Old December 15th, 2012, 18:24   #1
MAXRPM
MAXRPM's Avatar
Fuel Economy: 57
Default The fan blower is not working Jetta mk4
Checked the fuse on my MK4 Jetta and it's ok, could it be the fan switch? press A/C switch and it does not light up, the fan switch panel portion does not light up at night either,,,, any advice before I continue my search on what
the culprit is.. txs
1/4 mile run----13.98 sec. @ 105.37 mph
DRIVERS FIRE COMPLETE KIT GTB2260VK
MAXRPM is offline   Reply With Quote
Old December 15th, 2012, 18:40   #2
csstevej
Does the fan work on #4 setting only?
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old December 15th, 2012, 18:44   #3
davebugs
Yep. Certainly sounding like the resistor at this point.
davebugs is offline   Reply With Quote
Old December 15th, 2012, 18:45   #4
csstevej
That's what I'm thinking too.
Old December 15th, 2012, 18:48   #5
davebugs
To the OP - the backlight being burnt out is likely unrelated.
There is an excellent how-to here on how to remove center know, remove bulb with vacuum home, what bulb # to get, and how to reinstall.
Old December 15th, 2012, 18:51   #6
csstevej
Yeah to fix that you need to pull the knob off and the bulb is recessed inside, forget what size.
Old December 16th, 2012, 10:09   #7
PDJetta
PDJetta's Avatar
Its this bulb:
Sylvania 2721.
I have discovered the same bulb is used to illuminate the power socket in the ash tray. Ask the dealer about a replacement and they tell you that only the entire socket assembly is available for $55. But you can disassemble that too and replace just the bulb.
--Nate
Old December 18th, 2012, 18:26   #8
MAXRPM
MAXRPM's Avatar
Fuel Economy: 57
let me try and see if the #4 works, i tried it up til #3 what are the chances that it could be the blower? hope not,, I'd hate to pull it out,,, before I try to pull it out I'd need to continue doing more test on the rest of the stuff, ,,,,,, when button is pushed for the recric, light works, but the A/C does not,,, any more suggestions?
Old December 18th, 2012, 19:08   #9
csstevej
Check position #4, it bypasses the resistor pack and applies 12 volts to the motor. If it works there then the resistor pack is bad, my sons car, the pack was rusted because the PO didn't put the cabin filter cover on The correct way
and water trickled down to the resistor pack and kept it submerged.
Old December 20th, 2012, 18:51   #10
MAXRPM
MAXRPM's Avatar
Fuel Economy: 57
position#4 still does not turn the blower or heather on,, so now the question that I have,, is fuse #25 (25Amp) the only fuse for the blower or is there another one that I'd need to check?
Old December 23rd, 2012, 00:08   #11
MAXRPM
MAXRPM's Avatar
Fuel Economy: 57
I think it is time to check my blower to see if it is the culprit!!!!!
Old December 23rd, 2012, 18:58   #12
where2
where2's Avatar
Pull the glove box out and drop a 12v battery straight on the blower motor. If it runs, then chase wires.
'06 Jetta_TDI Pkg_1 5spd (4 wife) Got Boost...
'04 Jetta_TDI_Wagon_GL 5spd (4 daily) Got Miles... 165k!
'90 Corrado_G60 Pkg_2 5spd (4 fun) Supercharged and half the fuel economy of a TDI!
where2 is offline   Reply With Quote
Old January 7th, 2013, 18:42   #13
MAXRPM
MAXRPM's Avatar
Fuel Economy: 57
I"m chasing the wires now, it's not the motor, its not the fuse, and I have no current going through the resistors and the motor, so I am thinking the culprit may be the blower switch,.
As far as I know,
there is only 4 different things that could malfunction, fuse, switch, blower, and resistors??? Am I right on this???
Old January 16th, 2013, 23:46   #14
MAXRPM
MAXRPM's Avatar
Fuel Economy: 57
Fuse, fan blower, resistors, fan switch, are not the culprit, does anyone know which relay provides current to the fuse box?
Old January 17th, 2013, 07:28   #15
AndyBees
AndyBees's Avatar
Fuel Economy: life time average above 50 MPG
..........bet it's the Fan Switch!
Those circuits are fed thru the 75X (that circuit is disabled during the START MODE of the Iginition). In the On position (Iginition) the Fan and other accessories will function.
The Fan Switch (E9) circuit is fed by fuse #25 (which happens to be a 25amp fuse) and does not involve a relay. The Switch can be bad and it "will not" operate the fan on #4 position.
With Ignition ON, the Fan Switch must be ON before the Fresh Air function or AC function will operate whether their bulbs are blown or not.
There is a How To as well as a current Thread of discussion over in 101, which includes a few pictures of the switch and what happens internally when it goes kaput.
Hope this helps!
2000 Jetta TDI, 50+ overall average (no tune)
300k mile mark on 12/28/11
427 fill-ups, in Excel spreadsheet, 323k miles...
'84 Vanagon ALH TDI engine (32 mpg), Polaris Diesel ATV, Allegro Bay RV 5.9 cummins
VWs 40 years, VW diesels 33 years, ALH TDIs 11 years
blower fan not working diesel142 VW MKIII-A3/B4 TDIs 2 July 22nd, 2012 10:38
wtb: blower fan motor for mk4 jetta tdi 2000 vwmikey99 Ontario 1 June 6th, 2011 20:22
Blower fan, and seat heaters not working mnbrown25 VW MKV-A5 Golf/Jettas 0 September 20th, 2010 14:31
blower fan for ac not working jefem24 VW MKIV-A4 TDIs (VE and PD) 8 June 30th, 2007 10:19
Heater Fan/Blower not working the great roberto0 TDI 101 3 December 23rd, 2006 09:55
Page generated in 0.14508 seconds with 10 queries
[Output: 126.75 Kb. compressed to 104.94 Kb. by saving 21.81 Kb. (17.21%)]
