Old January 6th, 2013, 19:21   #1
nitro_junkie001
nitro_junkie001's Avatar
Default Rotella T5
I Know..Another Oil Question
Yes . I used the Search ...Been Reading Alot on Oils tonight.
I don't see any Info. on the Rotella T5 10w-30 here on the Forum.
I picked up a Bottle of this the other day .I read that it was a Energy saving Fuel economy performance oil.
I see that it meets the CJ-4 , CI-4 Plus , CI-4
And is Compared to conventional SAE 15w-40
I have not changed out my oil yet. I wanted some input befor doing so.
Anyone run this in there Tdi's?
nitro_junkie001 is offline   Reply With Quote
Old January 6th, 2013, 19:35   #2
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
I'm not clear on why anyone would run anything but 5W40 in an older tdi.
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old January 7th, 2013, 06:18   #3
TooSlick
TDI(s): Audi 100S
You could run it.... The additive chemistry is certainly better than the old VW 505.00 oil that was originally specified for your engine. I actually like the 10w-30, diesel rated oils for high mileage gas engines, since they are formulated as "thick" SAE 30wts. The CJ-4 spec requires that 10w-30's have a HT/HS viscosity of at least 3.5 Centipoise, vs 3.0-3.2 Cp for most gas engine oils (API/SN).
For an older TDI in Florida, a 5w-40/10w-40 or 15w-40 synthetic is a much better choice, however....
TS
TooSlick is offline   Reply With Quote
Old January 7th, 2013, 14:25   #4
Rual817
Rual817's Avatar
That oil breaks down LONG before the Full Syn will. The immediate cost savings QUICKLY goes out the door when you have to change @ 3K, as opposed to 10k on Full Syn.
214K all stock 4spd auto., vented, 205/65/15H LRR Discount Tire RoadHugger
Really want a 5sp, tune, VNT 17/22, injectors, exhaust...
Rual817 is offline   Reply With Quote
Old January 8th, 2013, 16:32   #5
nitro_junkie001
Yea. I'm sure most people said that when Synthetics came out also.
TS
I've Never Been One to Run My Sythetic in My Cummins for 10K .I'll run 5K tops with the synthetic. So I don't mind the Extra time on shorter services to keep piece of Mind . I've seen a few Motors wipe a bearing out or sludge up because The dealer told them they could go 5K on ( non Sythetic oil services.)
Old January 8th, 2013, 16:52   #6
scooperhsd
I've personally gone 10-12,000 miles on T6 , but I wouldn't use T5 in my TDI EXCEPT possibly in the summer.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old January 8th, 2013, 17:10   #7
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Why not in the winter?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old January 8th, 2013, 18:11   #8
scooperhsd
15W40 - takes a LOT longer to flow through out the engine than 5W40.
Old January 8th, 2013, 18:14   #9
AndyBees
AndyBees's Avatar
I think my car is at 11.5k at the moment on T6......
I keep telling my son it's time to change the oil. He likes the 50+ MPGs on his 150 mile daily commute (was using a Jeep Cherokee with big wheels).....
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
Old January 8th, 2013, 18:21   #10
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
We are talking about a 10w30, synthetic blend. Unless it gets below 0F / -20C, you should be good.
Rotella T5/T6, $29.99 @ Canadian Tire LNXGUY Ontario 71 April 17th, 2012 10:17
Rotella T 5w40 now Rotella T6??? Joester Fuels & Lubricants 13 February 5th, 2010 17:20
Rotella T6 & Rotella T SB? kwalsh24 Fuels & Lubricants 8 January 28th, 2010 17:38
Difference between Rotella T/Rotella T Synthetic? Thermo1223 Fuels & Lubricants 23 March 5th, 2005 17:58
EURO VAN T5 / TRANSPORTER T5 transporter_man TDI Power Enhancements 0 October 19th, 2003 04:56
Page generated in 0.11209 seconds with 10 queries
[Output: 100.34 Kb. compressed to 85.55 Kb. by saving 14.79 Kb. (14.74%)]
