Old August 22nd, 2012, 23:14   #1
scottyboy553
Default no boost until 2.5k rpm!
hi
first of all im new to the tdi forum and already im posting for help,i have a golf tdi anniversary edition and friday night the turbo let go,anyway fitted new/remanufactured turbo yesterday and now the car will not come on boost until 2.5 rpm,theres no fault codes wot so ever so im puzzled as to what could be the problem,ive unplugged the maf and i get no boost at all so that seems fine,all pipes are on correctly and the problem was not there with the old turbo unit.So guess i could do with a little help guys if you would be so kind,all suggestions welcome.thanks in advance scott.
scottyboy553 is offline   Reply With Quote
Old August 23rd, 2012, 02:44   #2
DanG144
This sounds as if your turbo is staying at the minimum boost position.
What year car is this? What engine?
If it is a VNT turbo, does the turbo actuator move to the stop set screw when vacuum is applied?
Old August 23rd, 2012, 02:44   #3
Ol'Rattler
Ol'Rattler's Avatar
It would really help to know what year and engine code you have.
Were did you get the new turbo? If it is a re-man than you may have wasted your money.
Could you explain how the old turbo failed? If it came apart, parts of the compressor may have been ingested by your engine causing damage to pistons and valves.
If the seal in the old turbo failed and you had a run away from the engine burning it's own oil you could have had a hydro-lock which will bend connecting rods.
If the VNT actuator is not adjusted properly, it could cause boost problems. Also, vacuum leaks could cause the problem you describe.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old August 23rd, 2012, 02:59   #4
scottyboy553
sorry assumed when i registered and had to put what type of car ect it would show,the car is a 2002 golf tdi 150 (arl) anniversary edition,the bearings failed in the turbo and i stopped straight away as to prevent further damage,certain nothing has gone into engine and cams ect are all fine,the turbo was from turbo solutions and ive fitted remanufactured turbos to a few other cars and they have been fine,wouldnt have thought they would be able to sell them if they are unfit for the purpose they are being sold for but if it isn't then it can go back,gunna try adjusting actuator which turbo solutions has advised and see if it cures anything,had to do same on vxr i had before so shall update when ive tried this,thanks
Old August 23rd, 2012, 06:16   #5
scottyboy553
Right ive adjusted the actuator 3/4 of a turn like the turbo supplier told me to and it doesnt seem any better,2nd comes on boost at 2500 rpm,3rd about 2100 rpm and 4th at 1800 rpm,5th and 6th seem fine,had a lot more poke low down in low gears before and still no codes.now im puzzled!
Old August 24th, 2012, 06:07   #6
scottyboy553
are there any tdi wizards out there?
Old August 24th, 2012, 07:53   #7
DanG144
When you put 20" hg or more vacuum on the actuator, does it move to the stop set screw?
Did you adjust the actuator rod length 3/4 turn? Hopefully not the stop set screw.
You need to ensure your turbo actuator is set to start moving at about 4" hg and then it should be at full boost before 20" hg.
There are plenty of people willing to help you. Maybe even your next door neighbor. Are you in Chesterfield Australia? Ohio, USA? England?
Also the more explicit and exact you can be in presenting your facts and communications, the better we can help you.
Old August 24th, 2012, 10:16   #8
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Originally Posted by scottyboy553 View Post
....2nd comes on boost at 2500 rpm, 3rd about 2100 rpm and 4th at 1800 rpm, 5th and 6th seem fine,...
That description makes me believe there is a time component involved. The amount of time needed to build pressure may be consistent in each gear, but the amount of time from accelerator pedal application to some rpm will vary depending on the gear ratio.
If boost builds slowly enough it's even possible that in first gear you'd be at red-line and fuel reduction before boost ever builds. In 5th and 6th the acceleration and RPM increase is slow enough that the same number of seconds needed to get to 4000 rpm in first might only bring you to 1400 or so and as a result the boost might 'seem fine'.
I'd check for things like leaking pressure or vacuum in the control hoses, and for slow reacting movement of the actuator. It's probably moving far enough, just not quickly enough to be effective in the lower gears.
Svante Arrhenius 1896
Old August 24th, 2012, 10:18   #9
duwem
Fuel Economy: Used to get 45, but big wheels, big brakes and a roof rack, 36mpg now
Are you seeing on Vagcom your actually not getting measured boost, or is just a seat of the pants deal?
Might be good to actually log whats going on to help troubleshoot.
