Old November 11th, 2012, 19:12   #1
storx
Default Taco-tdi
I am wanting to replace my 1995 dodge cummins pickup as it was in a wreck a few years ago and its been nothing but a money pit ever since.. I also hate how its an single cab and would love to own an mid size diesel pickup as i own rental propertys and require something to tow around large objects ofton... doors, plants, mulch, wood, drywall
Target trucks are
4DR Ford Ranger
4DR Toyota Tacome
Engine:
ALH - simplicity and seem to be fairly easy to find. Parts are pretty cheap to mod these and build them reliable...
Can i get some advice on which one is better compared to the other. I am not well knowledge on either one and people experience would be my best bet i think on this.
Da Diesel Build
storx is offline   Reply With Quote
Old November 11th, 2012, 19:13   #2
storx
I am driving 45 mins tomorrow to go check out this truck. It has an blown headgasket possible timing belt/chain the owner said. What are things i should look for that makes it a bad donor?? price $3800
Da Diesel Build
Old November 11th, 2012, 22:24   #3
SuperAdellic
SuperAdellic's Avatar
I am not aware of any 4dr rangers on the US market. Maybe in Canada or Mexico??? I know the S10/Sonoma/Canyon/Colorado, Frontier, Dakota, and Tacoma came in 4dr.
In regards to the Tacoma 4dr trucks:
Downside: they only came in automatic, they tend to be more expensive than the others I listed, most of the problems that I have read about are type of use or abuse related. Then again, there's always a lemon in every lot.
Upside: very well supported in the aftermarket, swaps have already been done in Tacomas, the TRD package with the locker is worth some extra money if you can find a truck with it. I'm sure sites like http://www.ttora.com will be able to tell you a lot more specifics on the particular issues to look out for. Good luck and I'm jealous. I've wanted a diesel Tacoma for a long time, especially after driving diesel 4Runners and Prados in Japan.
'00 Golf GLS 4D 5spd (Big Red 1)
'12 Prius Pkg 3 (Blue car; my son's name for it)
'01 Golf GL 2D 01M (Hans; RIP)
The Picard is angry!
800 club twice, 900 club 9/27/2013
SuperAdellic is offline   Reply With Quote
Old November 12th, 2012, 04:02   #4
jimbote
jimbote's Avatar
That is a killer deal !!! If you don't I will .... It would be a fairly straightforward swap to manual, but an auto tacoma would be nice... Check for frame rust by poking around with a screwdriver ... Frame rot was a problem on some rust belt tacomas, other than that this seems like a very good price
Old November 12th, 2012, 10:43   #5
storx
im about to drive up now to look at it..
I was talking with an friend lastnight and he said that the dsg has become so abundant on vortex and junkyards that they are coming down in price because people are swaping them to manuals in there car. He owns an VW BUG that has an Yamaha R1 engine and because of the winter season he adopted an creative AWD system to it thats not really usefull for drag racing but its enough to get out of snow easy...
He purchased an aluminum hydraulic pump and attached it to the engine with an bracked and attached to the engine so its spins as the engine is driven. He fabed up old VW FWD hub assemblys to the front of the bug and attached tiny aluminum hydraulic pumps in the axle shaft areas on the hubs. These small produce only 10hp of hydraulic power so when they are not gripping the fluid is bypassed.
We were talking about the idea of installing an TDI/DSG combo in the car longitude. Then run an custom axle from the drivers side of the transmission to the rear axle. Then run the passenger side output to the front axle.
The other option we were tossing around was to attach an hydraulic pump on both transmission outputs and then install hydraulic motors on both axles to drive them hydraulic..
We are no expert on hydraulics and we understand that is you spring a leak that you cant go anywhere.. well this can be protected by running the hydraulic lines inside some tubular metal pipe for protection. I wanna get some feedback from everything to see what you guys would think about this.
Da Diesel Build
Old November 12th, 2012, 12:07   #6
FredS
Fuel Economy: 00 NB-39, 01 Golf-41, 94 Toy-30
Yeah, if that truck was anywhere near me, I'd be on it too. Jim, is that auto standalone controlled? The idea does sound interesting, but converting to a manual would be hard to resist.
2000 Beetle, 5spd, RC2, Sprint520s,(daughter's 2nd new car)
1999 Golf GL 2dr, 5spd, TDTuning-Stg4, R520s, SBC Stg2-Endurance, 17/22, WhitBread DP, 3bar MAP
92 Dodge crewcab diesel(custom stretch) 4x4
03 GTI, 2012 Tiguan
FredS is offline   Reply With Quote
Old November 12th, 2012, 13:57   #7
Hollis16
That's a fantastic deal on that truck. Swap the timing belt and sell it for a 10K profit! engines are non-interference.
I want to swap a TDI into my taco, but I don't think my 3RZ will ever die.....
Hollis16 is offline   Reply With Quote
Old November 12th, 2012, 16:03   #8
jimbote
jimbote's Avatar
the biggest issue with running a TDI/DSG longitudinally in the truck is you will be way undergeared essentially you will be in low range all the time to the tune of 3.?? to 1, where you ideally need to be 1 to 1 or overdrive @ highway speeds ....neat idea btw and would make a great rockcrawler
Old November 12th, 2012, 16:13   #9
jimbote
jimbote's Avatar
spendy yes but this is it ... http://www.powertraincontrolsolution...anscontrol.php
Old November 14th, 2012, 12:12   #10
storx
Truck was being bought as I arrived
Beautiful donor
Da Diesel Build
Old November 14th, 2012, 13:21   #11
jimbote
jimbote's Avatar
Dang!!...hate to hear that....whenever I see a deal like that I send an email/message that I will take it for price asked no matter what....foot's in the door and refusal is still possible ....next time man!!...hopefully it won't be long before another pops up
Old November 15th, 2012, 09:45   #12
storx
I did offer upfront... They just I guess didn't believe me
Da Diesel Build
Old November 15th, 2012, 09:57   #13
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Originally Posted by SuperAdellic View Post
I am not aware of any 4dr rangers on the US market..
That's because they are called Explorer Sportrac.
oilhammer
www.cardocautomotive.com
Old November 15th, 2012, 10:19   #14
KITEWAGON
KITEWAGON's Avatar
It depends on how you define 4-dr. There are extended cab versions with rear doors that open just like the extended tacos. Unfortunately mine truck doesn't have those doors. I didn't think it would matter to me, but it is such a pain to retrieve stuff from behind the seats that I wish I had a door. 3-door would be enough.
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Old November 15th, 2012, 13:03   #15
storx
Ya I would accept 3 doors but I'm tired of 2 doors
Da Diesel Build
Page generated in 0.16237 seconds with 9 queries
[Output: 126.61 Kb. compressed to 104.79 Kb. by saving 21.82 Kb. (17.24%)]
