Old December 14th, 2012, 20:15   #1
outthere
Default Fuel Flap Door
Hope someone can point me in the right direction.
I knocked the fuel nozzle into the fuel flap door on my B5 Wagon. The flap snapped at the hinge. Does anyone have a diagram or pics of how this goes together? I'd like to remove the hinge thats still attached to the car, epoxy, replace but not sure exactly how this goes apart & back together. worst case replace it.
Your awesome help is always appreciated! (Coming up on 13 years of TDIClub- I owe a lot of folks props/beers!)
outthere is offline   Reply With Quote
Old December 15th, 2012, 05:25   #2
thundershorts
probably lots of used ones available as its not tdi specific. forget trying to glue it.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old December 15th, 2012, 19:39   #3
MattS
TDI(s): 2005 Passat
There is a single Torx screw accessible with the door open (or broken off!) that holds the whole assembly in place. Removal is very easy. I swapped mine with one I found on a gasser in the junk yard. (Had to manualy activate the release on the junk car after removing the side panel in the trunk.) Paint is a perfect match. I was even able to peel off and reuse my diesel label on the inside of the flap.
MattS is offline   Reply With Quote
Old December 16th, 2012, 12:10   #4
auntulna
I had one break where the hinge meets the door. Took it out, just one screw.
Glued it indoors for better temperature and control; used super glue to hold the parts, then covered that with epoxy glue.
Gave it about ten open/close cycles. Doing OK so far.
auntulna is offline   Reply With Quote
Old December 21st, 2012, 17:00   #5
outthere
Thumbs up
Many thanks - found a used match online $50 later part arrived today. I hadnt thought to look at gasser's and other model years, duh.
This is from a '99 passat gasser. Hope to pop it in tomorrow AM.
Thanks again I appreciate the feedback!
Old January 3rd, 2013, 19:18   #6
outthere
Shout out to Tom's Foreign Auto Parts in CT. exact fit, color, and arrived in 36 hours from order for $49. tomsforeign.com
FS: brm intake flap and egr flap GotEuroCorrado Private TDI Items for Sale/Wanted 0 October 30th, 2012 18:23
Wanted: Silver B5.5 Passat Fuel Door/Flap MattS Private TDI Items for Sale/Wanted 0 February 14th, 2012 04:42
door flap for recirc ac not working too well RuneTDI VW MKIII-A3/B4 TDIs 7 August 15th, 2009 06:07
WTB: MK IV Fuel Flap Door Primer and Torx screw Davot Private TDI Items for Sale/Wanted 1 July 8th, 2008 22:55
WTB Golf IV Fuel Flap Door Primer and Torx screw Davot Private TDI Items for Sale/Wanted 0 June 1st, 2008 07:14
Page generated in 0.13096 seconds with 10 queries
[Output: 72.36 Kb. compressed to 63.46 Kb. by saving 8.90 Kb. (12.31%)]
