Old October 30th, 2012, 05:45   #1
Gebre
Question VW 2001 Jetta Front seat replacement
Can 1999 VW Jetta front seats fit a 2001 VW Jetta?
Gebre is offline   Reply With Quote
Old October 30th, 2012, 10:24   #2
jessabug
jessabug's Avatar
Is it a '99 or 99.5 Jetta? As in, is it the same generation or not?
Hers: 2003 20thAE GTI, 3" 42DD turbo back, Unitronic Stage 2, 139k
His: 2001 Jetta TDI GL, auto->manual swapped, 165k
The old skool project: 1984 Jetta TD GL, 190k, 2.5" exhaust, Giles IP
jessabug is offline   Reply With Quote
Old October 30th, 2012, 16:00   #3
Gebre
Not sure, I pulled seats from a U-Pull it place from a 1999 Jetta, but the car is a 2001 VR6 Jetta. How can I tell if this Jetta is diesel?
Old October 31st, 2012, 15:45   #4
IXLR8
Doesn't matter if it is a diesel or not. The issue is the build date. They changed models in the middle of the year. So the seats from a car build in the second half of 99 will fit. Seats from the first half of the year might not. You need to find out if it is a MK3 or MK4 Jetta, MK4 will work, MK3 might not.
Jim Peck
'12 TDI Passat SE 6M, Platinum Gray w/Moonrock- 86,750 miles, 52 mpg. Buyback 12/16/16
'02 TDI Golf, 5 spd., 290K miles -PP520, RC3+ , VNT-17, Webasto, .68 5th gear.
IXLR8 is offline   Reply With Quote
Old October 31st, 2012, 19:43   #5
deejaaa
deejaaa's Avatar
Fuel Economy: 59 latest mpg
in other words, same body style?
there are changes between years that will throw a light because of airbags so it's best to get same year.
RIP Grams, 6-27-16
Originally Posted by stamar View Post
I am a tdi expert now.
A wise man told me "Cut Twice, Measure Nunce."
deejaaa is offline   Reply With Quote
VW Jetta Front seat replacement Gebre TDI 101 0 October 30th, 2012 05:39
2001 Jetta - Driver Seat Replacement Needed - Black Cloth JettaTDI8655 VW MKIV-A4 TDIs (VE and PD) 0 September 23rd, 2011 11:19
Front seat slider issue 2001 Jetta brandy TDI 101 0 January 11th, 2010 12:22
Front Seat removal - 2001 Jetta - Air Bag Alarm lotzamiles VW MKIV-A4 TDIs (VE and PD) 2 September 8th, 2003 13:20
removing front driver seat on 2001 Jetta JES General VW Discussion 2 May 2nd, 2001 03:49
Page generated in 0.07823 seconds with 10 queries
[Output: 69.02 Kb. compressed to 60.98 Kb. by saving 8.04 Kb. (11.64%)]
