Old December 28th, 2012, 13:26   #1
yahmon
Default Webasto
I just installed a webasto tsl 17 in 04 passat tdi.
It was a bit of work and was almost done when i found this pdf file for webasto blue heat.
http://pics.tdiclub.com/showphoto.ph...e-heat&cat=517
The tsl 17 is an over the counter webasto product meant for any vehicle.
The main differences are that the blue heat comes with heater hoses and has fan control wiring harness, also had to build my own mounting brackets
I am going to make my own fan control which requires a wire to run from pin #4 from the heater unit.
Does anyone knows where i can get the proper pin(female) that inserts into the plastic connector that connects to the unit?
yahmon is offline   Reply With Quote
Old January 4th, 2013, 23:13   #2
Pitzury
Climatronic or manual heat controls?
Pitzury is offline   Reply With Quote
Old January 14th, 2013, 00:38   #3
yahmon
manual climate, didn't integrate the fan yet.
apparently pin 4 on the heater supposed to be a temp signal to start fan but i am not sure if that holds true for tsl17 which seems to be identical to thermo top c in europe.
According to some manuals pin 4 is option.
webasto is a difficult quest to say the least.
Like to learn some remote setups with tsl 17 with fob activation.
Webasto Top V greengeeker Upgrades (non TDI Engine related) 4 February 11th, 2012 00:22
webasto blueheat absolutetraitor Upgrades (non TDI Engine related) 40 May 5th, 2011 08:07
Webasto 2010 Lightflyer1 VW MKV-A5 Golf/Jettas 6 January 7th, 2010 08:54
Webasto install duncgee Upgrades (non TDI Engine related) 18 November 3rd, 2008 13:11
Espar vs. Webasto marekcz VW MKIV-A4 TDIs (VE and PD) 10 October 19th, 2005 09:10
Page generated in 0.12756 seconds with 10 queries
[Output: 55.95 Kb. compressed to 50.84 Kb. by saving 5.11 Kb. (9.14%)]
