Old October 26th, 2012, 20:27   #1
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
Default Darkside Developments CR140 GTB2260 turbo kit
Getting started / baseline:
I recieved the kit next day by DHL!
I volunteered to fit the kit to my US CR140, I guess the US had the CR cars before the UK.
A lot of work has been done by Storx too here
http://forums.tdiclub.com/showthread.php?t=357716
Here's Ryan's early mock up:
Note: the compressor outlet has been cut and rotated, Storx did this too, so it will fit close to the IC pipe
this is also the same turbo O.C.TDI http://forums.tdiclub.com/showthread.php?t=268968
used on his 2004 jetta with 248whp/433wtq
the kit included everything shown. the CR actuator, gaskets, bolt, modified turbo, header, oil feed and drian lines.
the header is made out of pipe, not tubing, so it is very durable.
this is a prototype, and it's fitment will be used to improve future kits.
I dyno'd the car with Performance-diesel downpipe 2-1/2" turbo back exhaust w/ cat and malone stage 2 tune and made 164 whp and ~285 wtq
the kit looks like the other dark side kits, with all the parts and gaskets below
with Audi GTB2260VK Turbo GS4 059 145 722 S
picture updated 10/29/2012
In preparation, I already installed:
Euro S3 IC
SouthBend Stage 3 Endurance Clutch
Pelequin Limited Slip Diff
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old October 26th, 2012, 20:27   #2
bhutchins
bhutchins's Avatar
Getting the EGR system out of the way is a lot of work. Anyone considering a turbo upgrade may want to go ahead and get the EGR removal kit for "off road use only" of coarse. I have Ryan's kit here The Anti Shudder Valve (ASV) is shown right below.
this is what it replaces.... I dont want that gunk in my intake!
you will have to drain the coolant (aka anti-freeze) to remove the EGR cooler. the stock fluid is known as G12
As much as I tried, I could not get the EGR cooler out with the subframe still in, so turn to the steering rack replacement section of the Bently's manual
Remove the subframe: Remove the 4-13mm (1/2") bolts, the 16mm (5/8") and the 18mm (no equal) and the subframe will drop off, which allowed for the removal of the EGR cooler.
Unbolt the axle from the trans. this will really make for a lot of room. alternately you can remove the pass. tie rod end bold, then unscrew it with the hex in the middle, and unbolt the swaybar link and push them rearward
Old October 26th, 2012, 20:27   #3
bhutchins
bhutchins's Avatar
the turbo's out, comparing the two...
Going in:
IT FITS!!!!
I had to unbolt the axle from the trans to make room, but it went in relatively easy
Its close to the firewall, and the hood seal, but there's room for movement. I taped thw wires in foil backed mastic "foilmastic" and flipped the firewall wire hold down upside down to raise them up
per Storx:
When you go to install the subframe center back, trace the bolt on passenger side that bolts to steering electric motor assembly and put that bolt in first on Center section
The bolt is the rear small one on passenger side
make sure the alignment pins are in their holes on drivers side before you install the rest of the bolts
Bentleys list bolt torque to 50Nm (37 ft-lb) + 1/4 turn (90 degrees) - Always Replace
the bolts to the sway bar bushings are 17 ft-lb + 1/4 turn, part numbers are either
10x76mm bolt: N 105 797 02 or
8x75mm bolt: N 910 734 01
Old October 26th, 2012, 20:28   #4
bhutchins
bhutchins's Avatar
the plastic IC pipes are restrictive, so had some sent from RyanP "across the pond"
Old October 26th, 2012, 20:28   #5
bhutchins
bhutchins's Avatar
234 WHP / 404 WTQ, uncorrected, on same dyno
stock fueling
Video
http://youtu.be/w27EMe1LGSM
no smoke until WOT
Click for full size pdf
for comparison
2014 5.0 mustang 420 HP @ 6500 -16% = 352 HP / 390 FT-LB TQ @ 4250 -16% = 390 ft-lb
2013 370Z 332 HP @ 7000 - 16% = 279 HP / 270 ft-lb @ 5200 - 16% = 227 ft-lb
2013 Nissan GT-R 545HP - 16% = 458 HP / 463 ft-lb @ 3200 - 16% = 389 ft-lb
Last edited by bhutchins; June 19th, 2013 at 10:54. Reason: added dyno resuts & comparison
Old October 26th, 2012, 23:14   #6
NewTdi
Fuel Economy: 58/46/39
Reserved for post 6!