2002 Golf GLS TDI 5spd-288,000 miles
Panzer FMJ Skid Plate, PP520's on Flow Balanced Injectors, H&R 28mm Rear Swaybar, Eurosport X Brace, TT Shifter, 42DD shifter Bushings, exhaust restriction reduction, Eibach Pro Kit Springs, Koni STR.T Struts/Shocks, TT front control arms, spindles and brakes, 17" wheels w/ Potenza Summer Tires
duwem is offline   Reply With Quote
Old August 24th, 2012, 12:12   #10
scottyboy553
First of all thanks for the replys,gettin frustrated with the car now,im good with spanners and sockets but not really any good with the technical side of things.
I am located in chesterfield derbyshire which is indeed england.I have no idea what 20hg is but phoned turbo solutions who advised me to move the actuator rod and he just asked me to see if the actuator rod moved upto the grub screw stopper when you start the engine and it does,he says "it cant be the turbo as when it comes on boost it pulls hard(which it does) and doesnt die straight off plus in the higher gears its fine" which he is gunna say but i think its something else aswell.I dont have vag com but do have access to a couple of good diagnostic scanners from my mates garage where i do all my own work,think one's called launch and cant remember the other but only know how to read codes and stuff on them.
Thinking of trying a new boost control valve just to eliminate this but it was fine before turbo went,other than this i really have not got a clue,dont know of anyone near me that has vag com apart from probably jbs autodesigns and they have ripped me off before so i wont use them ever again so ive hit a dead end,all pipes look fine and no signs of leaks.
Old September 22nd, 2012, 11:49   #11
yogurt
TDI(s): mk5 gt tdi
Hi,Ive had the same problem on a 140 gt tdi,run very well before the turbo blew,fitted re-con turbo and the car feels like its lost loads of power and boosts now at 2400rpm but before around 1400rpm, everything has been tested so in my eyes its the turbo, will post again when fixed!!!!!! this coming week
yogurt is offline   Reply With Quote
Old September 22nd, 2012, 14:31   #12
losmi88
TDI(s): Seat Leon TS
We expect a response if you succeed to solve the problem .... I have the same problem on my car,Seat Leon ARL.my old turbo was broke on half,and i put remanufactured turbo.
losmi88 is offline   Reply With Quote
Old September 24th, 2012, 19:10   #13
vwdiesel101
Fuel Economy: best tank:1250km 65 UK MPG
adjust your actuator would be my guess
vwdiesel101 is offline   Reply With Quote
Old September 25th, 2012, 14:28   #14
losmi88
The problem is in the turbo, we tried 3 garret turbo and the problem is still present.In the end we put KK Turbo and the car works perfectly
Old October 20th, 2012, 12:23   #15
shotgungaz
shotgungaz's Avatar
Fuel Economy: town =34.run=58=leaning on her a bit too much= 14 mpg lol
ive got this same problem on my mk 4 golf gt tdi 150 arl. still has stock turbo.been to awsome gti on vagcom and shows no error codes atall,he checked vnt on turbo n75 all ok and g31 air temp sensor all perfect its a 2002 model.new mas air sensor fitted .bosch.im at a loss now as io dont know what to do.any help would be great guys thanks.ill check this every day and post the cure if i find one b4 getting rid lol.garage told me to keep driving it until it throws up a fault code but *** they had it 3 hrs and didnt find anything even with the vagcom.i ordered a new boost control solenoid just to see if it helps but well see.
shotgungaz is offline   Reply With Quote
PD150 feels slow until 3.5k rpm Diesel Head. VW MKIV-A4 TDIs (VE and PD) 2 April 26th, 2011 10:17
Shift at 3K, 4K or 4.5K RPM for max acceleration? Bob_Fout VW MKIV-A4 TDIs (VE and PD) 25 February 10th, 2006 15:51
Just Wondering:44mpg fwy @2K rpm or 3.5K rpm = OK? Jackbear TDI Fuel Economy 22 February 16th, 2005 16:09
5K RPM with 300 miles Garver VW MKIV-A4 TDIs (VE and PD) 8 June 7th, 2001 16:23
Ooops TDI does 5K RPM! ScottTDI VW MKIV-A4 TDIs (VE and PD) 17 April 24th, 2001 18:41
Page generated in 0.16539 seconds with 10 queries
[Output: 123.04 Kb. compressed to 102.78 Kb. by saving 20.27 Kb. (16.47%)]
