boy
VeeDubTDI's Avatar
Your what is doing it, too? The 2006 listed in your profile does not do regens.
Old January 24th, 2013, 12:50   #8
RebelTDI
Regens should occur every 400-600 miles. I imagine driving conditions will affect this. As stated above, if you interrupt a regen, another will occur until it is complete. BTW, I don't think that you can conclude that every time the fan runs after turning the car off that it was in the middle of a regen, according to the service manager I deal with. If anyone knows differently, let us know.
RebelTDI is offline   Reply With Quote
Old January 24th, 2013, 13:13   #9
cd_booth
Fuel Economy: 35/45
There have been occasions where I didn't notice a higher than usual idle and the fans running after shut down. This would indicate that it wasn't in the middle of a regen.
cd_booth is offline   Reply With Quote
Old January 27th, 2013, 16:12   #10
bombero
bombero's Avatar
Why does the Passat use the fluid for this when it is the same engine? Not sure which system I would rather have though...
2006 Jetta TDI/graphite blue/dsg
My other diesel is a fire engine.
bombero is offline   Reply With Quote
Old January 27th, 2013, 16:37   #11
Good Ol' Boy
VeeDubTDI's Avatar
The AdBlue exhaust fluid isn't used for regens, per se - it is injected all the time to control NOx emissions. By having the exhaust fluid, the emissions system is significantly less complicated and allows for better fuel efficiency. This is why the Passat, despite its larger size, is capable of getting better fuel economy than Golfs and Jettas.
http://en.wikipedia.org/wiki/Diesel_exhaust_fluid
Passat Active Regens - How Often [Fans run after shutdown] gergg VW Passat Family (NMS and B7) TDIs (2012+) 293 May 25th, 2015 11:56
Oil Dilution From Frequent DPF Regens whiplash willy Fuels & Lubricants 15 March 19th, 2012 11:20
Tracking Regens Jim'stdi VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 October 24th, 2011 08:53
Lets talk Regens Mach1 VW MKV-A5 Golf/Jettas 56 February 9th, 2010 07:00
Should regens happen every day? TomS TDI 101 2 January 16th, 2010 14:16
Page generated in 0.09339 seconds with 10 queries
[Output: 101.25 Kb. compressed to 85.61 Kb. by saving 15.64 Kb. (15.45%)]