This looks like a super look project!
03 MK IV Sedan 341k miles, BW S7 turbo, RC, PP764, SMIC, 3bar, SB Stage 2 end., PD130/150 TIP - NO SMOKE - Audi TT bushings, Koni Yellow, stock springs.[B]
03 MK IV Wagon 508k miles - GONE TOO SOON
Thank you MATT for the continued car care
NewTdi is offline   Reply With Quote
Old October 26th, 2012, 23:19   #7
oldpoopie
oldpoopie's Avatar
Eyes on this
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old October 26th, 2012, 23:30   #8
NewTdi
Justin, you have eyes in too many places! Thanks for the big turbo install; car runs great!
Old October 27th, 2012, 06:22   #9
KraftwerkB6
KraftwerkB6's Avatar
TDI(s): 2010 JSW
cant wait for this to happen and the build to start. super pumped.
cool stuff done to car goes here.
KraftwerkB6 is offline   Reply With Quote
Old October 27th, 2012, 09:14   #10
JFettig
JFettig's Avatar
I figured this was yours
JFettig is offline   Reply With Quote
Old October 27th, 2012, 10:28   #11
bhutchins
bhutchins's Avatar
Originally Posted by oldpoopie View Post
Eyes on this
if your just going to sit there and watch, you may as well lend a hand
it goes up on the ramps tomorrow
Aren't you running the 2260 also?
Actually I will need your expertise soon. I had bought that short block off the other Justin, I'm going to ceramic coat the pistons, and I already have the Rosten rods.
Old October 27th, 2012, 10:38   #12
dieselfuel
What kind of numbers are you expecting from this kit...335d like numbers...?
df
2003 Jetta TDI 200,000 mi. Horrible fuel milage? Check your thermostat: http://forums.tdiclub.com/showpost.p...49&postcount=7
dieselfuel is offline   Reply With Quote
Old October 27th, 2012, 10:45   #13
oldpoopie
oldpoopie's Avatar
Indeed I am. Also building up a pd to swap to, and will be using a gtb2260 water cooled
Old October 27th, 2012, 11:36   #14
storx
look what you get to enjoy aswell.. love this sound... man this turbo throws you in your seat once you get the vanes adjusted...
https://www.youtube.com/watch?v=w6JeHWsH4RQ
Da Diesel Build
storx is offline   Reply With Quote
Old October 29th, 2012, 16:09   #15
bhutchins
bhutchins's Avatar
updated the kit picture in post 1
Injector socket (T40055) works great for removing the stock turbo oil feed line
man is that EGR stuff hard to get off. the EGR filter back bolt is hard to get to. the turbo oil drain line is in the way, my 3/8 drive socket might work if I had a 2" extension (4" is too long) and I cant get a standard wrench on it either. off to the harware store.
Update: the 1" extension worked perfect
CR140 Big Turbo Build storx TDI Power Enhancements 866 August 22nd, 2014 06:57
turbo garrett gtb2260 for sell moivw Private TDI Items for Sale/Wanted 0 November 17th, 2011 10:40
Darkside GTB Turbo Kit for 2.0 16v BKD Engines ryanp Vendor & GroupBuy items for sale 0 September 20th, 2011 09:39
Darkside Developments domdom TDI Power Enhancements 8 April 24th, 2011 09:24
Page generated in 0.20598 seconds with 10 queries
[Output: 138.80 Kb. compressed to 115.73 Kb. by saving 23.08 Kb. (16.62%)]
