Old September 17th, 2012, 17:56   #1
captgravity
Default Timing Belt Noise
I just replaced my timing belt and serpentine belt and noticed a noise when I get up to >2500 RPM. The noise increases in proportion to the RPM and I would describe it as a valve letting off pressure -- shhhhhhh. Has anyone else experienced this or know what could be causing this? Thanks.
Car: 1999.5 Jetta TDI ALH MK4
New TB & Serp Belt: Contitech
New idlers: INA
New tensioner: Litens
New water pump: Geba
captgravity is offline   Reply With Quote
Old September 17th, 2012, 21:10   #2
audiphile
audiphile's Avatar
I think the noise you're hearing is a boost leak - you probably didn't clip the intercooler hose on all the way.
audiphile is offline   Reply With Quote
Old September 17th, 2012, 22:03   #3
captgravity
You were right about the intercooler hose. I made sure it was seated correctly and the noise went away. Unfortunately, now I don't feel the turbo boost and can't rev past 3000 RPM. Any ideas?
Old September 17th, 2012, 22:14   #4
audiphile
audiphile's Avatar
well, it's possible that the other end of the hose is now completely off, thus not allowing boost to build up.
or your ECU is in limp mode. is the check engine light on?
Come to think of it, you probably got the timing off by a tooth or two... or the injection pump is out of time.. did you use a pin to lock the pump? did you spin the engine by hand after installing the timing kit to make sure it aligns after 2 turns?
Old September 17th, 2012, 22:34   #5
vwjettadsl
vwjettadsl's Avatar
Make sure a vacuum hose did not come loose during the timing belt job. Its easy for a hose to come loose when you are raising or lowering the engine during the TB job.
I would look specifically at the vacuum hoses behind the intake manifold, those are the most common culprits.
Trusted TDI Mechanic traveling to: MO, KS, IA, NE, OK, AR, IL & TN (Plus more if requested)
Mobile Timing Belt Replacement, I travel to you
Malone Tuning Dealer, I offer mobile tuning service for ALL TDI's + CDI's
www.vwtdisales.com
vwjettadsl is offline   Reply With Quote
Old September 18th, 2012, 17:34   #6
captgravity
@audiophile: there was no check engine light, and I made sure to lock the IP, manually crank 2x, and then fine tune with a Ross-tech cable.
@vwjettadsl: I went over all the vacuum hoses and found the hose leading into the vacuum pump was kinked from when I moved it out of the way during the timing belt procedure. Turbo is now back and I no longer feel impotent when I drive.
Thanks both for the help!
Old September 18th, 2012, 18:14   #7
vwjettadsl
vwjettadsl's Avatar
Glad you found the problem! I figured it was something simple.
www.vwtdisales.com
Old September 18th, 2012, 18:20   #8
audiphile
audiphile's Avatar
sweet!
Timing belt noise LucasTDI TDI 101 10 February 1st, 2010 16:23
Timing belt noise TDC VW MKIV-A4 TDIs (VE and PD) 11 June 2nd, 2004 20:13
Timing Belt Noise VocalVirgo VW MKIV-A4 TDIs (VE and PD) 2 January 4th, 2003 01:21
Timing belt noise! aluminum TDI 101 1 October 21st, 2002 15:23
Page generated in 0.12588 seconds with 10 queries
[Output: 86.22 Kb. compressed to 74.20 Kb. by saving 12.03 Kb. (13.95%)]
