Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2012
TDIFest 2012 Discussion about TDIFest 2012 on the Labour Day weekend (August 31st to September 2nd, 2012) in Ypsilanti (Ypsi), Michigan.
Old August 22nd, 2012, 20:53   #1
TDIDaveNH
Left Lane Coal Roller at Large
TDIDaveNH's Avatar
TDI(s): 1997 Passat
Default Getting Ship-Shape for Fest?
What have you got to do car-wise to get ready for fest? I was thinking about this today and wondered if anyone else has a mountain of car repairs to do that you'd like to be done before rolling out?
I'll go first:
Install two new front tires and get aligned
Timing belt and all rollers (overdue by 4K miles)
Charge AC- figure out what is going on?
Replace rear brake proportioning valve that is leaking fluid like a sieve
Get to the bottom of code P00500
Remove cracked windshield to have rust media blasted & new dealer window installed.
Locate front GLX filler lenses and one foglight to replace broken ones
Polish headlight lenses again
Register & transfer old vanity plate from former B5.5 and get inspected (fingers crossed)
Figure out why trunk light no longer works.
Vacuum and clean car
Granted I can let some of this stuff slide, especially the last one if need be
Per cogo, non per mico (By compression, not by spark)
GLX conversion in Storm Grey- my first TDI engine rides again.
TDIDaveNH is offline   Reply With Quote
Old August 22nd, 2012, 21:20   #2
mrvermin
mrvermin's Avatar
Ok, the laundry list.
- Found out today that the head pulled and was pushing boost back through the coolant causing the overflow to vent and compression to drop when hitting over 20psi . So will have to pull off the head and get it all fixed up, at same time I'll check the turbo, pipes and anything else under there.
If I have time after that, I want to install my new 2004 tail lights, W8 overhead console, summer rims (ok running all summer on my 15" winters was no fun), LED trunk light strip, and maybe my HID fogs..... If I have time for any of that after the engine work
MrVermin
NEW: 2011 Golf Sportwagen Highline, Navi, DSG, Pano-Roof
OLD: 2001 Jetta TDI: 6speed ERF swap, Fully Built Block & Head, RC Tuned, Race520's,
Colt Stage2 Cam, PD150 Intake, PD150 RacePipe, VNT17/22, OMI, 3" Full Exhaust, 3BAR MAP, 11mm IP, Defender Skidplate, 17" Ariettas, GLI Suspension, Audi TT LCA Bushings,
mrvermin is offline   Reply With Quote
Old August 23rd, 2012, 06:10   #3
n8ronJ
n8ronJ's Avatar
Over the past 2 weeks I have been getting my car ready for the Fest and I'm still not done.
Installed SBC Stage 2 Daily clutch.
Changed trans fluid.
Installed new Evo Atlas Skidplate
Installed new trans speed sensor (do NOT forget to unplug that when you pull the trans..)
Installed new dampener on the serp belt tensioner & changed serp belt
I'm currently waiting on a McNally boost/egt gauge to install and I'm getting new tires and alignment early next week.
It's been a busy few weeks..
sold2003 Jetta GLS TDI, 275k, Platinum Grey, 5 Speed, SBC Stage2 Daily, Evo Atlas Skidplate, RC3
n8ronJ is offline   Reply With Quote
Old August 23rd, 2012, 06:28   #4
trog
TDI(s): 2000 Jetta
Default OH Yeah!
Long list, but I'll keep it short:
Finish the engine rebuild, hopefully breaking it in on the way to Fest.
Lucky I don't have too far to drive
trog is offline   Reply With Quote
Old August 23rd, 2012, 07:00   #5
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
The list is long:
My car right now:
Going in:
Oh, and my house was robbed last week and the got my car amp that was just repaired. So I have to find a new amp and install it if I want audio.
2.0 ALH, GTB2260, 12mm, etc, etc.....
www.nashimporters.com http://louisvillevw.org/
TDI Repair Available, TBs, Clutches, Manual Swaps, BSM, etc..
PD Cam tools, BSM tool, VE & PD TB tool rental available.
Nash_TDI is offline   Reply With Quote
Old August 23rd, 2012, 07:51   #6
mrvermin
mrvermin's Avatar
Originally Posted by Nash_TDI View Post
The list is long:
sorry to hear about the break-in, really does suck.
