Old September 29th, 2012, 05:08   #1
SVTWEB
Default Keyless Entry with Remote Start
So my 2013 JSW came with KESSY but it lacks the remote start option. So, before I try and re-invent the wheel, has anyone attempted to add this option to their KESSY equipped vehicle?
Thus far I have verified that the KESSY Computer 5K0959434B is used across the Jetta/EOS/GOLF/PASSAT/TIGUAN platform, of which the PASSAT/JETTA/TIGUAN has the remote start as an option.
Could it be as easy as a coding issue on the KESSY Module and the pairing of a 4-button remote? Could VWOA as a cost-savings issue, provided only the 3-button remote on the JSW???
I acquired a new 4-button remote from a vendor on eBay so we'll see how it goes.
NOTE TO TROLLS: The words "can't be done" do not exist in my vocabulary. Only thing I can't do is give birth....
2010 Jetta TDI 6-Speed
2001 BMW R1200C Phoenix; 2012 BMW K1600GTL
2014 Ford F150 Raptor; 2017 Ford Escape
SVTWEB is offline   Reply With Quote
Old September 29th, 2012, 06:47   #2
Onefast66nova
TDI(s): 2014 golf
I install remote starts and keyless all the time. Yes I can be done but these cars so not heat up we'll at idle. You will be much better off installing a frostheater. I had this decision last year to make and could not be happier. As far as the kessy system being able to control it I can not speak to. I know adding a aftermarket system requires a bypass module and also a working ignition key in the vehicle to physically tie into the aftermarket remote start bypass. I know I didn't really answer your question but hope it helped. Lol
Onefast66nova is offline   Reply With Quote
Old October 3rd, 2012, 10:36   #3
SVTWEB
The Factory 4-button key arrived today. Going to give my dealer contact a call and have him "Marry" the key to the car. I'll keep y'all posted....
Old October 3rd, 2012, 11:30   #4
twilsey
Since we know these cars won't heat up t an idle, what is your purpose for the remote start?
twilsey is offline   Reply With Quote
Old October 4th, 2012, 06:03   #5
SVTWEB
To be able to start a vehicle 1-2 Minutes before driving away can make a very big difference in longevity as the internals of the engine will have an opportunity to start to come up to temperature and the oil flowing well before placing a load on the engine. And, while the engine doesn't come up to temp, if you prepare ahead of time you can have the defrosters ready to go on startup....
Old October 4th, 2012, 06:40   #6
compu_85
Gadget Guy
compu_85's Avatar
Just an FYI... when you unlock the car to get in after a KESSY remote start the engine turns off, and you have to hit the start button again to drive off.
I agree that the short warmup before driving off would help things out though
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old October 4th, 2012, 07:39   #7
CsTDI
Fuel Economy: T2: 25-26avg/A6: 49
is there an issue with the glowplug cycle duration and remote start in lower temperatures?
'10 TouaregTDI, Campanella White, '15 JettaTDI, Platinum Gray, '11 GolfTDI, Blue Graphite (buyback), '01 JettaTDI (retired), '05PassatTDI (totaled), '06 TouaregTDI, Campanella White (retired)
CsTDI is offline   Reply With Quote
Old October 4th, 2012, 07:49   #8
SVTWEB
The KESSY system will not allow the engine to start until the glow-plug light goes out.
Old October 10th, 2012, 14:35   #9
adz55
I'd be interested in this feature more for running the A/C in the summer before I get into the car. It can be over 150F inside a car in the summer where I live.
adz55 is offline   Reply With Quote
Old November 13th, 2012, 18:00   #10
79RabbitDSL
TDI(s): 09 JSW
Did you have any luck with this? I am very interested.
09 Jetta Sportwagen TDI
96 Harlequin VR6
79RabbitDSL is offline   Reply With Quote
Old November 15th, 2012, 10:26   #11
SVTWEB
Still working on this... Trying to get through the OEM LED HID issue with KESSY and the BCM. The things you must go through to be a trailblazer....
Old November 15th, 2012, 12:42   #12
79RabbitDSL
TDI(s): 09 JSW
Haha, I know right? Keep up the good work! and keep us posted.
96 Harlequin VR6
Old November 17th, 2012, 23:16   #13
BigDaadio
TDI(s): 13 jetta
I just purchased a 13 jetta (my 1st tdi) it was 18 f here the other day. I let her warm
For 10 minutes and I was blowing heat out the defroster. Is this not normal?
I don't want the remote start so much for warming the car ,
As I do the engine in these cold Adirondack winters.
There are a couple Canadien companies selling bypass interfaces.
Please keep us posted.
BD
BigDaadio is offline   Reply With Quote
Old November 18th, 2012, 14:55   #14
SVTWEB
@BigDaadio... That is my reasoning. I would love to be able to start the car and let it run for about 5-10 minutes in the morning to get all the juices flowing before I put a load on it. I working at it....
Old November 18th, 2012, 15:12   #15
compu_85
Gadget Guy
compu_85's Avatar
So they moved a bunch of things around on the BCM on your car too? I for the life of me can't figure out the logic behind behind it. For example, I'll have to move power for the trunk light and map lights to another pin because that output is for the left inner tail lamp on cars with HIDs
-J
Present:
Past:
Keyless entry remote not working powerram250 TDI 101 4 June 7th, 2010 20:27
Keyless entry remote not working?? dbdubb VW MKV-A5 Golf/Jettas 19 January 7th, 2008 15:57
New keyless entry remote crazy_canuck VW MKIII-A3/B4 TDIs 10 March 31st, 2006 18:11
Remote Keyless Entry Not Working Right Blue_Thunder VW MKIV-A4 TDIs (VE and PD) 9 July 13th, 2004 07:03
Remote keyless entry aketay VW MKIV-A4 TDIs (VE and PD) 4 February 19th, 2000 09:00
Page generated in 0.18629 seconds with 10 queries
[Output: 130.55 Kb. compressed to 109.16 Kb. by saving 21.39 Kb. (16.39%)]
