Old December 3rd, 2012, 15:10   #1
Jibeho
TDI(s): 2015 Golf
Default Wow Seized A/C compressor locked engine
Been noticing some noise and smell over the last 2 days. Also the Cooling fan was staying on even though the A/C was off. Today on my way home I stopped and when I tried to start it ran for 3 seconds and stopped. Good thing I had a utility knife in my car to cut the accessory belt with. That got the car started and was able to drive home. I just never figured this had enough lock to kill the engine.
2000 TDI NB, SMOG .205, B99 254k miles(Dead)
2006 MINI Cooper S 17% JCW CAI, One Ball
2009 Jetta TDI (Sold to VW)
2015 TDI Golf S DSG
2016 Mercedes C300 4matic
Jibeho is offline   Reply With Quote
Old December 3rd, 2012, 16:30   #2
Thirstyturtle328
Thirstyturtle328's Avatar
Wow that is REALLY surprising. I once thought my AC pulley had locked up (turned out I just couldn't tell it was spinning because it was so shiny looking from the top of the engine). Anyways, I stopped in the middle of a 6-hour trip with my wife and dog and spent 2 hours fixing nothing because it was actually melted fuses on the battery.
Anyways, now you've got me nervous about it locking up because my compressor is PRETTY rusted (no splash guards or skid plate until I got the car @ 165,000)
Good luck replacing the clutch and/or compressor!
2002 Golf GLS TDI 5MT
Bosio Sprint 520's, Audi 17x7.5 Fat Fives, Panzer Plate, CCV Mod, UltraGauge
Thirstyturtle328 is offline   Reply With Quote
Old December 3rd, 2012, 16:54   #3
Jibeho
TDI(s): 2015 Golf
This locked up and idling car, I wonder what would have happened while driving.
2015 TDI Golf S DSG
Old December 4th, 2012, 06:14   #4
Genesis
Fuel Economy: 53/48/42
Under power you probably would have broken the accessory bracket as the torque on the large idler and tensioner would have grossly exceeded expected values.
If the pieces got into somewhere bad (like under the timing belt cover) then it gets even worse, but a broken accessory bracket is a royal PITA to replace (it's also a bit expensive, but the real problem isn't the cost, it's the hassle.)
Genesis is offline   Reply With Quote
Seized AC compressor unseized? Slowrvr VW MKIV-A4 TDIs (VE and PD) 5 May 29th, 2012 07:56
Seized AC compressor??? Danno! VW MKV-A5 Golf/Jettas 3 May 27th, 2012 05:05
Seized A/C compressor after 2 years Slowrvr VW MKIV-A4 TDIs (VE and PD) 1 May 10th, 2012 11:25
Limp mode and seized a/c compressor Jettascuba TDI 101 0 February 13th, 2012 03:18
seized ac compressor R&R? almus VW MKIII-A3/B4 TDIs 25 June 25th, 2009 21:50
Page generated in 0.11212 seconds with 10 queries
[Output: 64.66 Kb. compressed to 57.98 Kb. by saving 6.68 Kb. (10.33%)]