MrVermin
Old August 23rd, 2012, 08:20   #7
romad
romad's Avatar
Yesterday I used a free "Summer Inspection" coupon from the dealer to have it checked over. Only found a slight oil seep from valve cover gasket (I'll keep an eye on it then have Matt-98AHU look at it), and recommended new fuel filter and brake system flush (ditto Matt checking the brakes and already had the filter on order). Looks like nothing critical before I leave Sunday. Between the Chico mini GTG in Sep and the Bay Area GTG in Oct, everything should be taken care of.
The fleet:
romad is offline   Reply With Quote
Old August 23rd, 2012, 08:45   #8
Ah, the joy of a new car. I'll put fuel in it, already washed it.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old August 23rd, 2012, 08:52   #9
loganbmx4gt
loganbmx4gt's Avatar
Wife slammed the door yesterday and I could tell by the sound the window jumped off track. Rolled window up and sure enough it did, so I have to get out there and get that situated.
Got the suspension and new tires and alignment done last month & oil change last week. Just need my window window fixed and car cleaned up.
loganbmx4gt is offline   Reply With Quote
Old August 23rd, 2012, 14:53   #10
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Still so much to do!!! Only eight days? yikes!
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
schnellvw.com
GTiTDi is online now   Reply With Quote
Old August 23rd, 2012, 19:36   #11
deegingerkid
Beware the Ginger! Vendor
Fuel Economy: 38-44 depending on lead-footed-ness and highway/city proportion
I'll go first:
Wow Dave...that's a ton of stuff. Good luck! Good thing the car isn't loaded up with tools.
Ohio to California transplant and loving it!
2k Beetle, Batik Blue, 5sp., Stage 3 TDtune, front knuckle upgrade (from 1.8T), Seat Cupra R rear axle bushings (I rather like tasteful and discreet upgrades)
I'm a ginger. You've been warned.
deegingerkid is offline   Reply With Quote
Old August 23rd, 2012, 20:48   #12
tomo366
TDI Lifer
tomo366's Avatar
Started cleaning it yesterday and will start the ZAINO treatment this weekend.....and put 4 new Conti Extreme Contact DW tires on her today Almost ready to go!!
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old August 23rd, 2012, 21:14   #13
mlemorie
TDI(s): 2004 Jetta
Fuel Economy: Avg: 43-44
Been wanting to detail for a while now, I doubt that Ill get to it though. I have all new suspension bushings, ball joints and tie rods to go in but thats not looking too good either. I keep getting called in to work weekends.
I have VCDS and plenty of tools.
mlemorie is offline   Reply With Quote
Old August 24th, 2012, 09:20   #14
GTiTDi
GTiTDi's Avatar
ordered new wheels and tires, just hope they get here before I leave for Fest!!!
MK2 GTI build
schnellsnailFB
schnellvw.com
Old August 24th, 2012, 11:53   #15
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
I'm finalizing all kinds of paperwork for Fest, signing stuff, paying bills, etc. The to-do list is getting shorter!
Then I have to pack the car, get all of the A/V stuff loaded, wash it maybe (although that's kind of useless since I'm making a 500 mile drive out to Michigan). Hopefully I can get it detailed once I get into town.
Then the big setup begins! Registration suite, tents set up in the parking lot, item cataloging for the raffle, various meetings with the hotel, etc.
ONE WEEK TO GO!
Trusted TDI Mechanics Map || TDIClub Chat
Want to help out at the Fest?? Fest Volunteer Thread. Zippy_car TDIFest 2007 28 August 25th, 2007 18:36
Ho5G Post-Fest Fest Hamsterdiesel Eastern USA 304 September 25th, 2006 16:25
FS OEM Golf Tail Lights in good shape $75 + Ship jonsonneborn Private TDI Items for Sale/Wanted 0 September 9th, 2004 17:51
new shape golf sdi biggy2003 Other VW Group TD(I)s 6 February 12th, 2004 10:38
TDI Fest 2002 Exp/Income (2003 Fest take note) The Ripster TDIFests 2000 - 2003 10 September 9th, 2002 17:15
Page generated in 0.18279 seconds with 10 queries
[Output: 135.06 Kb. compressed to 113.33 Kb. by saving 21.74 Kb. (16.09%)]
