Old October 24th, 2012, 20:30   #1
TurboDieselPoint
Default Cabin Air Filter
Ok, just curious, is the cabin filter in the Passat located BEFORE the A/C evaporator and the heater core so that it will keep crap from collecting in the fins on both of them? Where exactly is it located?
Thanks in advance!
TurboDieselPoint is offline   Reply With Quote
Old October 24th, 2012, 23:56   #2
vw_norm
Gone, but not forgotten.
Yes. The cabin filter is located above the passenger footwell trim panel in the a/c unit. It is removed from the bottom of the assembly after removing an access panel on the a/c heater unit. The filter is placed between the fan/outside air intake and the heater and a/c cores. It also is equipped with activated charcoal as part of the filter element.
vw_norm is offline   Reply With Quote
Old October 25th, 2012, 06:17   #3
Ace Deprave
I was recently wondering about this myself. Sounds like it's easy to get to...my 2008 Mazdaspeed3's cabin filter was a huge pain to get to...I had to remove part of the dash, the glove compartment, and an assortment of other things to access it. I think it took me 2 hours to do, and that's with watching a youtube instruction video. Thankfully, I won't have to change that one again!
Ace Deprave is offline   Reply With Quote
Old October 25th, 2012, 18:47   #4
TurboDieselPoint
So the path is:
A). Outside Air -> Filter -> Fan -> A/C Evap/Heater Core -> Vents?
or
B). Outside Air -> Fan -> Filter -> A/C Evap/Heater Core -> Vents?
Old October 25th, 2012, 21:12   #5
Lightflyer1
Lightflyer1's Avatar
My experience has always been B in the past. Fans push air better than they pull it.
Old October 26th, 2012, 00:19   #6
vw_norm
Here is an exploded view of the HVAC box. 23 is the A/C Evaporator, 22 is the Aux heater (TDI only), 21 is the heater core, 19 is the dust/pollen filter, 18 is the cover for the filter, 17 is footwell access cover, 16 is the fan/blower, 11 is the condensation water drain hose with valve, 9 is the outside air intake. Air flow is right to left (Option B above).
Old October 26th, 2012, 09:28   #7
unixb0y
Originally Posted by TurboDieselPoint View Post
So the path is:
This is how it's done on the MKIV. The filter is accessed from the engine compartment and fresh air is taken from below the windshield.
There are hood gaskets that prevent engine bay air from being used.
unixb0y is offline   Reply With Quote
Old October 26th, 2012, 10:16   #8
compu_85
Gadget Guy
compu_85's Avatar
Speaking of the Aux heater... did we confirm TDIs have them?
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old October 26th, 2012, 14:39   #9
Nebelwerfer
We must have something. The temps here have been around -5C every morning and the engine is cold.
I crank up the heat to about 25C and I'm getting warmth in about a minute. It's not a lot, but its better than ice cold air.
Regards
Nebelwerfer is offline   Reply With Quote
Old October 31st, 2012, 12:54   #10
ng3
ng3's Avatar
According to the pic the Aux heater is #22
12 VW Passat Trend+ 2.0l DSG
ng3 is offline   Reply With Quote
cabin air filter quick6black VW MKIII-A3/B4 TDIs 1 September 20th, 2008 12:16
Cabin Air Filter... Jeepmb TDI 101 7 September 16th, 2008 20:37
Cabin Air Filter chopprs TDI 101 5 August 5th, 2008 07:00
Where is my cabin air filter? scythefwd TDI 101 8 August 14th, 2006 04:49
Cabin Air Filter - "pollen filter" on a NB cattlerepairman VW MKIV-A4 TDIs (VE and PD) 7 June 28th, 2004 13:21
Page generated in 0.17067 seconds with 10 queries
[Output: 97.40 Kb. compressed to 82.92 Kb. by saving 14.48 Kb. (14.87%)]
