Old August 20th, 2012, 19:34   #1
SilveR316
SilveR316's Avatar
Default Braided Steel Turbo Oil Feed Line?
I remember reading a few years back these flexible oil feed lines are "bad" for your engine.
Is this actually the case? Are there any downsides to using the flexible line? Can someone that has run this line chirp in?
I'm thinking about replacing my old oil feed line with this one when I do my turbo swap, and it seems a hell of a lot easier to hook up the flexible line instead of the crazy bent stiff line.
Also, who sells them? Is KermaTDI the only place?
'00 Golf TDI, 410k, 1852 @ 25 psi, Race520's, 3 Bar MAP, SBC st2 Endurance, VR6 Brakes, Koni Coilovers + RSB, TT LCA Bushings, 2.5" PP Downpipe + Eurosport Cat Back, Hella Tinted Tails
SilveR316 is offline   Reply With Quote
Old August 20th, 2012, 19:39   #2
happysack3
TDI(s): 03 Jetta Tdi
Its alot cheaper to make one yourself Itll only cost 40 bucks
happysack3 is offline   Reply With Quote
Old August 20th, 2012, 20:00   #3
vogelspinnen
vogelspinnen's Avatar
TDI(s): VW caddy
Been running one for 2 years, no issue so far. And yes, it will be much cheaper to make your own.
vogelspinnen is offline   Reply With Quote
Old August 20th, 2012, 20:01   #4
Whitbread
Whitbread's Avatar
TDI(s): Several
Any half decent hydraulic shop can make what you need. I'd offer to ship you one but shipping will probably cost more than the line.
You need;
M10x1 to 1/4" MJIC adpater
M12x1.5 to 1/4" MJIC adapter
90* 1/4" FJIC to MJIC elbow
45* 1/4" FJIC to MJIC elbow
30" long 1/4" braided stainless hose with straight 1/4" FJIC ends
1/4" JIC is also known as -4AN in the industry. Depends on who you talk to and what line of work they mainly cater to.
02 Jetta TDI
Whitbread Performance Innovations
-Full TDI maintenance, performance and custom fabrication services. 248-755-8118, 10AM-5PM EST M-F. Please email or call only for business inquiries. PM's are not for business communication.
Whitbread is offline   Reply With Quote
Old August 20th, 2012, 20:10   #5
SilveR316
SilveR316's Avatar
I'd love to make one if I had the abilities to do so, but unless someone has detailed instructions I don't really see it happening. I don't mind paying for it if its more convenient that way.
Whitbread, would you be willing to sell one to me?
Old August 20th, 2012, 20:36   #6
Whitbread
Whitbread's Avatar
TDI(s): Several
Write down the shopping list I gave you and go to any hydraulic shop. They will know what everything is. Look up a Parker, Eaton, or Aeroquip distributor near you.
I can't sell any for a while as I'm in detroit during the week and only back in ohio on weekends when my local hydraulic shop isn't open.
02 Jetta TDI
Old August 20th, 2012, 20:58   #7
SilveR316
SilveR316's Avatar
Ok, I'll see what I can find.
Are any special tools required for the job?
Old August 21st, 2012, 06:31   #8
Genesis
Fuel Economy: 53/48/42
You can generally get the fittings either in crimp-on (requires a hydraulic crimper to put the ends on, and they're one-time use) or re-usable two (or sometimes three) piece fittings.
I used to make up my own lines all the time for my boat; it's not difficult at all. Small-diameter fittings generally do not require a a mandrel for assembly.
Genesis is offline   Reply With Quote
Old March 7th, 2013, 23:46   #9
dsljetpak
TDI(s): 03 Alh Jetta
Fuel Economy: Any where from 45-60 on a good day.
Yo, sorry to bump an old thread. But, Whitbread's advise is bang on. I took all the sizes down to my buddy who understands fitting gibberish and he was able to make me up exaclty what I need. Getting rid of the banjo bolt and the stupid fitting on the turbo. Now the oil line can easily messed with if need be. Thanks a bunch! PS: Make friends with a kid who works at a hose shop. I got mine for 14 bucks!
dsljetpak is offline   Reply With Quote
Old March 9th, 2013, 16:44   #10
Sc0
Fuel Economy: 46/40/34
Bought one from Kerma some years back, no issues... Bought it as a replacement since my old fitting was seized on the turbo and kinked/snapped the hardline when I tried to loosen it.
Sc0 is offline   Reply With Quote
Old March 9th, 2013, 20:09   #11
nathan_b
Fuel Economy: 50mpg
if you remove some coolant lines you can get the turbo out with the oil line on it, thats what I do rather than break it, its worth $80 or so for a few minutes out of your way.
nathan_b is offline   Reply With Quote
Old June 3rd, 2013, 16:36   #12
nh nam vet
With 275,000 miles on my 1997 (10/96 production decal) 1Z TDI Passat, I had an ever increasing oil drip coming from the turbo. I took the easy way out and replaced the turbo oil return line (with the new block adapter) but still had a bad leak. I checked the web on replacing the only remaining suspect: the turbo oil supply line.
