Old October 20th, 2012, 13:26   #16
Herm TDI
Herm TDI's Avatar
Check the Black/White check-valve.
If this little POS is defective your performance will be flat...weak...lame...limp.
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old October 21st, 2012, 07:54   #17
shotgungaz
shotgungaz's Avatar
Fuel Economy: town =34.run=58=leaning on her a bit too much= 14 mpg lol
want to add one more thing ive noticed.the turbo seems to come in later after leaving my car over night by about 500 rpm but after couple of miles it settles at about between 2000 rpm and 2100 rpm? any suggestions guys??
shotgungaz is offline   Reply With Quote
Old October 23rd, 2012, 07:24   #18
shotgungaz
shotgungaz's Avatar
fixed my problem and it was my boost control solenoid but thanks for the help anyway NOT.not a single reply to help me out guys.ive put the fix on for anyone else who reads this anyway but bit dissappointed in the lack of help.seems google was the best help lol.
Old October 23rd, 2012, 07:30   #19
shotgungaz
shotgungaz's Avatar
my m8 had similair probs with his seat and was just the maf.check in this order.vagcom first if available then maf sensor then boost control sensor then the vains in tyhe turbo and actuator.to find vagcom in uk just put in vagcom users uk and it will give you a list m8.
Old October 23rd, 2012, 07:31   #20
shotgungaz
shotgungaz's Avatar
to check maf just unplug it and see if it makes any difference if not your mafs goosed lol
Old March 7th, 2013, 14:27   #21
shotgungaz
shotgungaz's Avatar
this sounds a lot like what happened to mine a few months back scott.i asked for help on here tried different things,took it to awsome gti for diagnostics which showed no error codes and no boost leaks also checked the vnt which was fine so i went on a gut feeling and changed maf sensor even though it said it was ok on diagnostic which still didnt fix it and then i changed the boost control sensor off just behind the maf it is m8.pull off the pipes and put a new one in and screw back to body work .pipes back on and hey presto my car has been perfect since.car ran perfect except the boost lag so very similair to whats happening with yours m8. mines a gt tdi 150 golf. hope this helps m8 as it cost me a bloody fortune lol.
Old March 7th, 2013, 15:31   #22
98 jetta
TDI(s): 1998 Jetta
You want real help? Get that trash turbo off your car and install a new one.
98 jetta is offline   Reply With Quote
Old June 3rd, 2016, 19:30   #23
Antjp
Thumbs up
I have got the same problem as you had. I have no power. It's Never missed a beat for the 2 years I've owned it. Then after being stood for the weekend, It's slow as a snail. Thanks for posting this. I've been searching for 2 weeks now to cure my problem. And I was going to go down the route of booking it in for diagnostic, but at least now I have some starting point of a possible cure.
I have a Bora pd150. Is this possible faulty part on the bulkhead held in place with 2 10mm nuts, and in front of the part is the flexible air duct pipe? Thanks again. From ant
Antjp is offline   Reply With Quote
Old December 29th, 2017, 17:32   #24
rkarski
TDI(s): 2002 Jetta
02 Jetta TDI with 311,000 miles, I am having the same issue with no boost in first until it hits 2500rpm after replacing turbo with an after market. Any more ideas? Just bought it today and it is our first VX and TDI.
rkarski is offline   Reply With Quote
Old December 29th, 2017, 17:56   #25
UhOh
UhOh's Avatar
Why did you replace the turbo? If the old one puked I hope that you cleaned out the intercooler piping/bits. And I hope that you didn't have a runaway (and there's engine damage that wasn't dealt with).
What turbo (manufacturer) did you install? A cheap turbo is going to cause you nothing but headaches.
Did the turbo come with an actuator attached? (if not, then it's likely a cheap one) Good turbos will come with actuators that are adjusted. Regardless, it may come down to needing to adjust the actuator rod.
PD150 feels slow until 3.5k rpm Diesel Head. VW MKIV-A4 TDIs (VE and PD) 2 April 26th, 2011 10:17
Shift at 3K, 4K or 4.5K RPM for max acceleration? Bob_Fout VW MKIV-A4 TDIs (VE and PD) 25 February 10th, 2006 15:51
Just Wondering:44mpg fwy @2K rpm or 3.5K rpm = OK? Jackbear TDI Fuel Economy 22 February 16th, 2005 16:09
5K RPM with 300 miles Garver VW MKIV-A4 TDIs (VE and PD) 8 June 7th, 2001 16:23
Ooops TDI does 5K RPM! ScottTDI VW MKIV-A4 TDIs (VE and PD) 17 April 24th, 2001 18:41
Page generated in 0.14805 seconds with 10 queries
[Output: 99.92 Kb. compressed to 85.29 Kb. by saving 14.63 Kb. (14.64%)]
