Old October 1st, 2012, 17:18   #1
Tony K T
TDI(s): 1998 jetta
Default idle speed control
I have a 1998 jettd tdi.I can't find the idle control adjustment screw.Can anybody tell me where it is?Is it possible that it has been removed,and the vehicle will still operate?I have a Haynes book that shows everything on diesels,but the screw is no where to be found.
In N.H.,Tony.
Tony K T is offline   Reply With Quote
Old October 1st, 2012, 17:49   #2
Ski in NC
Fuel Economy: 48-52 typical
No idle adjust screw. Computer controls idle rpm. What is your rpm?
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old October 1st, 2012, 17:52   #3
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
You need Vag Com...
Where in NH are you?
I have Vag com here at the ho5g..
OH Haynes is useless.... you need the Bently you can look at mine.
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old October 1st, 2012, 17:53   #4
PeterV
PeterV's Avatar
Also wrong section.. you have an A3. Not an A5.
Old October 1st, 2012, 17:53   #5
A5INKY
Fuel Economy: pretty good
Right answer to your question, but wrong section to ask it. This would have been a good one for the "101" section.
If the idle is not quite right, have you checked your float levels or synced your carbs? (sorry, couldn't resist)
A5INKY is offline   Reply With Quote
Old October 1st, 2012, 17:56   #6
PeterV
PeterV's Avatar
Or east coast he needs local help.
Old October 1st, 2012, 17:58   #7
Tony K T
TDI(s): 1998 jetta
I haven't checked anything.All I have done is looked for the control adjustment screw.I am in Seabrook,N.H.Where in So. N.H are you?
In N.H.,Tony
Old October 2nd, 2012, 06:33   #8
jdhunt0
jdhunt0's Avatar
TDI(s): 2005.5 Jetta
Since we are on the topic, sort of, is there a way to adjust idle rpm on the MKV with VCDS?
jdhunt0 is offline   Reply With Quote
Old October 2nd, 2012, 07:43   #9
A5INKY
Nope. A tuner can in the tune software though.
Old October 2nd, 2012, 07:54   #10
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
In N.H.,Tony.
Hrm, evidently not. EDC has been around since 1985, TDIs have been around since 1990, and been sold here since 1996. Not exactly "new" technology. Was that Haynes manual written in the '60s? Lots of things have progressed since then.
Your manual may be showing information on the AAZ engine, which is a more old-school mechanical control diesel engine available in that car in Canada, but not in the USA.
oilhammer
www.cardocautomotive.com
code 1562 speed idle control ba843 TDI 101 3 June 21st, 2012 06:16
Testing quality of combustion using idle speed smooth running control DarrenUK Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 16 November 13th, 2007 09:28
idle speed smooth running control gottdi VW MKIV-A4 TDIs (VE and PD) 2 August 29th, 2006 14:05
P1556 Idle Speed Control marklang VW MKIV-A4 TDIs (VE and PD) 1 May 27th, 2004 23:16
Idle Speed Smooth Running Control Question Denis OBD Scanners 7 May 19th, 2003 08:37
Page generated in 0.13606 seconds with 10 queries
[Output: 97.64 Kb. compressed to 82.72 Kb. by saving 14.93 Kb. (15.29%)]