Paramedick’s 2/16/09 post http://forums.tdiclub.com/showthread.php?t=239382 on how to replace the exhaust manifold gasket was the way I went. I stopped after removing the EGR cooler since there is no need to pull the intake manifold: the turbo input supply line is clearly exposed.
However, if you have never yanked your intake manifold, now would be the time to perform this huge performance improvement. That was probably the messiest job I’ve done on this VW but had the biggest payback, I thought I had a new engine.
When I had previously cleaned the intake manifold I removed all of the OEM spring clamp hoses and replaced them with 5/16” head stainless steel worm drive clamps. It is so easy now to pull hoses. Other hints to make this job easier and reduce confusion: write down each removal step numerically on paper, wrap a band of masking tape around each hose/pipe/vacuum line/electrical plug removed and write with a Sharpie on the masking tape the number of that step, use Ziplock bags to hold smaller parts and include in the bag a piece of paper identifying the contents.
Since it was such a PITA to remove the original hard line, I wound up cutting it up to get it out. Also remember to remove the dipstick and the crankcase to CCV breather hose (2 x 6mm Allen). This will make more room for the new hose (hard or flexible) installation.
I decided to go with a flexible turbo oil supply line and used Whitbread’s 10/20/12 post http://forums.tdiclub.com/showthread.php?p=4119389 on what to get. The oil supply comes off of the aluminum oil filter housing and is a M12 x 1.5 female hole. The steel turbocharger destination is a M10 x 1.0 hole. I wasn’t successful in finding anyone local to put a hose together, so I compiled a list of parts:
Oil supply line, Turbocharger, braided steel -4 AN 36”, Turbonetics 10724
Metric adapter male 12mm x 1.5 to male -4 AN, Russell 670440
Metric adapter male 10mm x 1.0 to male -4 AN, Russell 670500
Coupler fitting, 90 degrees -4 AN to male -4 AN, Russell 614804
Coupler fitting, 45 degrees -4 AN to male -4 AN Russell 614704
Also needed: a 10 mm and 12mm crush washer for the metric adapters into the turbo and oil filter housing. I got all of the above from Summit Racing Equipment. They ship faster than anyone. My cost was just under $100, almost what vendors get for hard steel lines. I also cleaned both of the metric holes with Q-tips and alcohol and used Permatex High Temperature Thread Sealant PX# 59214 on the metric adapters for leak-free peace of mind (IT WORKED!!). Thanks again to Paramedick, Whitbread and all TDIclub members for sharing their knowledge.
My DD 1997 B4 sedan is @351k. The back-up plan 1997 B4 sedan is @234k. Her 2002 A4 TDI sedan is @334k.
nh nam vet is offline   Reply With Quote
Old June 3rd, 2013, 18:18   #13
A5INKY
Fuel Economy: pretty good
^Glad you got it figured out. FWIW, you could have gotten the supply line cheaper and just as fast here:
http://www.darksidedevelopments.co.u...d-2-0-tdi.html
Yes, it is shipping from the UK. Ryan must have made a deal with the devil, he ships parts DHL and it cost no more and is just as fast as most domestic suppliers.
Just another alternative.
A5INKY is offline   Reply With Quote
Old June 3rd, 2013, 19:55   #14
nh nam vet
Thanks A5INKY, I did find the darksidedevelopments turbo oil supply on a GOOGLE search but anticipated mucho dinero on shipping, thus went do it yourself. I anticipate older TDI's will need this fix in the near future. JESUS, I LOVE MY TDI!!!
Old June 4th, 2013, 00:25   #15
ryanp
ryanp's Avatar
Shipping is quite cheap if you are not in a rush and reasonable if you are, you can always check before paying too
Yes i wont enjoy the afterlife :b haha
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
05 TDI Golf turbo replacement pics and oil feed line replaced w/ steel braided line. Kruso VW MKV-A5 Golf/Jettas 6 May 8th, 2013 20:52
WTB Braided steel Oil Feed Line for AHU i8therice Private TDI Items for Sale/Wanted 1 June 4th, 2012 05:07
WANTED: Stainless steel braided turbo oil feed line 2003 ARL engine. JakobDK Private TDI Items for Sale/Wanted 1 April 9th, 2012 14:35
Braided turbo oil feed line Bobby Singh Private TDI Items for Sale/Wanted 0 April 6th, 2010 13:29
What are your thoughts on steel braided oil feed line? b18onboost TDI 101 13 April 14th, 2008 10:17
Page generated in 0.15986 seconds with 10 queries
[Output: 131.02 Kb. compressed to 109.64 Kb. by saving 21.37 Kb. (16.31%)]
