TDI-Hawkeye
Greetings all -- I wish to share with you a simple and extremely effective modification I made to correct the bluetooth microphone quality on my 2012 Passat TDI.
Internet research revealed many frustrated owners were complaining about how they sounded to the person on the other end of the call like they were muffled, choppy, "in a tunnel" etc. After my own research, I found the problem to be related to noise cancellation.
The microphone is extremely sensitive. The default position on the 2012 Passat is facing down toward the passenger cabin. I determined call quality increased when the microphone was facing up and away from the cabin and into the quiet roof console area. That's it! Now, to the fix:
What you'll need:
* Small Flat-Head screwdriver with tape wrapped on end to protect plastic paneling
* T20 Torx bit & driver or wrench
Starting look at the roof console:
Pry down the corner of the panel covering the microphone:
Gently pull down the cover & remove by sliding the hinges out:
Use the T20 Torx wrench/bit to remove the two screws (in green) -- the Microphone is outlined in Red in its default position
Use the screwdriver to loosen the clips holding the console into the roof and drop the console down:
Reposition the microphone by removing it from its insert and orienting it to face up and away from the driver's side. The 3 clips that originally held it in place work nicely to hold it in the new position. Make sure that the wire to the Mic is safely tucked under the driver's side front corner of the insert so it is not being pinched:
Reassemble the console in the opposite manner in which you removed it. NOTE: the microphone will rest very tight against the roof console housing in its new position. Just be careful when screwing the console back in so you don't damage the Mic. Now enjoy surprisingly enhanced audio quality free of the ambient noise from the vehicle cabin!
What you'll need:
