Old October 30th, 2012, 08:11   #1
dieselolds
Default Beeping noise while driving
Hi to everyone.I recently aquired a 02 jetta TDI.I've put maybe a 1000KM on it since buying it.It had a engine replacement in '09 due to a broken timing belt.I bought the car maybe two months ago and did alot of front suspension work,new filters,new brakes and so forth all around.
I replaced the timing belt,water pump and all pulleys,etc.I've changed the oil on it a few times to get the old dirty oil out of the engine.I'm using 5W40 Rotella T6 synthetic.Today for the first time the car makes a beeping noise while driving but stops when the car comes to a complete stop.The second the car moves forward the beeping noise starts again.There are no warning lights on inside the panel but only a flashing brake light,but thats been like that since I owned the car.
The check engine light is on but its a glow plug circuit fault.The ABS is on too,but that also has been that way since I bought the car.The noise is really bothersome so if you guys can offer some suggestions on what it could be,please let me know.
Thanks,
Chris
2002 Volkswagen TDI 1.9L sedan,Cold air intake kit,aftermarket headlight/tail-light kit,newly added fog light kit,chrome grill.
2013 Volkswagen Passat.....comfortline edition with 2.0 turbo diesel and 6 speed manual tranny.
dieselolds is offline   Reply With Quote
Old October 30th, 2012, 08:17   #2
cleaver
cleaver's Avatar
see my thread here:
http://forums.tdiclub.com/showthread.php?t=240956
check fuse #5....
Diagnosing Limp Mode
IMO, best place to buy VW parts in Canada: contact Brian @ www.roselandtech.ca
cleaver is offline   Reply With Quote
Old October 30th, 2012, 08:19   #3
cleaver
cleaver's Avatar
and this thread...
http://forums.tdiclub.com/showthread.php?t=271389
Old October 30th, 2012, 08:21   #4
Crankous
Crankous's Avatar
When I leave my handbrake on while I drive it makes a long beep noise... I would start there since there is already a problem having a flashing brake light on. I know it's been this way for a long time and the noise just now showed up but the flashing light shouldn't be on so it's a good place to start...
Crankous is offline   Reply With Quote
Old October 30th, 2012, 08:25   #5
Ski in NC
Fuel Economy: 48-52 typical
Check hand brake switch. Switch might think hand brake is engaged.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old October 30th, 2012, 18:09   #6
dieselolds
Thanks everyone for the replies.I'll look into this.
Old November 6th, 2012, 12:37   #7
cleaver
cleaver's Avatar
Did you get a chance to look at the problem? Hopefully some of our solutions have pointed you in the right direction.
Old November 7th, 2012, 06:57   #8
mittzlepick
mittzlepick's Avatar
Fuel Economy: 1175 record tank
if i recall ebrake on comes from fuse panel area and another from the instrument panel like in concert with and oil light
mittzlepick is offline   Reply With Quote
beeping noise mykel TDI 101 5 August 29th, 2010 04:33
Beeping alarm while driving?? elberto TDI 101 3 September 23rd, 2009 19:30
Strange beeping noise alarm while driving?? elberto TDI 101 3 September 18th, 2009 12:21
noise while driving Stan B TDI 101 4 September 12th, 2007 18:21
beeping noise when turning ignition volmaniac TDI 101 0 March 18th, 2005 12:31
Page generated in 0.14159 seconds with 10 queries
[Output: 85.88 Kb. compressed to 73.78 Kb. by saving 12.10 Kb. (14.09%)]
