This almost looks like something a bloke could build himself. You need a flywheel with a pile of strong neodymium rare earth magnets mounted to it, a bunch of spools of magnet wire, and boom, you got yourself a rotor motor. Add some batteries, wiring, and control circuitry and you're done. Anybody out there trying to build something like this on their TDI?
@TDIMeister -- In that case, I'd think you'd just be shifting up a little sooner to keep the engine running at low RPM/high load.
Do TDIs stop injecting diesel when coasting down a hill in gear?
If the rotor motor has enough power to continue propelling the car down the road, wouldn't this look like the same thing as coasting down a hill (from the engine's point of view)? If so, diesel consumption should drop to zero once the rotor motor is doing all the work of keeping the car rolling. At least, until the battery bank goes dead from all the work of pushing the car AND pushing the coasting diesel engine.
