Old April 5th, 2015, 01:02   #16
wrenchman30
Fuel Economy: 43 best befor egr much better now
while these thread repairs are nice your assuming they are stronger, your screwing them into aluminum which is the weakness in the first place
wrenchman30 is offline   Reply With Quote
Old April 5th, 2015, 05:31   #17
Dimitri16V
Dimitri16V's Avatar
It is designed that way so the engine drops during a front end collision
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old April 5th, 2015, 07:17   #18
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
Yes, the aluminum is the weak point. However, it is the repeated removal & re-installation of the vertical mount bolts that strips the threads in the mount. The steel insert now takes the stress of the bolt threads, meaning it will stand up to the repeated re & re of the bolts better than the softer aluminum Since there is no movement between the insert and the aluminum, it doesn't wear out.
Moving? Need boxes?
Go green and check out FROGBOX.com
Old Ride (2000 Black Sedan): Gone
New Ride: (2003 Silver Wagon): Malone Tuned, T4 injectors, 11mm pump, 2.5" Magnaflow cat back, PD150 intake, OMI, Wingnut SS, ERF 6 speed, Bilstein TC Sport susp. w/GTI springs, Neuspeed RSB, Santa Monica's, Autometer Cobalt Boost & EGT, MFA Sport cluster, GLI Leather seats, SS vacuum lines, AVIC Z3 Nav and I still get 4.5L/100km (I got 3.9L/100k on a tank once)
Some handy 'How to's'
Wingnut is offline   Reply With Quote
Old April 5th, 2015, 11:35   #19
phaser
Fuel Economy: 47 MPG B-20
I have nearly 360k on my 04, and intend to keep driving it until it dies.
Should this be thread repair be done now as preventive maintenance, or just wait?
2004 Jetta BEW 5M - 470k - 47 mpg / Fuel B-20 / Fuel Filter - Cat IR-0750 /
Oil Filter - Hengst / Oil - Schaeffer Supreme 9000 5W-40 /
Bypass Filter EaBP100 /
Air Filter - EaA208
/ Transmission Oil - VW G50
phaser is offline   Reply With Quote
Old April 5th, 2015, 17:09   #20
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
What prompted me to install the inserts was the amount of "wiggle" when I partially inserted the bolts into the mount bracket... (keep in mind that the engine had quite a high number of miles on it - meaning that the threads had been "exercised" quite a number of times for timing belt changes...)
Yuri
Pereat mundus, fiat musica!
ymz is offline   Reply With Quote
Old May 24th, 2015, 19:35   #21
Dimitri16V
Dimitri16V's Avatar
wiggle is not good , means top threads are rounded
Old May 26th, 2015, 17:02   #22
UhOh
UhOh's Avatar
Two things not mentioned is that the insert has courser and larger threads AND it is to be installed using red thread-locker.
Check back with me on how well they work. I partially botched the installation of one of them, didn't get the tap all the way down (I had thought I had, but when I went to install the insert it stopped before the top was seated) and ended up dremmeling a bit of it off: it's effectively less strong, so if a less-strong install ends up working for me then a proper install will surely be fine! It's been holding together now for 6k miles.
Old May 27th, 2015, 16:40   #23
jokila
jokila's Avatar
Fuel Economy: 52/45/40
I did one of my mount's bolts with this. I agree the aluminum is weak after repeated reinstallation. It was my third timing belt.
There is nothing worse than being at the point in the timing belt process and realizing the threads are disintegrating as you torque down. I was able to cut the threads right through the other motor mount and seat the timesert. It was a lifesaver to having to wait another day and buy more TTY bolts.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old May 27th, 2015, 16:49   #24
UhOh
UhOh's Avatar
All in all the cost was slightly less than had I bought a new motor mount. BUT, now I have the tool bits and a couple of additional serts for use elsewhere (I have two of these cars). For me it was a matter of not wanting to tear things back apart to swap in a new mount: I was tired and I didn't want to undo any of my TB work (adds increased risk of messing something else up!).
Old May 28th, 2015, 08:57   #25
jokila
jokila's Avatar
That was exactly my situation and the cost. I ended up ordering it because I do timing belt work for others and it happened once before to a customer. He ended up ordering a new mount and me having to wait another day or two to finish it. I wanted to be prepared in case it happened again and it happened to me during my last TB work.
Old May 28th, 2015, 14:45   #26
Dimitri16V
Dimitri16V's Avatar
Those are not TTY bolts .
Old May 29th, 2015, 20:58   #27
jokila
jokila's Avatar
I think you must not be following which bolts I am referring to as they most certainly are TTY bolts.
The aluminum mount that is attached to the side of the engine uses what I believe are three 16mm, non TTY bolts to the engine, but most everyone replaces them. It is the two large bolts that attach to it that are definitely TTY. The threads of this mount get weak and can disintegrate.
The torque on those 18mm bolts is 75 ft lbs, or if you follow the Bentley, it is 44 ft lbs + 1/4 turn.
Old May 29th, 2015, 21:37   #28
UhOh
UhOh's Avatar
^^^ Exactly!
Old May 30th, 2015, 01:19   #29
wrenchman30
tty bolts feel like you strip them out when torqued properly, these bolts and many on vw are specified as tty bolts but in reality there just bolts with thread sealer on them, place a new bolt and a old bolt head to thread and the threads will be same length (head will touch each end of bolt)
Old May 30th, 2015, 04:20   #30
ymz
tthese bolts and many on vw are specified as tty bolts but in reality there just bolts with thread sealer on them
not always... sometimes (such as in the case of these vertical engine mount bolts) they're just bolts with an anti-corrosion coating on them... not thread locker...
Yuri
Engine support mount thread stripped when doing TB DeafBug VW MKIV-A4 TDIs (VE and PD) 29 May 20th, 2016 16:48
Pictorial: Repair Engine Mount in Place Franko6 TDI 101 10 January 19th, 2015 05:21
TimeSert Engine/Tranny Mount Thread Repair, W/ Pictures PDJetta TDI 101 9 September 20th, 2012 16:04
DSG Bottom Bolt Hole thread repair - Bolt Thread Size Donald Holder VW MKV-A5 Golf/Jettas 1 June 1st, 2011 19:07
Rear engine mount: gearbox thread stripped Trog thou Meatier TDI 101 13 September 27th, 2007 10:38
Page generated in 0.17036 seconds with 10 queries
[Output: 136.76 Kb. compressed to 114.95 Kb. by saving 21.81 Kb. (15.95%)]
