Old September 24th, 2012, 13:06   #1
Aridzonan
TDI(s): 2001 GOLF
Default Slow Death of a Vacuum Pump
I've got a 2001 Golf TDI with a 1.9l diesel. I had the joyous experience of cleaning out my totally obstructed intake manifold. Using the "Redneck" method http://www.youtube.com/watch?v=oet4qWeZuYA I also used a BBQ brush to clean up the carbon residue that was left. Immediately I got a boost. But, my vacuum pump was dieing slowly. My brake pedal got stiffer and finally no turbo and no Engine Codes. So, I swapped out my vacuum pump and still had a problem. This is in praise of Canadian_Grizzly's "Diagnosing and Fixing Limp mode for A4 1.9TDI". My problem was my N75 solenoid it did not have the prerequisite resistance (sub 25 Ohms). After changing the N75 Waste Gate solenoid and all of my vacuum lines as per Canadian_Grizzly's procedure http://forums.tdiclub.com/showthread.php?t=179589. I still had a problem. I had an inline vacuum check valve in backwards. Once I had that corrected my amazing VW TDI turbo came back to life with a vengeance. I also performed one other modification. I installed a BMW Oil Separator R29921664 in an attempt to mitigate Intake Manifold fowling. There are others oil separators on the market. I can't vouch for this one yet. Once again, thanks to Canadian_Grizzly for his sage post.
Aridzonan is offline   Reply With Quote
'04 PD sudden death after 2 blocks - Lift Pump? Beacher Ontario 23 February 11th, 2010 20:52
Rebuilt Injection Pump, Vacuum Pump, Pump Pulley Datsun1973 Private TDI Items for Sale/Wanted 6 January 16th, 2009 16:41
Power steering pump death(?) Vinyl_Addict TDI 101 6 September 8th, 2008 11:32
97 Passat Ignition switch dying a slow death. BHarrison VW MKIII-A3/B4 TDIs 27 March 14th, 2006 11:43
TDi Sudden Death Syndrome - fuel pump relay? awed Other VW Group TD(I)s 3 August 22nd, 2003 08:04
Page generated in 0.13188 seconds with 10 queries
[Output: 47.43 Kb. compressed to 44.75 Kb. by saving 2.68 Kb. (5.65%)]
