Old October 10th, 2012, 10:13   #1
jjcsnlynn
jjcsnlynn's Avatar
Default Stumbles after starting
This summer I replaced the gaskets on my injection pump and last year I changed the timing belt. After chaning the timing belt, I posted my timing numbers and the only comments from the forum were 'maybe raise it a little to help with cold starting".
Shortly after changing the gaskets on the drivers side and top of the pump housing, I noticed the enging stumbling a second or two after starting. It recovers itself and everything is fine, but it started getting colder this week and it seems to be a bit worse. It's not cold enough for glow plugs, but I'm thinking it will be worse as it gets colder.
I put the IC (I think it's called) on 10 after I changed the gaskets.
Any suggestions?
02 Jetta TDI (5-Speed)
03 Jetta TDI (5-Spd Wife's)
96 Passat TDI (5-Speed Son's)
04 2500 HD Duramax Diesel 4x4
jjcsnlynn is offline   Reply With Quote
Old October 10th, 2012, 10:33   #2
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
air getting into the pump while sitting?
IQ set too high?
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old October 10th, 2012, 11:09   #3
Abacus
That helpful B4 guy
Abacus's Avatar
If by IC you actually mean IQ (Injection Quantity), then 10 is your problem, you're underfueling. It should be more like 3-9, with lower number running and starting better but giving slightly more smoke. I run 2.8 in the wife's B4, 3.8 in the wagon, and 5 in the sedan due to a worn turbo not providing enough air resulting in more smoke on acceleration. More than 5 on the '97 and it starts harder with reduced perfromance.
Adjust the IQ adaptation setting to 32768 then hammer mod it to an IQ of about 5, then adjust with the Vag-Com from there to get your desired results, which will vary by individual car, driving style, and preference.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Old October 10th, 2012, 17:37   #4
jjcsnlynn
jjcsnlynn's Avatar
OK, I use the link on this forum and I'm pretty sure it stated 10, but I will give it a try. Do I need the special key to do the hammer mod? I borrowed the tool and have given it back to the owner.
Old October 11th, 2012, 06:20   #5
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
You will need the tool to slightly loosen the QA housing. And, by hammer, we mean lightly tap the QA housing. I have successfully used a small block of wood. It really doesn't take much.
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old October 11th, 2012, 06:39   #6
Abacus
That helpful B4 guy
Abacus's Avatar
I can send it back if you need it, but I'm doing an IP reseal this weekend and will need it then.
Old November 3rd, 2012, 18:44   #7
jjcsnlynn
jjcsnlynn's Avatar
Abacus,
I just checked my IQ (sorry, it's been a while. I have some issues at the house right now). When I started it the IQ was about 8, but as is smoothed out it's now down to 3.0-3.4.
I don't know how to do the adaptation. Can you send me directions?
Also, now that it's cold and the GPs are coming on, I smoke a whole lot when I start it up. It lasts for about 2 minutes then goes away. It's only done this since getting cold and it looks like fuel smoke. I think I've always had one FI that is leaking down. Could this be the cause or is it the extra fuel being injected since its cold. If so, Can I disable the extra fuel?
Old November 4th, 2012, 05:55   #8
TonyJetta
How many miles on the injectors?
Tony
new Passat sometimes stumbles at partial throttle 04Passat VW B5 Passat TDIs 217 October 18th, 2011 21:02
Jetta stumbles-Out of ideas rc_y2kws6ta TDI 101 16 February 12th, 2008 19:43
engine stumbles and looses power drawred TDI 101 5 June 6th, 2007 09:59
Engine stumbles when cold D_C VW MKIV-A4 TDIs (VE and PD) 0 December 2nd, 2006 17:53
Engine stumbles/firing problem? Zin TDI 101 2 October 23rd, 2006 10:42
Page generated in 0.13225 seconds with 10 queries
[Output: 90.80 Kb. compressed to 78.34 Kb. by saving 12.45 Kb. (13.72%)]
