fixer
2005 Mk5 Jetta, 5M, ~170,000 miles. Car has been extremely reliable to this point. Driving on the highway last week, without warning the car stalls, glow plug light flashing, low oil pressure indicator, emissions workshop and other stuff. Oil was 1.5 qts low, due for oil change I hadn't gotten to yet. Car had never stalled before. Oil topped up, problem remains. My battery was going (the original in fact), which I replaced with an OEM from the dealer. While installing the battery I took the opportunity to remove airbox and battery box and clean and reconnect the 4-5 grounds accessible there. I also removed the split loom and visually inspected the harness wires from the driver headlight to the engine where it becomes inaccessible. No evidence of chaffed or damaged wires at all. I checked and re-seated all the fuses and modules, none seemed loose. Put back together and the behavior thru several days is roughly the same each time. After sitting for awhile or overnight car starts and runs normally, but within 5 minutes or so will stall and produce the flashing glowplug, low oil pressure indicator, emissions workshop, sometimes the tach works sometimes it doesn't. After the stall, car takes longer to start and makes a different sound while starting and doesn't rev above ~3000.
VagCom shows:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: RC s01f EDC G000SG 7550
Revision: --H01--- Serial number: xxx
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 63C5135BA24E991
1 Fault Found:
000802 - Engine Speed Sensor (G28)
P0322 - 000 - No Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 2
Mileage: 274224 km
Time Indication: 0
Date: 2000.00.00
Time: 04:58:34
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 90.2 %
Voltage: 11.17 V
Bin. Bits: 00001100
Idle Stabilization: 0.0°KW
RPM: 126 /min
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 3A7B8E3F7544B89
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CD778674F90D69
1 Fault Found:
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000063785
Coding: F4098E02400418000014000000140000002077035C
VCID: 2F6DAF6BBE066D1
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
1 Fault Found:
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD028DF
Coding: 0012627
VCID: 2E53B26FB90C649
Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
1 Fault Found:
00532 - Supply Voltage B+
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 L HW: 1K0 953 549 L
Component: Lenksäulenmodul 013 0040
Coding: 0000041
VCID: 3B758B3B7A7E811
No fault code found.
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 972 LX
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023203
Shop #: WSC 08220 444 58805
VCID: 8D1195E3944AFF1
1 Fault Found:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001053190646
Coding: 3D3F0B400F1002
VCID: 2959417380E2031
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TP99903
VCID: F8FFD4378BC8EA9
1 Fault Found:
00926 - Terminal 30
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 178
Mileage: 274223 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:55
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001271
VCID: 36639A0F415C5C9
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.2 1502
VCID: 306FAC17A338729
1 Fault Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Mileage: 4200 km
Temperature: 17.0°C
Voltage: 14.30 V
Voltage: 14.10 V
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106281B0906050FA0080F0490A540
VCID: 820BB6DFDD14B09
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Status: 00110010
Fault Priority: 4
Fault Frequency: 3
Reset counter: 178
Mileage: 0 km
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001271
VCID: 377D970B4656A51
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 A HW: 1K0 035 180 A
Component: Radio DE2 008 0115
Revision: 00008000 Serial number: VWZ4Z7E3035745
Coding: 0040400
VCID: 1E3362AFC9ACF49
1 Fault Found:
01305 - Databus for Infotainment
014 - Defective - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 3169A913A8327B1
1 Fault Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 326BA61FAD34409
1 Fault Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51B563B40A1F1
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
End ---------------------------------------------------------------------
I ordered a G28 sensor, no local dealer had one in stock, and if that doesn't do it (I'm guessing it probably won't) will start electrically testing all the harness wires. Does anyone have any other ideas?
Tony
VagCom shows:
Coding: 0050071
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 274224 km
Time Indication: 0
Date: 2000.00.00
Time: 04:58:34
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 90.2 %
Voltage: 11.17 V
Bin. Bits: 00001100
RPM: 126 /min
Coding: 0021122
1 Fault Found:
1 Fault Found:
Coding: 00065493
Shop #: WSC 00000
Coding: 00217125
Shop #: WSC 00000
1 Fault Found:
Coding: 0012627
1 Fault Found:
Coding: 0000041
Coding: 0023203
1 Fault Found:
1 Fault Found:
00926 - Terminal 30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 178
Mileage: 274223 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:55
Coding: 0001271
1 Fault Found:
1 Fault Found:
Freeze Frame:
Mileage: 4200 km
Temperature: 17.0°C
Voltage: 14.30 V
Voltage: 14.10 V
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 178
Mileage: 0 km
Time Indication: 0
Coding: 0001271
1 Fault Found:
Coding: 0040400
1 Fault Found:
Coding: 0000144
1 Fault Found:
Coding: 0000144
1 Fault Found:
1 Fault Found:
Tony
