Old January 6th, 2013, 09:32   #1
john brenner
Default can I fill the adBlue tank myself on 2009 treg
Right now I am stuck going to dealer, has to be a way of filling adblue tank. Any one find a way of doing it yourself?
john brenner is offline   Reply With Quote
Old January 6th, 2013, 09:51   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Yes!
http://www.myturbodiesel.com/1000q/a...di-dpf-faq.htm
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old January 6th, 2013, 12:03   #3
john brenner
Ok the Kruse bottles work but they are almost thirty dollars. And Kruse makes a filler hose that fits on adblue tank. I am guessing the other end only fits Kruse disposable containers. The video said you could make shift the bottle into a funnel. Looks like a spill in the making. Is the fitting on treg tank standard to all adblue tanks or a vw bastard. I would like to make a hose set up so if there is a spill its out side the car. buy the kruse bottle fit the spill proof top to a hose and have a large funnel to feed adblue into hose out side the car. Kruse wants 180 dollars for two foot hose. LOL
Old January 6th, 2013, 12:13   #4
40X40
Experienced
You buy a bottle of DEF from VW. You use up the DEF from that bottle and then either figure out a way to refill it or you cut off the bottom of it and use it as a funnel.
You can read the DEF tank level with VCDS (at least on the cars, not sure about the SUVs).
You only have to service the DEF tank every 10,000 miles. Spillage can be overcome with plastic bags and duct tape which you install/remove each time you service the DEF tank.
DEF=ADBLUE
Bill
Golf VI AdBlue tank location CDerekGo VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 November 30th, 2012 18:57
Anyone have confirmation on location of Adblue tank? Fixmy59bug VW Passat Family (NMS and B7) TDIs (2012+) 12 November 25th, 2012 08:05
AdBlue tank rattle? scott10s VW Touareg TDIs 4 May 7th, 2012 04:32
How much to fill your tank? whitevanman TDI 101 32 March 28th, 2012 20:55
Cant fill up my tank agy2k2 VW MKV-A5 Golf/Jettas 6 February 21st, 2011 14:03
Page generated in 0.13291 seconds with 10 queries
[Output: 62.69 Kb. compressed to 56.20 Kb. by saving 6.49 Kb. (10.35%)]
