Muleears
I'm having the Limp Home Mode problem that resets when the car is turned off and restarted. The car throws no codes. In searching I have found that the N75 valve and several turbo hoses could be the culprits. I can search the turbo hoses for leaks but I have no idea where the N75 is, if someone could describe or post a pic that would be great. Also I read of a ground wire chaffing through one of the turbo inlet hoses, where exactly does this take place? Do I need access from the bottom to see it? Any help is appreciated.
