Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > TDI Cars for Sale/Wanted
TDI Cars for Sale/Wanted VW TDI/Diesel cars for sale and wanted.
Old October 15th, 2012, 23:57   #1
mrowens33
Default 2006 Jetta TDI bad DSG -$6000, Is it worth it?
http://milwaukee.craigslist.org/cto/3323483579.html
I talked to the owner of this car and it's pretty clear there is a major issue with the DSG- possibly a OEM broken flywheel. Is it worth buying and towing to Jason (GURU) in Madison for a rebuilt DSG ? Would it be worth offering $4500 or less?
mrowens33 is offline   Reply With Quote
Old October 16th, 2012, 03:52   #2
showdown 42
TDI(s): 2012 touareg
Quick answer NO. 200K on the OD with issues. You can do better I'm sure. The DSG issues have been discussed and they are expensive. IMHO move on..JP
showdown 42 is offline   Reply With Quote
Old October 17th, 2012, 08:39   #3
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
I think it is a good question for Jason to answer. Personally, I have little use for automatic transmissions. They are expensive to maintain, waste fuel and they are expensive to replace when they go kerplunk. Are you prepared to handle the worst case scenario of a $5(k) expense in addition to what else could be tooefed on the car?
So, other then speculating on what is wrong, as opposed to what could be wrong, buying it without knowing begs the simple question: Do you feel lucky, well do you? Good luck ...............
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Dallas/Ft. Worth 02 Jetta TDI Automatic, $6000 OBO jbfisher TDI Cars for Sale/Wanted 0 August 3rd, 2012 21:42
Looking at a 2006 jetta tdi dsg rstone VW MKV-A5 Golf/Jettas 3 December 13th, 2011 10:01
2006 Jetta T.D.I.,5 speed clutch For Sale with only 6000 miles micmoran Private TDI Items for Sale/Wanted 0 May 8th, 2011 16:30
Looking for 2006 TDI Jetta w/DSG Freebore TDI Cars for Sale/Wanted 2 November 24th, 2008 16:02
New 2006.5 Jetta TDI DSG gabes97 TDI Fuel Economy 6 April 4th, 2007 08:15
Page generated in 0.12383 seconds with 10 queries
[Output: 58.80 Kb. compressed to 53.50 Kb. by saving 5.30 Kb. (9.02%)]
