Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2012
TDIFest 2012 Discussion about TDIFest 2012 on the Labour Day weekend (August 31st to September 2nd, 2012) in Ypsilanti (Ypsi), Michigan.
Old September 9th, 2012, 18:20   #16
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Which Meijer, the one at 3825 Carpenter? That looked to be the closest with B20.
Originally Posted by VeeDubTDI View Post
I think that's the one.
And I topped off the tank there to calculate the MPG to the fest. Fuel looked OK and smelled normal (as normal as a blend can smell).
Svante Arrhenius 1896
Old September 9th, 2012, 21:22   #17
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
I ended up driving out to the Wacker fuel station. The B20 I filled up on there was high quality!
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
GTiTDi is offline   Reply With Quote
Good places to get a timing belt done? pnyknight Ontario 30 January 13th, 2012 10:41
Any good bushing places k45 Upgrades (non TDI Engine related) 2 August 14th, 2007 09:21
Bio Diesel Good for Particulate Filters! Spokane Walt Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 July 25th, 2006 11:50
Is this good bio-diesel fo fo weed Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 9 February 1st, 2002 00:04
2 good Diesel specialty repair places IL and IA GeWilli VW MKIV-A4 TDIs (VE and PD) 0 December 7th, 2000 08:53
Page generated in 0.14321 seconds with 10 queries
[Output: 56.20 Kb. compressed to 51.87 Kb. by saving 4.33 Kb. (7.71%)]
