Old December 15th, 2012, 07:31   #1
WAYNEO
TDI(s): 2001 NB
Fuel Economy: 40-42
Default PA state inspection issue/ exhaust
Have 2001 NB, live in Delaware County. Just failed state inspection, needs exhaust system repair. If I did a mufflerectomy that started behind my cat and used a straight pipe, would that pass inspection? Any suggestions where to get it done, or get work a passable system at a lower cost? My wallet is pretty lean these days. Got to do it soon.
WAYNEO is offline   Reply With Quote
Old December 15th, 2012, 14:00   #2
PDJetta
PDJetta's Avatar
See if your state posts what is required to pass an inspection. See if "Muffler" is listed. Better yet, ask the guy that failed the car, because he probably will be the one who sees the car again.
--Nate
Old December 15th, 2012, 15:45   #3
romad
romad's Avatar
See http://www.dmv.state.pa.us/pdotforms...ubchapterE.pdf
Particularly Section 175.75(b)(1) on page E-6 and Section 175.80(e)(6) on page E-14
The fleet:
romad is offline   Reply With Quote
Old December 17th, 2012, 11:50   #4
WAYNEO
TDI(s): 2001 NB
Fuel Economy: 40-42
There are no emission reqirements for passenger diesels in PA. The problem is determining how far from the cat will the state allow a weld to a new pipe. if that can be deterimed, may have a cheap fix. May also have to include a resonator. Muffler is meaningless as there is no noticable sound issues that would result in a fail.
Old December 18th, 2012, 08:10   #5
saturnhacker
if you are talking about removing the muffler that could be a problem with most inspection mechanics in PA, of course the code can sometimes be interpreted differently by different people.
pm sent
B4 Passat (5 and counting, various states of driveablility)
02 Golf
82 Caddy 0-60 someday
95 US Electricar (Geo Prism), the lead sled
saturnhacker is offline   Reply With Quote
Old December 22nd, 2012, 18:41   #6
BradleyRas
BradleyRas's Avatar
Fuel Economy: 55/42/38
I performed a mufflerectomy years ago and had to find a state inspection mechanic who was a little more flexable... nobody else would pass it due to not having a muffler. The VW stealership offered to 'fix' my mufflerectomy for $700+. hahahahhah thanks but NO!
2000 Jetta TDI GLS-silver arrow, trialer hitch-lux pac-broken right glove box hinge, EGR deleted, KermaTDI 3" turbo back exhaust, G60 flywheel/VR6 clutch, Titan 764 nozzles, Malone stage II tune and vent-ectomy.
BradleyRas is offline   Reply With Quote
Old December 30th, 2012, 09:16   #7
nathan_b
Fuel Economy: 50mpg
I believe in PA a turbo is a legal "muffling device"
which it does, it chops up sound waves.
nathan_b is offline   Reply With Quote
MD State Inspection... nm50 Eastern USA 12 June 21st, 2013 16:14
PA TDIers, state inspection question greenskeeper Eastern USA 12 February 8th, 2013 14:23
State inspection around Philadelphia adamant628 Eastern USA 4 March 5th, 2010 12:06
NJ State inspection chris smith Eastern USA 11 February 6th, 2007 13:50
MA state inspection questions v8volvo Eastern USA 24 December 5th, 2006 07:30
Page generated in 0.13458 seconds with 10 queries
[Output: 79.00 Kb. compressed to 68.50 Kb. by saving 10.50 Kb. (13.29%)]
