Old September 9th, 2012, 10:41   #1
Thelawnboy54
Fuel Economy: AVG 46-48
Default Kerma TDI
Has anyone used Kerma TDI products? I'm interested in the Q Loader on my 04 Pump Duse. The only mod I'm looking to do us remove the EGR because the cooler pipe broke. Any help/suggestions?
http://www.kermatdi.com/servlet/the-...sh-/Categories
Thelawnboy54 is offline   Reply With Quote
Old September 9th, 2012, 20:47   #2
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Kerma is known for years and it is very GOOD and very Trusted Vendor.
http://forums.tdiclub.com/member.php?u=1704
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old September 10th, 2012, 10:12   #3
penclnck
I'll vouch for them. When an issue came up the first time my car was flashed, no fault of Kerma, they went above and beyond to help me out for something out of their control.
I've had a few minor tweaks and some reflashes as well, turn around times have been pretty good.
My wife and I are happy with our flashes.
Pencilneck blah blah blah
penclnck is offline   Reply With Quote
Old September 10th, 2012, 10:14   #4
JarHead
JarHead's Avatar
Same with me. Very happy with the tune and Charlie's customer service!
"Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem."
PRESIDENT RONALD REAGAN, 1985
"There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion."
JarHead is offline   Reply With Quote
Old September 10th, 2012, 20:36   #5
diesel4ever
diesel4ever's Avatar
Fuel Economy: 4.2/4.8/5.5
I have Kerma tune on my BEW. Not only i got more power, it improved my fuel economy.
2004 Jetta TDI Sport, KERMA Tune, VNT17 Turbo, 505,000km
2004 Jetta (hers), KERMA tune (otherwise stock), auto, 365,000km.
diesel4ever is offline   Reply With Quote
Old September 11th, 2012, 07:56   #6
BobnOH
Fuel Economy: 50/45/35
don't know a lot about the actual tunes, but that Q-Loader is sweet, allows you to port multiple tunes
Old September 14th, 2012, 03:54   #7
Spätzle Burner
Spätzle Burner's Avatar
Fuel Economy: 43 average... Needs to get better... Cooler temps 46.6 mpgs!
Yah, they are good folks to do business with. Charlie has spent hours helping me with an issue that had nothing to do with a Kerma product. I try to buy as much from them as possible, b/c they earned it.
Panzer Plate, New South boost pressure and EGT gauge, Q-loader, Kerma 2.5 turbo down pipe with 2.5 SS exhaust w/ cat only, ebay fmic( ask me why!), and Kerma 1856, Kerma OMI modified to fit a BEW, R32 in-take, PD150 intake manifold, BFI stage 2 mounts, Peloquin limited slip, SBC Stage 3 End, O2M six speed... R783's, E-Codes, shine rear sway bar, Bilstein HD's and Shine springs. 2 liter long-block next!
Spätzle Burner is offline   Reply With Quote
Old September 14th, 2012, 09:46   #8
karter59
I can't say enough good things about Kerma and Charlie's tunes. I've bought many things from them and never had any issues.
karter59 is offline   Reply With Quote
Old September 25th, 2012, 07:15   #9
thundershorts
lawnboy, if you're in Red Lion Pa, have you considered Rocket? You might find it less expensive and better service.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old January 19th, 2013, 09:54   #10
Thelawnboy54
Wow!! What amazing service I got from Jeff @ Rocketchip!!! He spent 3 hours with me(1st time TDI owner) goin over different things with my car! Checking various known problem spots and making sure my car was 100%!! I couldn't have ever imagined better service!! All the time he spent with me and no additional charges!! I have a MK4 PD and just got my first 50+ mpg tank thanks to his chip!!! I was never able to break 50, with 49.5 being my best! 51.5 achieved this tank in the winter coldness and winter blend fuel!! I couldn't be happier and would recommend Rocket Chip to anyone!!
Kerma tdi? Acesebulba VW MKIV-A4 TDIs (VE and PD) 35 October 3rd, 2015 17:26
Thanks Kerma TDI! Ookpic TDI Power Enhancements 5 January 23rd, 2009 19:04
A3/B4 WGT Super 17 hybrid turbo on Kerma, question for Kerma, etc. akampion TDI Power Enhancements 14 January 9th, 2009 10:17
TDI Kerma ? kcb VW MKIV-A4 TDIs (VE and PD) 3 January 10th, 2005 16:59
Kerma TDI displaypack VW MKIV-A4 TDIs (VE and PD) 7 September 15th, 2004 20:12
Page generated in 0.17373 seconds with 10 queries
[Output: 95.16 Kb. compressed to 80.70 Kb. by saving 14.46 Kb. (15.19%)]
