Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2012
TDIFest 2012 Discussion about TDIFest 2012 on the Labour Day weekend (August 31st to September 2nd, 2012) in Ypsilanti (Ypsi), Michigan.
Old August 31st, 2012, 12:51   #1
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Default Double DIN removal tools desired at 'fest
My radio has quit. I still have the flashing red anti-theft lamp, fuse 42 is good and the lighter socket is still powered. VCDS does not recognize the radio (controller not present). It does not power up at all to even provide the "safe" code access.
The earlier (A3 /B4) radios had a second fuse on the back of the radio itself and I'd like to pull the radio in this A4 to check if it also has an on-board fuse.
If you're at the fest, and have removal tools that will work on a double DIN sized, non-Monsoon, head unit, I'd like to hear from you.
If you're in the Marriott leave a message in room 507 or you might find me near the blue Jetta pig near the yellow Saab pig in the parking lot.
Svante Arrhenius 1896
Old August 31st, 2012, 12:52   #2
diesel4ever
diesel4ever's Avatar
Fuel Economy: 4.2/4.8/5.5
I am coming tomorrow and will try to remember to bring them.
2004 Jetta TDI Sport, KERMA Tune, VNT17 Turbo, 505,000km
2004 Jetta (hers), KERMA tune (otherwise stock), auto, 365,000km.
diesel4ever is offline   Reply With Quote
Old August 31st, 2012, 18:42   #3
loganbmx4gt
loganbmx4gt's Avatar
I have a radio removal tool. Not sure its what our needing. Im your neighbor BTW, 508.
loganbmx4gt is offline   Reply With Quote
Old September 1st, 2012, 13:10   #4
Lug_Nut
Lug_Nut's Avatar
Thanks again for the use of the tools. Although the fuse on the radio also checked out to be OK, and I thought the radio was completely dead, when I plugged the electricals back in it came to life.
For how long? Who knows. I haven't locked it back into it's mount so I can remove it if it quits again and try unplugging it and plugging it in again.
Old September 3rd, 2012, 10:51   #5
Cooper
I have the tools if you need them after you get back.
Cooper is offline   Reply With Quote
Old September 4th, 2012, 17:35   #6
Lug_Nut
Lug_Nut's Avatar
It's still working. My trips are much shorter so I could deal with the silence for 10 minutes that I couldn't for 10+ hours.
I'll be ordering a set for myself.
WTB: MKIV Jetta Monsoon Double Din removal tools TDI_ROLLER Private TDI Items for Sale/Wanted 2 May 19th, 2011 14:37
FS: 42DD MKIV Double Din Radio Removal Keys letterman52 Private TDI Items for Sale/Wanted 1 November 25th, 2010 19:48
WTB or Borrow Double Din Radio Removal Tools aja8888 Private TDI Items for Sale/Wanted 5 October 20th, 2008 18:21
Anybody have the double din radio removal tools (2001-2005) that they will let me beg Jeff Heyerman Ontario 8 June 27th, 2008 16:02
FS: Monsoon (Double Din) Radio Removal Tools Brio Private TDI Items for Sale/Wanted 0 January 13th, 2007 15:55
Page generated in 0.16307 seconds with 10 queries
[Output: 75.63 Kb. compressed to 66.08 Kb. by saving 9.54 Kb. (12.62%)]
