Old September 30th, 2012, 16:29   #1
Benna
Fuel Economy: 39.6
Default Trying to find a part. Please help
Hey fellow tdi'ers.
I have a 99 beetle 1.9 tdi. I recently lost all gears while driving.
After thinking it was a broken cable then an adjustment.
After some careful tear down I found out the "female" spline metal piece that is attached to the counter weight was worn. Now I was able to use a 1/2" washer to make temporarily usable. It needs replacing and I have no idea what the part number or even name is. Anyone that can help I appreciate it. Thanks
Benna is offline   Reply With Quote
Old September 30th, 2012, 16:47   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
I take it you mean number 8 in this pic?
What's your gearbox code?
Seatman is offline   Reply With Quote
Old September 30th, 2012, 17:02   #3
Benna
Fuel Economy: 39.6
No 8 is the shaft that goes into the tranny. It's the piece of like 1/16" metal maybe 2 inches by 1 inch. It slips over the splines on #8. The counter weight is bolted to it.
Old September 30th, 2012, 17:02   #4
Benna
Fuel Economy: 39.6
Where is the gearbox code located?
Old September 30th, 2012, 17:37   #5
Metalhead
Metalhead's Avatar
Fuel Economy: 40/44/49
In the trunk, near the spare tire location, I believe. It gives engine code, transmission code, and paint color. It's' a little sticker. Could be wrong, that's where I remember it being.
I have a Hex-USB+Can VCDS cable, Metalnerd Rear brake tool, Metalnerd IP triangle tool, and Metalnerd Alternator bit set
Metalhead is offline   Reply With Quote
Old September 30th, 2012, 17:57   #6
Seatman
Seatman's Avatar
What linkage is in the new beetle? Is it the standard Mk4 affair?
Old September 30th, 2012, 20:20   #7
nkgagne
Fuel Economy: See Fuelly in signature
That beetle should have the 02A early mk4 linkage
Bone stock. Dieselgate Stage 1 reflash complete.
nkgagne is offline   Reply With Quote
Old September 30th, 2012, 20:26   #8
LNXGUY
LNXGUY's Avatar
Yup, same linkage as the 99.5 Golfs/Jettas.
Bill
LNXGUY is offline   Reply With Quote
Old October 1st, 2012, 06:23   #9
Benna
Fuel Economy: 39.6
Trans code ebj. Like I said its that plate that the counter weight bolts to that fits over the splined shaft. Thanks for the location metalhead.
Old October 1st, 2012, 07:01   #10
Seatman
Seatman's Avatar
That pic is all I can find on the 99 beetle, if anyone can tell me which number is the correct part I can give you the part number.
Old October 1st, 2012, 07:24   #11
Benna
Fuel Economy: 39.6
Is there any pics that show the counter weight out there? I may have to attempt to make my own piece. Matching the splines would be the hardest part.
Old October 1st, 2012, 07:52   #12
Benna
Fuel Economy: 39.6
Ok after exhaustive google searches. I believe I found the part. Gearshift lever pn 1j0711051b? Thanks for everyone's input. It helped me get into the right search parameters.
Old October 1st, 2012, 07:53   #13
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
i think it's called the shift actuator, you don't need the weight
...looking for old receipt, pat no.....
Old October 1st, 2012, 15:26   #14
Seatman
Seatman's Avatar
Ah yeh, is that #45 in this pic?
I've been looking at gearbox end but vagcat is written in an odd way.
Old October 1st, 2012, 15:28   #15
Seatman
Seatman's Avatar
Just found this with google too
http://www.ecstuning.com/Search/1j0711051b/
Try googling the part number, you might find a cheaper one on ebay.
where can i find this part Boilermn65 TDI 101 3 May 10th, 2010 22:08
How do I find Part # ? cod TDI 101 2 April 1st, 2010 19:16
Cannot Find Part Numbers Thurston_Howell TDI 101 1 May 7th, 2009 13:24
How to find OEM part # Flatlandflash TDI 101 3 August 28th, 2008 09:54
What is this part and where can I find it? imported_Fletch TDI 101 8 April 8th, 2005 06:55
Page generated in 0.10094 seconds with 10 queries
[Output: 120.23 Kb. compressed to 99.51 Kb. by saving 20.73 Kb. (17.24%)]
