Old August 29th, 2012, 14:38   #1
rolotomassi44
Default Car won't start, will turn over but not start. Help please!
This sucks,
So I made the trip back to Indiana safely. No problems really.
I go to start my car just now, temp on display says 92F. Car starts and dies immediately. I cycle the ignition a few times (in case some priming was needed). The engine turns over perfectly fine. But it won't start!
Now keep in mind my red led dash display fades with heat. On the last turn a coolant light came on and said something like "top of motor", well that's all I could make out anyway. I just ordered a vagcom off eBay. It should be here before Sept 4th. No check engine light has come on.
Help me!
rolotomassi44 is offline   Reply With Quote
Old August 29th, 2012, 14:41   #2
rolotomassi44
Oh did I mention my car was towed yesterday? My landlord had made a mistake. There was no noticeable damage and it was dollied. Car drove perfectly fine afterwards and started fine.
Old August 29th, 2012, 14:59   #3
rolotomassi44
Tried again, no warning came on. Still won't start.
Old August 29th, 2012, 16:25   #4
hevster1
TDI(s): 98 NB
Fuel Economy: 40-42
Umar, I am assuming it cranks ok. It could be as simple as a clogged fuel filter or bad in tank fuel pump. Pull the fuel line from the tank, have someone crank it and see if fuel comes out. It is only 5psi but it should flow. It could be electrically related, such as no power to the fuel pump or ecm for example. It could be a blown fuse. Check all fuses. A locked turbo could cause a no start as well. Disconnect the intake tube and if it starts up that is probably the cause.
If it doesn't crank well, it may be a bad starter or battery.
NJ's best shop performing Quality Repairs on TDI's, Toyota, Lexus, Scion and other European and Asian cars as well as Motorcycles & ATV's. Written warranty, reasonable prices. ASE L-1 & A-9 Master re-certified. NEW LOCATION: Montague NJ. Hunter Wheel Alignment. Snap-on Tire Service.I don't need to have specials, my prices are better already!
www.mmautocycle.com
hevster1 is offline   Reply With Quote
Old August 29th, 2012, 16:29   #5
thundershorts
what do you mean by warning? when you turn key on do you have a mil light (cel)?
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old August 29th, 2012, 16:47   #6
thundershorts
fast or slow cranking speed?
Old August 30th, 2012, 07:29   #7
rolotomassi44
Managed to start the car with my spare key. After doing so, my normal key starts it now.
Old August 30th, 2012, 08:10   #8
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
???Gremlins???
-George Bernard Shaw
Old August 30th, 2012, 08:22   #9
rolotomassi44
haha, I have no idea. It was REALLY hot yesterday (but that hasn't stopped it starting before). I'm thinking it could be the immobilizer in the key, strange enough, considering it decided to start this morning.
Old August 30th, 2012, 09:11   #10
BobZ
Does the glow plug illuminate when turning the key to the "on" position when it does not fire up? If it does not - replace relay 219. http://forums.tdiclub.com/showthread.php?t=245377
80a fuse is for the glow plugs
15A fuse is for the injectors
10A fuse is for the heated oxygen sensor
219 is the power relay for the ECM, and also supplies power to the fuel pump relay.
05 Passat owned since new, chainless since 120,000 with Franko6 cam at 200,000 & GDE Tune + 01 Jetta 220k on the road and improving as we go + 01 Golf 320k TDI back on the road since 11/14 + 96 Burb with just 145k towing camper and hauling 6 kids and B E A U T FUL wife! Added 06 GMC Sierra DMax to fleet.
BobZ is offline   Reply With Quote
Old August 30th, 2012, 09:25   #11
rolotomassi44
Yeah I remember browsing the forums and seeing this. My glow plug lights were coming on as usual which leads me to believe relay 219 is not the problem. Thank you though Bob.
Old August 30th, 2012, 09:33   #12
BobZ
No problem - It can present as an intermittent problem until it leaves you stranded. I did also have an issue with my tandem pump that caused a similar problem... Quite frankly, I think it was more 219 related though as it controls the fuel pump and the glow plugs and I think they are on separate contacts within the relay. The glow plug light is just a tell-tale sign. It is a cheap replacement to rule it out and cheaper than a tow.
Old August 30th, 2012, 09:41   #13
aja8888
aja8888's Avatar
Fuel Economy: About as good as it gets!
The new 219 relay is upgraded for better reliability. It's worth changing it out pro-actively.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
Bring the 1971 Beetle back to life thread:
http://forums.tdiclub.com/showthread.php?t=472400
aja8888 is online now   Reply With Quote
Old August 30th, 2012, 09:54   #14
BobZ
My updated one lasted as long as the original... I am onto the third at 194,000 miles. Actually, the original lasted more miles than the "updated" one...
Old August 30th, 2012, 09:55   #15
aja8888
aja8888's Avatar
Sounds like you need to carry a spare one.
Alarm won't turn off...Can't start car Buckaroo VW MKIV-A4 TDIs (VE and PD) 7 January 6th, 2016 18:50
Car won't start or even push start. srmichi TDI 101 8 July 12th, 2012 10:40
Can't start '98 Jetta TDI - Stuck in the *Car won't start* thread markwilk TDI 101 15 September 26th, 2010 19:30
Car won't start with new remote keyless mod ,will start with old alarm module (B4) whatsthegoodword VW MKIII-A3/B4 TDIs 9 December 13th, 2006 12:44
Car won't start; won't even turn over J. McGowan VW MKIV-A4 TDIs (VE and PD) 11 February 18th, 2003 06:41
Page generated in 0.16810 seconds with 10 queries
[Output: 124.64 Kb. compressed to 103.73 Kb. by saving 20.91 Kb. (16.77%)]
