My VW has had a slow draw since I bought it in 04. I do not know the source. If I dont run it, somewhere around 2 weeks it will not crank to start due to low battery. I have a smart charger that shows amps xx.x its putting to the battery. I have observed quite a bit over the years as I hit the battery with the charger at least every 1-2 months to make sure it's up and note how low it was if at all.
For about a week I had the dead radio. Pulled the #42 fuse for over a half hour, didnt fix it, disconneted the battery overnight and it came back to life.
The thing is, during that week, I hooked the charger up 2-3 times after an overnight first and then for a few hours in the garage after driving it for more than an hour. I notice the charger was having to put much more than usual back in. I never hooked an ammeter up to see what the draw is, but based on what I saw it was at least 2-3 times larger than my normal 'built in' draw which has lasted many years and in fact likely made my last new battery last only 3 years due to all the voltage cycling. In fact I have considered whether to use a deep cycle next time. Last replacement I put in a battery something on the order of 20-30% larger than the factory size.
I felt the radio, never felt unusual or warm as if it was really on, or some component in it was wasting heat. Anyone every witness this during the dead radio bouts I am sure many of us have witnessed. If you haven't, or didnt know to look, when you get a dead radio, see if you see the mystery draw I did.
Any EEs or electronic familiar with an explanation for this case?
