Old December 25th, 2012, 08:02   #1
Agtech4020
Agtech4020's Avatar
Fuel Economy: 48.3
Default Transmission shift hesitation when cold
I have a 2001 Jetta TDI that is unfortunatly equipted with an Automatic transmission. Since the weather has gotten cold I have noticed that the transmission will hesitate between 2nd and 3rd gear giving a slight neutral feel. Once the car warms up the transmission shifts perfectly normal, I can't make it slip or act up at all. I had the transmission rebuilt about 50,000 miles ago and have had very little trouble with it. I'm not a hot rod driver and the care is bone stock with 225,000 total miles. The transmission fluid was changed only 10,000 miles ago.
I have heard that the transmission shift valve is know to have issues and wonder if my issue might be an indication that it needs replacing? Any suggestions would be greatly appreciated.
Thanks!
Agtech4020 is offline   Reply With Quote
Old December 27th, 2012, 12:05   #2
feuerwehr7
Hello there!! I have the same problem B U T my ATF fluid was changed less than 800 miles ago. This symptom is very erratic and also not jet a error code. Any help or suggestion from anybody? I read and read but it got me all confusion rather than enlightened. 2002 Jetta TDI 151000 Miles
feuerwehr7 is offline   Reply With Quote
Old March 10th, 2013, 15:11   #3
Agtech4020
Agtech4020's Avatar
Fuel Economy: 48.3
In the end I found out that my torque convertor was turning itself into shavings. The fix ended up being a completly rebuilt transmission with a new torque convertor to the tune of $3,250. On the bright side the car has never shifted so well! This is why you don't spare any expence on torqe convertors, going cheap only costs you in the long run.
Auto Tranny Shift Hesitation And Extreme Vibration npretnar VW MKV-A5 Golf/Jettas 2 February 18th, 2012 10:34
DSG shift hesitation Razor B TDI 101 15 May 17th, 2011 07:42
PD Auto Transmission won't shift when cold manics01 VW MKIV-A4 TDIs (VE and PD) 8 March 10th, 2011 06:31
Hesitation when cold Wildwr VW MKIII-A3/B4 TDIs 3 September 9th, 2010 05:42
2000 golf Auto shift hesitation Ray Whitley VW MKIV-A4 TDIs (VE and PD) 4 June 3rd, 2001 08:23
Page generated in 0.12731 seconds with 10 queries
[Output: 57.79 Kb. compressed to 52.55 Kb. by saving 5.24 Kb. (9.07%)]
