Old December 3rd, 2012, 15:21   #1
obscenic
Default No start after intake manifold cleaning.
I'm having a hell of a time figuring this one out so I thought I would ask around here for some troubleshooting!
After doing my timing belt (and water pump etc) I had my mkIV golf back on the road and noticed a lack of power. I VCDS'd it and found that no turbo was being delivered at all. These are the steps that I took
I took a look at the vacuum lines and found that the ASV actuator nipple had snapped off. Whilst I was waiting for a new one, I took off the ASV/EGR valve, the EGR cooler, the piping and the intake manifold and took it to get cleaned at a machine shop.
With them sparkling clean I reinstalled them all except the ASV/EGR valve. I added a belly pan and replaced the side skirts (probably irrelevant but just in case).
When the actuator arrived I installed it, reinstalled the valve, hooked up the vacuum lines and electrical connections and double checked everything.
It started for about 2 seconds, and then stopped noisily. Subsequent cranking sounds pretty bad. I pulled apart all my air lines to make sure I wasn't starving the engine of air with an accidental rag leftover - it all looks clear. I took off the intake manifold and valve to check for obstructions and all looks clear. I can't quite see into the block intake with the engine still in the car, but I don't see any signs of rags or anything.
Any thoughts? I'm at a loss.
obscenic is offline   Reply With Quote
Old December 3rd, 2012, 15:30   #2
Ski in NC
Fuel Economy: 48-52 typical
Check that you did not reverse the connectors for ASV and crankcase vent heat element. They have the same shape plugs and if you reverse them, the asv will close on engine start.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old December 3rd, 2012, 15:32   #3
obscenic
I should have added; it's a 2000, ALH engine.
Old December 3rd, 2012, 15:34   #4
obscenic
I left the ASV one plugged in the entire time.
Old December 3rd, 2012, 15:42   #5
Crankous
Crankous's Avatar
what was the sound when it stopped? what does it sound like when you crank it now? Also get a mirror to look into the intake ports on the block with a nice flashlight you can see well. also Im sure you double checked your timing job hasnt gone bad right?
Crankous is offline   Reply With Quote
Old December 3rd, 2012, 15:49   #6
obscenic
It sounded.. bad. Like something was stopping the engine from turning. I only tried cranking it once after that for fear that something had fallen into the block intake ports whilst the intake was off. When I cranked it, it had the same bad something holding the engine back noise. I've been using a mirror and a flashlight to see in, but I need to find a smaller flashlight to get a better look.
The timing belt job was done meticulously, and checked afterwards with VCDS and the timing is bang on.
Old December 3rd, 2012, 16:03   #7
Crankous
Crankous's Avatar
Yes but have you checked the belt since the noise. even the new components that are provided by vendors fail.... the percentage is small but it does happen. Sounds like some damage has happened to me. Did you clean your Intercooler before you put this all back together? there could have been a slug of oil that made it into a cyl and locked it up.
Old December 3rd, 2012, 16:32   #8
Seatman
Seatman's Avatar
Fuel Economy: No idea
The asv is definitely wide open when cranking? You say you left the pipes connected but you obviously must've had them off to swap in the replacement. I would check the simple things like that first before getting to worried. A tdi cranking with the asv closed or no fuel etc can sound pretty appalling compared to one that starts good.
Seatman is offline   Reply With Quote
Old December 8th, 2012, 09:10   #9
obscenic
I tried with the asv out of the loop, same sound.
Old December 8th, 2012, 10:03   #10
KLXD
Did you clean the ports in the head? If not maybe a piece of junk fell into an intake port then went under a valve and stuck it open.
Hard to believe that it wouldn't mush out since the stuff is pretty soft but I've heard of this happening.
Whatsit feel like if you turn it over by hand with a wrench on the crank pulley bolt?
Current: ’02 Jetta, Auto; ’98 Jetta, 5 Spd; ’98 Dodge, 5 Spd, SB, 4x4; ’84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): ’85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: ’85 Mitsubishi PU, 4D55T; ’81 Rabbit, 1.6; ’80 Dasher, 1.5; ’79 Rabbit, 1.5
Old December 8th, 2012, 11:24   #11
obscenic
So, i just popped the valve cover and turned it by hand and it feels like normal compression. Once I thought I had the cams at TDC I looked in the bell housing window and the ****ing mark was BANG on the arrow. It couldn't have been any more precise. I put the injection pump pin in and it went in fine. So the timing hasn't shifted or failed (HUGE sigh of relief). I'm looking into the intake ports and can't see any crud holding one open, but it's hard to say given the viewing angle.
I did not clean the ports in the head because of the risk of dropping crud into the cylinders...
Old December 8th, 2012, 11:32   #12
obscenic
Thank you everyone so much for your input so far! It's really helped me get motivated to do this myself instead of caving and pushing it down the block to the local shop.
Old December 8th, 2012, 11:39   #13
Ski in NC
Try rotating engine minimum two turns by putting a 19mm 12pt socket on crank bolt. Should feel four compression strokes and no hard spots. Compression will stop your rotation, but with effort kept on wrench, compression will bleed down and allow you to continue. CW when viewd from passenger side.
Old December 8th, 2012, 11:55   #14
obscenic
On my way out to do so right now! It'll be easier now that I can see the cams.
Old December 8th, 2012, 12:56   #15
obscenic
If the cams have rotated a full 360 degrees, i should have felt 4 compressions, right? I'm only feeling one and a half..
intake manifold cleaning, now car wont start 2000BEETLETDI TDI 101 7 July 9th, 2010 20:09
Intake manifold cleaning... what about the intake ports in the head? im no hero x VW MKIV-A4 TDIs (VE and PD) 4 November 22nd, 2007 07:09
Intake manifold cleaning help DeGolf VW MKIV-A4 TDIs (VE and PD) 5 October 4th, 2004 07:43
is intake manifold cleaning enough? vonic VW MKIV-A4 TDIs (VE and PD) 2 May 2nd, 2004 18:11
Intake Manifold Cleaning tobsav TDI 101 1 March 25th, 2003 19:06
Page generated in 0.14794 seconds with 10 queries
[Output: 125.03 Kb. compressed to 104.47 Kb. by saving 20.57 Kb. (16.45%)]
