Old February 28th, 2018, 07:52   #91
Gttdigonewrong
TDI(s): gttdi 170
Talking
Has anyone ever solved this problem with cam sensor fault. My 2007 gt tdi has been in 2 different garages now and not fixed in 2 years. Sam fault code as cam shaft sensor.
It’s had:
New ecu 3 times in 2 years
Cam Belt and pulley etc..
Fuel pump
New wiring loom
New cam and crank sensor
Tried all the earths around the whole car
Still not running any help?????
Gttdigonewrong is offline   Reply With Quote
Old February 28th, 2018, 09:57   #92
oldpoopie
oldpoopie's Avatar
Check engine harness for damage... particularly on top of the starter area but anywhere really where it is enclosed in corrugated loom
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old February 28th, 2018, 10:18   #93
Mawcus
Fuel Economy: 41 mpg
Originally Posted by Doca View Post
I have the long start implausible signal on the cam sensor on a 2008 BEW. I have replaced the sensor & the starting is identical if I unplug the sensor so I think I have a wiring fault. Can anyone tell me the where the 3 wires go to? what are the ECU pin nos?
Thanks.
Check the cable from the alternator to the battery and make sure all your battery connections are tight and dont wiggle.
This might help to
http://forums.tdiclub.com/showpost.p...28&postcount=1
http://forums.tdiclub.com/showthread.php?t=444620
http://forums.tdiclub.com/showthread.php?t=245327 Post #5
It could also be a bad “new” cam sensor. I was getting a cam sensor code. Intermittent-no signal so i replaced it with a new one from a reputable vendor. It failed within a year or two. After chasing around other long start problems and replacing a lot of sh$t i probably didnt need to I reinstalled the original cam sensor and the starting problems went away. I mistakenly replaced a good sensor because the intermittent-no signal fault code i was getting was probably because of a voltage drop between the alternator and battery.
Mawcus is offline   Reply With Quote
Old February 28th, 2018, 11:41   #94
JB05
Fuel Economy: 43/41/40
I changed my cam sensor the other day although there were no DTC's or long starting cranks. Getting the new sensor in place and keeping it there to put the bolt back in was very tedious. Took several attempts along with a few breaks. I locked the bolt in the 10mm socket with the finger tip of a disposable glove and had a rag under the work area. Got a new grommet from a dealer.
Since the crank sensor cable was susceptible to heat damage, which I changed last month; I figured the cam sensor could go at any time.
JB05 is offline   Reply With Quote
Old February 28th, 2018, 14:23   #95
fruitcakesa
Fuel Economy: 40's
Compared to my ALH's which almost would start with the heat of my fingers on the key, the 04 was a long crank starter from day one.
It always started but it usually required a few seconds of cranking and often more. But never enough of an issue to diagnose and fix
I did search the forum and found a TSB for a wire fix in the ECU that addressed long crank times. I bought the repair wire and immediately put it in the glove box.
More recently the car threw a cam position sensor code.
This time I addressed the issue and replaced the CPS.
Pretty straight forward install if you remove anything that could possibly interfere with hands and tools when placing and securing the sensor and if you pull the vac reservoir it makes getting the new rubber plug back in without dropping it into the nether regions of the engine
TOTALLY FIXED. Starts instantly like the ALH's
2004 Jetta TDI wagon 5 speed 278k+ VNT 17 Kerma tune. new heater core
fruitcakesa is offline   Reply With Quote
Camshaft position sensor Indwelling VW B5 Passat TDIs 30 February 25th, 2013 12:40
What does the Camshaft Position Sensor read off of? unseenthings VW MKIV-A4 TDIs (VE and PD) 14 September 21st, 2012 15:48
camshaft position sensor hgsmith TDI 101 17 February 14th, 2012 09:07
camshaft position sensor Seated OBD Scanners 1 October 8th, 2011 05:21
Camshaft Position Sensor (G40): No Signal lirunaway VW MKIV-A4 TDIs (VE and PD) 1 August 11th, 2011 17:55
Page generated in 0.13191 seconds with 10 queries
[Output: 73.69 Kb. compressed to 65.56 Kb. by saving 8.13 Kb. (11.04%)]
